New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Aug 8, 2019 at 6:46 PM
    Grand dude
    Grand dude Well-Known Member
    Dave
    lehigh valley, PA.
    2016 trd or dcsb & 2002 trdor exclb
    cool stickers and a baseball card With clothes pin, sounds awesome ! wicked
    just an fyi a few people were asking abt you at the RC takeover you were missed
  2. Aug 8, 2019 at 7:11 PM
    JeffB
    JeffB Well-Known Member
    Jeff
    N.E. CT
    2017 TRD Sport
    1st for me, nice pic.
    Well done.
  3. Aug 9, 2019 at 1:53 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Thanks buddy. That's nice to know
  4. Aug 9, 2019 at 4:32 AM
    morri89
    morri89 Well-Known Member
    Brendan
    Hopedale MA
    2020 Rubicon
    Anyone doing the spartan super tomorrow? Have an 8AM start time, might check out Treehouse after the race since it'll be my 4th race in Charlton and still haven't gone
  5. Aug 9, 2019 at 4:36 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    Well 3.5 hour drive took 4.5 hours but we are definitely in the mountains of New Hampshire. The truck did fine but even with the larger trans cooler the steep grades put the transmission to work and it reached 232F. Ended up all the way down to 2nd a few times. Fingers crossed we get the wife an expedition at the end of her lease. California is literally at a lake in the mountains. Great views to be had. Off to Santa's village today. I'll make sure to take some pictures today.
  6. Aug 9, 2019 at 5:38 AM
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    RinseKit + (adventure bundle) was $179 with code for $20 off
    took it out of the box, with the commercial box inside of it..
    included in the box was:
    box with resivoir, hose, and nozzle ready to go with 2 screw off plastic caps on heater, and booster pump holes
    sink adapter (brass)
    garden hose adapter (plastic) both adapters link into the nozzles quick adapter
    heater rod with thread adapter, and wrench for both sizes
    boost pump with integrated guage (65PSI max)
    silicone flat collapsible refill funnel for refilling unit in trail/where no running water is available..
    super soft quick drying towel/seat cover (its like a chamois cloth)
    everything was well packaged, and even in their boxes they fit into the rinsekit + case.
    Setup"
    Instructions were kinda vague, but I understood the principle of the device so intuitive for me, but would have been nice of them to specify which port for the heater rod, and which is for the booster pump.. I put the booster pump on the left side, and the heater rod in the right port (more centered on the unit)
    within 5 minutes I was screwing the heater rod, and the booster pump into the base.. came with a wrench of the heater rod, and thread adapter.. the hose length is such that at 6'3" I can leave the base on the ground, and hold the nozzle over my head. hose is probably 1/2" OD cloth covered hose.. heater rod cord is around 8ft.. and the booster pump handle sits proud of the mount surface about 3 inches, and pumping it is super easy (not hard to push down at all)..
    1st use:
    I hooked up the provided brass nozzle to my kitchen sink, no issues and filled with warm water.. took about 2 minutes to fill on town water 60PSI on 1/2" PEX.. I made hte mistake of not tightening the booster pump all the way,, and some water came out the threads.. I turned off the sink spigot, and turned the hose line shutoff valve.. I tightened the pump down (has a top o-ring), and turned the valve, and water faucet back on, and ran for another 20 seconds.. turned the fill valve off first, then the faucet as er instructions, to keep pressure in the unit. I removes the quick connect from the sink adapter and moved the unit outside to test it.. I gave the booster pump a few pumps, attached the sprayer nozzle and was suprised at the pressure it had.. easily on par with my garden hose, albeit a bit less flow (GPM) due to the smaller hose diameter.. the nozzle does feel a bit cheap (and it leaks a few drips, and I may replace it later with a nicer metal orbital nozzle) (i believe the quick connect is a standard garden hose plastic type).. the unit I tried on all spray patterns on the nozzle... mist, shower, jet, center, and angled. ( I believe these are the settings on it, at work now).. the center seems to be the best all around pattern for cleaning/rinsing/showering, with shower being second, but loses pressure, and uses water faster...
    I drained it dry through the hose, and packed everything into the hard case.. I had a prior engagement to go to.. will do more testing on it tonight.. specifically the heater rod on my 12v outlet in the Tacoma...
    Chasespeed[QUOTED] and Bridge4 like this.
