New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Dec 18, 2018 at 2:09 PM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    Check out my photo album...I did components and cross overs in the kick plates with power pack 90W bridged amp tucked up above the glove box...
    https://www.tacomaworld.com/media/albums/polk-mm6501-and-alpine-ktp-445u-install.30097/
    Ah you're doing rears...
    It's a 2010 access cab? I don't think you have rear door speakers? There is a spot for them but there are no speakers in there. There are wafer speakers in the headliner behind and above the driver and passenger that are the "rear" channel. They are just glorified noise makers. When I did my upgrade I just disconnected them.
    Skierrichy and Bridge4 like this.
  2. Dec 18, 2018 at 2:31 PM
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    To many, but never done
    U should get a freebie then ask your insurance it won't hurt, then fix it yourself and pocket the rest!:thumbsup:
    tacobell007[QUOTED] likes this.
  3. Dec 18, 2018 at 3:07 PM
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    2008 access cab
    I took a bunch of stuff out of the door pocket to see if it was just vibrating from something in there. But that same shit has been in there for a long time months and can’t imagine it is causing me to think it’s my imagination
    So when I check in later it will can be confirmed that my speaker is junk. I attached a picture early I thought about posting a video with the sound but that will be stupid
  4. Dec 18, 2018 at 4:01 PM
    LivinLoud
    LivinLoud Miller Latte Advocate
    TJ
    Western mass
    ECOBOOST
    I mean… it’s a Ford, you don’t care
    Cross posted in the BST thread but...
    Up for grabs is a storage drawer that fits perfectly against the wheel wells in the bed of the truck. I picked it up with high hopes, but I’ve found that it does not leave enough room for my needs between the box and the tonneau. The box is lockable but i lost the keys, easy to replace. I plan to replace it with a plastic tool box. This is a great option for someone with a cap. Please PM me if interested! Located in Westfield, MA.
    Dimensions are 46”W 28.5” D 10” H
  5. Dec 18, 2018 at 5:02 PM
    TreeFortRichard
    Brian
    Ok. The 2008 had real rear speakers. That makes it pretty simple as the wiring is all there. Just turn the fade to rear and balance to left and listen...The speaker should never blow with a factory head unit....but they do die...any upgrade will be worlds better. I would do front and rears. It's not difficult at all....a zero skill person would probably take a sat/sun going really slow. I think it took me 4 hours but I was running new wire and installing crossovers and an amp. You could seriously install 'just speakers' in a bout 20 min per door. I don't know if you have the factory radio or you upgraded but if you didn't upgrade be aware that the factory head unit was tuned for the factory speakers and may even have limitations on the kind of sound it can output. There may not be full range sound going to the rear speakers.
    I found this. It's a photo install breakdown for opening up the rear door on a 2008
    https://www.speaker-installation-photos.com/Toyota/Tacoma/Tacoma-21/i-Q9wcPGL
    If you buy speakers from Crutchfield they give you all the hardware
  6. Dec 18, 2018 at 5:39 PM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    You’re the man! Stopped by AutoZone today, snagged that bulb and it made life so much easier. Fluid coming out was dark brown. Put fresh ATF in (per the cap recommendation) and turned the car on from lock to lock as well. Small whine now so I’ll see if it disappears on the commute tomorrow. Plan to repeat the 5 minute process next week.
  7. Dec 18, 2018 at 5:53 PM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    I think it’s a factory system. It’s a 5 CD changer. I will have to look
    Yes I will have to look . Around midnight I will check
  8. Dec 18, 2018 at 6:13 PM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    FA5A25A9-FC97-4DDE-B4CD-77504F4C81AC.jpg This one.
    WTF I should know and it’s driving me nuts
    Skierrichy likes this.
  9. Dec 18, 2018 at 6:16 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Hard to really see but the ladder edge of the stationary part nailed the top of the windshield qnd cracked both panes
  10. Dec 18, 2018 at 6:49 PM
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Satoshi grill, 3rd Gen TRDOR Bucket Seats, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, LCE Balance Shaft Delete, ECGS front diff bushing, TRD Sport LSD rear diff, Diode Dynamics SS3 Sport fog lights, Stainless Steel Brake-lines, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, Bilstein 8112 front Coilovers w/ rear Bilstein 5125's/IronMan lift leaf springs, Archive Garage Hammer Hangers, JBAs HD UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, 2019 Steering wheel, color matched door handles
    Forget my last comment about fixing your mirror, its definitely time for a replacement!
  11. Dec 18, 2018 at 7:03 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Those speakers will be simple. Trust me.
    At 10 years old even factory ones can go, exposure to heat/cold can do them in for instance.
    Looks like you have 6.5's in the rear doors. Those ain't bad, you might not need plates..just the wiring adapters. You "can" do it without adapters but why cut up the stock harness if you don't have to? I didn't use them on mine but I pulled new wire for my amplifiers.
    Bridge4 likes this.
  12. Dec 18, 2018 at 7:24 PM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Glad to hear ^^^
    Mine was actually whining a bit before and sounds much better now
    Clark27[QUOTED] likes this.
  13. Dec 18, 2018 at 7:36 PM
    Markcal
    Markcal Well-Known Member
    Something I just learned is that when you call your insurance company to ask a question about a potential claim, a notation is made in their system and could result in a rate increase even if you never file the claim, so be wary of doing it.
    16Tacos and Skierrichy[QUOTED] like this.
  14. Dec 19, 2018 at 2:16 AM
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    Really?! I have done this before but never had an increase.
    If that were to happen though I'd switch pronto.
    I do usually swich between Geico and allstate, had progressive many years ago they always seem to be out of the competition though. Geico has always been my favorite though.
  15. Dec 19, 2018 at 6:56 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Hankook DynaPro AT2 (Summer), Blizzak DM-V2 (Winter)
    I had Hanover for years. I'd check yearly and no one came close on price without dropping the coverage to something laughable. When I was buying the F-150, Hanover told me it would be around $2300 to insure it for the year, so I looked again. This time, everyone was lower. Geico ended up being the lowest, I'm at around $1000 for identical coverage and deductible to what Hanover wanted $2300 for. Plus, this one has rental coverage on top of it.
    Skierrichy[QUOTED] likes this.
  16. Dec 19, 2018 at 7:07 AM
    Clark27
    Springfield, MA
    2015 Lexus GX460
    Yeah no whine prior but not too concerned about it. Felt good turning and will repeat the process again a few times before I start really looking into it.
  17. Dec 19, 2018 at 8:24 AM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    Absolutely right there!
    I called Allstate to ask if I needed to report with them on a wood stove install. A month or so goes by and get an increase in my bill . The gave me soME BS and deny it.
  18. Dec 19, 2018 at 8:49 AM
    morri89
    morri89 Well-Known Member
    Brendan
    Hopedale MA
    2020 Rubicon
    Been pretty quiet in here the last few days. Guess everyone is as slammed at work as I am :notsure:
  19. Dec 19, 2018 at 8:54 AM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Learning Morse code. Dead to the world for at least a week ...
    Bridge4, tacobell007 and Skierrichy like this.
  20. Dec 19, 2018 at 8:58 AM
    BananaPeelOut
    BananaPeelOut Well-Known Member
    Ben
    NH
    2005 silver access cab TRD Off-Road
    Kenwood Headunit, CB radio setup, wind deflectors.
    what does "..." mean?
