New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Jan 3, 2019 at 9:43 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    At 24 miles round trip for work it's not bad for me, but if I had a longer commute I'd definitely be looking at fuel sippers for a DD and keep the Ram in the garage most of the time.
  2. Jan 3, 2019 at 9:46 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    50 - 60 miles a day for me :anonymous:
  3. Jan 3, 2019 at 10:16 AM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    Happy new year Jeff. Sorry about the truck; it can be replaced. Glad everyone is okay. Just came across this thread and figured it might be beneficial info as you negotiate with the insurance company, and look for a new truck.
    https://www.tacomaworld.com/threads/fear-loathing-denial-i-think-my-tacoma-is-totaled.568864/
    JeffB[QUOTED] likes this.
  4. Jan 3, 2019 at 10:24 AM
    SilverBulletII
    SilverBulletII Well-Known Member
    New England
    2017 Silver Tacoma SR, MT, 4 cylinders, 4X4
    My 2017 SR 4 banger MT operates at the same mpg figures you stated above. Interesting.
    Noelie84 likes this.
  5. Jan 3, 2019 at 10:34 AM
    Noelie84
    Noel
    Wales, Maine
    Especially when you figure that it weighs less, has less frontal area, and produces 1/2 the HP and torque numbers of the F150. :notsure:
    Personally, I'd love to see somebody shoehorn a 2.7 & 10 speed into a Tacoma, just to see what it could do :laugh:
  6. Jan 3, 2019 at 10:45 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
  7. Jan 3, 2019 at 10:47 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Hankook DynaPro AT2 (Summer), Blizzak DM-V2 (Winter)
    Plus, it'll tow 8100 lbs, run a 0-60 in under 6 seconds, and it cost about the same as a midsize configured the way I'd want one. I also get this kind of mileage with 3.73 gears--a rare option for these trucks.
    It doesn't make sense to me that the midsize MPGs are as low as they are. Even the Ranger, which is now apparently the best, is lower than I feel like they should be.
  8. Jan 3, 2019 at 10:50 AM
    Noelie84
    Noel
    Wales, Maine
    Probably has to do with the fact that they're not that much lighter than a full-size any more. Sure, there's a little less steel/aluminum involved, but they need to be reinforced so much to meet the crash standards that you don't save that much. Plus they've got all of the same luxury & tech bits that the full size trucks do, which also add weight (and are also why the midsizes aren't really any cheaper than a full-size, since they've all got the same tech and that's the expensive part). :notsure:
    Plus they typically have smaller engines, so the power/weight ratios are pretty similar to the bigger trucks, so there's not really any advantages there, either.
    tacobell007 likes this.
  9. Jan 3, 2019 at 10:59 AM
    js312
    Joe
    New England
    If I remember right, my truck is 5015 lbs (GVWR minus Payload Sticker). But, I think a less loaded SuperCab with the same engine can be around the 4800 lb mark. A loaded DCLB Tacoma (which is similar in wheelbase to mine) is what, 4500 or so? You're right, that's not a huge difference.
  10. Jan 3, 2019 at 11:19 AM
    Noelie84
    Noel
    Wales, Maine
    Sounds about right. I think my '16 was right around 4800 or 4900 curb weight. Plus the Tacoma's have more ground clearance and that tends to hurt MPG's a bit as well.
  11. Jan 3, 2019 at 12:08 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    I'll need to figure it out with my new commute at the new shop. When I lived 7 minutes away from my old shop I wasn't getting good mileage around town. I also sit in my truck to eat lunch. The truck still says I'm averaging 16.5 mpg though. My commute now is about 20 minutes one way. Nice having basically 1ton running gears and half ton suspension though
  12. Jan 3, 2019 at 12:15 PM
    Pugga
    Massachusetts
    You might sort of get to see it if Ford gets a little crazy with the Ranger. If they make a Ranger Raptor, that 2.7L Ecoboost is a prime candidate for the powerplant.
    How much does your 2500 weigh? My 250 is sitting around 6,400 lbs as best I can tell (she's heavier now with all the stuff I added, 6,400 lbs I think is what it weighed when it left the factory).
  13. Jan 3, 2019 at 12:19 PM
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    I have been eyeballing that for a bit... keeping a couple in my van would be great if they last.....
  14. Jan 3, 2019 at 12:23 PM
    Noelie84
    Noel
    Wales, Maine
    About the same, upper 6400/lower 6500 range. But that's before the plow frame/electronics are figured into it. And with the 700lbs of ballast and 950 for the plow I'm pretty solidly at 8k+ a fair amount of the time right now.
  15. Jan 3, 2019 at 1:00 PM
    Pugga
    Massachusetts
    Wow, I'm surprised they're that close together. I have the new aluminum body which supposedly saved quite a bit of weight. The previous generation F250 must have been a heavy sum-bish.
  16. Jan 3, 2019 at 1:08 PM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    I wouldn't be surprised if they consider 200lbs a huge savings. And you could argue that it certainly is.
  17. Jan 3, 2019 at 1:13 PM
    Pugga
    Massachusetts
    For the F-150, it was a 7-800 lb weight savings from steel to aluminum for the crew cab. I think it was a little less with the Super Duty, but thought it would still be 5-600 lbs.
  18. Jan 3, 2019 at 1:14 PM
    Noelie84
    Noel
    Wales, Maine
    I don't know if it really did, though. They added a lot of frame reinforcement to make up for the lighter body so I think the net weight savings were only around a couple hundred pounds, tops. Plus I've got the smaller Hemi, the 5.7. It weighs in around 500lbs, and the 6.4 is closer to 700, I think. So I imagine Ford's 6.2 is about the same as the Ram 6.4, so there's a difference there too.
    I read a couple of articles that said that it was in the range of 300lbs, I think.
    JeffB and Pugga[QUOTED] like this.
  19. Jan 3, 2019 at 4:47 PM
    RetiredRedneck
    RetiredRedneck Well-Known Member
    Bruce
    Port Moody, BC
    2018 TRD Off-Road - The Grey Ghost
    Toyota Roof Rails/Rack Toyota front Skid Plate BAKflip Hard Tonneau Cover iBoard Running Boards AVS Hood bug/rock deflector AVS Window Rain Gutters Amazon Centre Console Tray Larsen 2m/70cm antenna QYT VHF/UHF Mobile Radio Auxting LED Reverse Lights Taco Garage DMM with RAM bits-n-pieces Toyota OEM Bed Mat Interior LED Light upgrade - SuperBrightLEDS.com Pop-n-Lock OG Fabrication Centre Console Molle Panels Decals and badges removed CaliRaisedLED Amber Fogs, Ditch Lights and bumper Light Bar MESO Switch Panels AirOnBoard Switches Home Brew Auxiliary Electrics Panel
  20. Jan 4, 2019 at 4:01 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    Nope never. There was an fj page I followed on Instagram that used one but other than that nothing
