New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Sep 27, 2019 at 12:28 PM
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    Can anybody tell me if the wire clips that hold the headlight bulbs in place for my truck are easy to obtain. If I’m not mistaken I believe this dealership told me I need to buy the whole headlight assembly to get that I find that hard to believe and then I should be able to obtain it fairly easily
  2. Sep 27, 2019 at 12:28 PM
    Bridge4
    Bridge4 Well-Known Member
    MA
    2003 DCSB Imperial Jade
    If you plan on not using it most of the year, then it wouldn't be an issue. I had to roll mine up and down a lot in the winter and if I didn't remember to put it back flat before I went to bed, it was tough luck in the morning until another warm sunny day
    jethro and emelianenkov[QUOTED] like this.
  3. Sep 27, 2019 at 12:39 PM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    I never had a problem with my Truxedo lo-pro qt but then again I always unrolled it as soon as I was done.
    And Alex @emelianenkov it kept the snow out great while allowing me the use of the whole bed without blocking my rear window!
    emelianenkov likes this.
  4. Sep 27, 2019 at 12:50 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I think you're doing the right thing, ask people on here. I'm sure someone has a trashed set of lights and could get you the clips. Otherwise, give NAPA, Advanced or Autozone a call and see if they sell the bulb retainer clips.
    If you go through a dealership, that is likely not a part they sell separately, that doesn't mean it isn't available somewhere else separately. I have to believe someone sells them and they're probably like a $0.50 part.
    Pibbles99[QUOTED] likes this.
  5. Sep 27, 2019 at 12:58 PM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    I would only be using the bed during the weekend, if ever in the winter. If I did have to use it, I would close it up before it became an icicle.
    The Truxedo is really appealing, though that Gator looks good too. Plus no rails, so I can take it off and put the RTT on quickly.
    Bridge4[QUOTED] likes this.
  6. Sep 27, 2019 at 1:04 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    You might want to opt out of a tonneau cover unless it's one that you can stand on, so you can clean your roof off during the winter.
    Not sure what you'd do about the hood; maybe a stepladder.
    Bridge4 and emelianenkov[QUOTED] like this.
  7. Sep 27, 2019 at 1:05 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Yeah but like all the other tri-folds, in order to used the whole bed you either have to remove and store it or have it block your whole rear window. The roll ups just roll up and are out of the way
    emelianenkov[QUOTED] likes this.
  8. Sep 27, 2019 at 1:08 PM
    emelianenkov
    Alex
    NORTH POLE
    :laugh: Shit, you're right......
    Does auto insurance cover damaged paint from 20lb propane bottle torches?
    That's true. It'll be a while, and a lot of Ramen, before I can afford to accessorize this truck. Maybe I'll get a few little things when I sell that 05 outback.
  9. Sep 27, 2019 at 1:12 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Yeah and the lo-pro qt is not cheap for what it is
  10. Sep 27, 2019 at 1:14 PM
    emelianenkov
    Alex
    NORTH POLE
    Looks great though!
    I might try to have them throw a tri-fold into the deal, or see what other offerings they have here.
    The only accessory I was dead set on having/installing was a remote starter, and this has it. Everything else is nice, but not a necessity.
  11. Sep 27, 2019 at 1:14 PM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    Copy that! Just now getting off my ass and ordering a passenger side headlight assembly because it is all hazed over and I’ve had enough of that. Fog lights. Does anybody recommend a fog light assembly that is decent? One of mine leak and I would like to change those out.
    Thanks
  12. Sep 27, 2019 at 1:25 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Stock or aftermarket fog lamps?
  13. Sep 27, 2019 at 1:27 PM
    Noelie84
    Noel
    Wales, Maine
    Everybody will recommend morimoto LED's, but unless you've got LED headlights to match they just look too mall-rated for me :notsure:
    For something like a fog, an aftermarket like TYC will work fine. You can go OE if you want but they're more $$ for basically the same thing
  14. Sep 27, 2019 at 1:51 PM
    emelianenkov
    Alex
    NORTH POLE
    Have you tried one of the Mother's headlight restoration kits??
  15. Sep 27, 2019 at 1:52 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    KC would be another LED fog lamp. The KC is a bit more "regular" looking than the Morimoto but offers the improved performance of the LED
    Noelie84[QUOTED] likes this.
  16. Sep 27, 2019 at 2:19 PM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    I ordered a TYC headlight . Got good rating. So I think the TYC fog will suffice. I will add the Ciiton( spelling?) to the fogs. They are dual color , both amber and white. I really want an amber fog lighting for obvious reasons. Thoughts?
  17. Sep 27, 2019 at 2:21 PM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    Negative. Are they worth it?
  18. Sep 27, 2019 at 2:27 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I have a set of foglights available.
  19. Sep 27, 2019 at 2:45 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Got my wheels today. Hope to have them installed next week.
    emelianenkov, Spare Parts and Bridge4 like this.
  20. Sep 27, 2019 at 5:07 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Beginning the proper indoctrination on her first night home.