  7. Aug 9, 2019 at 5:47 AM
    Scott17818
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    does the trans cooler have an independent fan? or is it relying on the engine cooling fan? you may want to look into either a temp controlled trans cooler fan, or an additional cooler would do it for you..
    jpereira2[QUOTED] likes this.
  8. Aug 9, 2019 at 6:44 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Morning, peoplefaces. Anybody doing anything good this weekend?
  9. Aug 9, 2019 at 6:47 AM
    Scott17818
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    finnishing touches on Deck 2.0 sealing my back door, and looking into getting seamless gutters.
    Bridge4 likes this.
  10. Aug 9, 2019 at 7:01 AM
    JeffB
    Jeff
    N.E. CT
    2017 TRD Sport
    I've got a small Mod to do.
    Noelie84 and nickonfire700 like this.
  11. Aug 9, 2019 at 7:17 AM
    Noelie84
    Noel
    Wales, Maine
    So no....:laugh:
    Sounds like me; I've got a huge bag of green beans that need to be canned, I'm picking up a 1/2 bushel of cukes tonight for pickles, and then I'm getting started on a woodshed for the cookstove in the addition (so I don't need to tramp through the whole house with armloads of wood).
    tacobell007 likes this.
  12. Aug 9, 2019 at 7:33 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Ugggh, I've got a cluster fvck of a bachelor party to basically run and I'm not even in the wedding party. The best man is border line retarded and the most horrific drunk I have ever met. The groom is big into motorcycles, the best man called me a month ago and asking if I could help him set up a track day as the party, I'm like "Henry, a track day is a big deal and going to cost us a shitload and you are asking a month prior? Not happening." I asked him to think of something else, so then he wanted to do F1 cart racing, the new Casino in Boston, a shooting range, lobster dinner in Boston then the breweries... I spent the past 3 weeks trying to get it through his head to tone it down, and in the end the groom wouldn't let me take it over so now nothing is happening. In the final hour I got a skeet shooting range to be able to host somewhat of an event, shoot some clays, but the best man never called me back now that ship has sailed. I'm done. I have 5 people coming to my house tonight, I guess we are getting drunk and that's the only fucking plan. Unreal. That's the only good news, it's only 6 of us total.
  13. Aug 9, 2019 at 7:40 AM
    Grand dude
    Dave
    lehigh valley, PA.
    Are you pulling a trailer or something
  14. Aug 9, 2019 at 8:06 AM
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    Working tomorrow....:mad:
    Noelie84[QUOTED] likes this.
  15. Aug 9, 2019 at 9:06 AM
    Scott17818
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    Sounds like my buddies bachelor party.. I was working doubles up until the day.. was told last minute to make the plans.. only thing other guy had setup was the hotel to stay at in portland.. I had to arrange transport for 6+ people (had rented a minivan to get us around, and wound up having to cancel it last minute, because no-one wanted to help out with $20 for the rental.. had to make last minute reservationsfor sebago brewery in Portland, hit up the bars in old port (total mistake here, all college attendees (I was 32 at the time, felt old).. then a trip to platinum plus for some strippers.. and then back to the hotel.... was a good time.. but sebago was a mistake.. must have been a new cook, cause my burger was still moo'ing, and the Hefeweizen was nasty.. tasted like bitter orange rhind and salt..... old port was ok, but a bit underaged for my tastes. strip[ club was ok.. hotel was definitly budget.. literally 6 blocks down from the strip club..... all in all it was ok, but we could have done much better with some planning..
  16. Aug 9, 2019 at 9:18 AM
    Bridge4
    Bridge4 Well-Known Member
    MA
    2003 DCSB Imperial Jade
    Hopefully good ol' Henry didn't get an invite
    If he did, maybe charge him a cover fee:rolleyes:
    Spare Parts likes this.
  17. Aug 9, 2019 at 10:10 AM
    jethro
    Geoff
    Southern NH
    Henry is going to pay for a lot tonight, both financially and verbally. If the moron can manage to get to my house.
    Bridge4[QUOTED] likes this.
  18. Aug 9, 2019 at 11:17 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    F250 mod. My transmission doesn't get above 203 towing through the mountains :stirthepot:
  19. Aug 9, 2019 at 2:02 PM
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    Get leaf guard covers while your at it . I need to do mine before fall
    Bridge4 likes this.
  20. Aug 9, 2019 at 2:08 PM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    Going to Hampton Beach tomorrow night with wife and dog then to Browns for seafood. Gonna take my small saltwater rod and cast some plugs out behind the restaurant
    Bridge4 and Fitzwilly like this.
