New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Dec 19, 2019 at 9:44 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    First issue with the wife's 5th Gen t4r at 126k miles. Neutral safety/ gear indicator switch is going bad. Unless you move the shifter back and forth between n-d a bunch of times it won't display "D" on the MFD and it throws a cell/ knocks the trans out of gear while driving. Fortunately it was only $100 plus $50 overnight shipping from Camelback Toyota ( best I could fine locally was wetborough Toyota @$178, and they couldn't get it till next Friday.). Now I just need to find a warm-ish day to install. Anyone ever done one before? It's 1 bolt and 1 nut on the pass side of the trans. I just haven't looked to see how much of a pita it is to get to.
    tacobell007 and Bridge4 like this.
  2. Dec 19, 2019 at 9:56 AM
    Bridge4
    Bridge4 Well-Known Member
    MA
    2003 DCSB Imperial Jade
    I liked it because I'm half way there on my wifes 2016. We have had to replace the gas tank flap due to warping and we had an issue with the MPH digtal area that needed to be fixed under warranty.
    Otherwise has been awesome. Hope to make it 126k with not much else!
    good luck on installation.
    Sloth[QUOTED] likes this.
  3. Dec 19, 2019 at 12:12 PM
    loki32687
    loki32687 Matt
    Peabody, Ma
    17 TRD Sport Inferno
    Jcyr likes this.
  4. Dec 19, 2019 at 2:38 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    I don't, but what are you running for a head unit presently?
  5. Dec 19, 2019 at 2:43 PM
    loki32687
    loki32687 Matt
    Peabody, Ma
    I have a F309TCM waiting to go in.
  6. Dec 19, 2019 at 2:51 PM
    ABA180
    East Bridgewater MA
    That unit is 18x4, max 50x4. Your power pack would be 45x4. IDK what you're going for but might be better to buy a bigger amp for around that price.
  7. Dec 19, 2019 at 3:12 PM
    loki32687
    loki32687 Matt
    Peabody, Ma
    Trying to not have to rewire everything, as plug and play as possible, and get decent sound out of it.
  8. Dec 19, 2019 at 3:35 PM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    It should be worth it in my opinion. The head unit is chip power and the brick will have a small power supply so it's more steady power.
  9. Dec 19, 2019 at 3:45 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Matt @loki32687 you might want to check out the Kicker Key amp. Its very cool in that it has it's own dsp built in. It automatically adjusts sound levels and time alignment.
    Search for it on YouTube. 5 star car audio does a good video install and review on it.
  10. Dec 19, 2019 at 3:52 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
  11. Dec 19, 2019 at 4:33 PM
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    I need one of these for my Ben Franklin stove.
    22”W ( front) X 18” (rear) 12” (depth).
    center has hole in it.
    I need to replace it because I do not want hot coals to burn directly on the metal. Eventually it will cause sagging. I have looked but I’ve had no luck. Any suggestions would be helpful and if anybody knows I would very much appreciate it
  12. Dec 19, 2019 at 5:19 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    I've seen them at tractor supply before, probably of similar quality. Also, this:
    https://www.amazon.com/HY-C-G22-Hea...ywords=fireplace+grate&qid=1576804542&sr=8-14
    If you know somebody who's handy with a welder, you could also have them put tack 1/2" rebar across the bottom. That'd help keep it from warping/sagging from the heat & weight of the wood, but probably not with the burn-thru.
    Chasespeed likes this.
  13. Dec 19, 2019 at 5:32 PM
    JeffB
    JeffB Well-Known Member
    Jeff
    N.E. CT
    2017 TRD Sport
    Add a layer of Fire Bricks on the steel then get add a grate.
  14. Dec 19, 2019 at 8:37 PM
    ABA180
    East Bridgewater MA
    Gotcha. That won't hurt to start there if you want ease of installation I reckon.
  15. Dec 20, 2019 at 1:40 AM
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    Exactly. It’s the front grill of the old 1928 model John Deere. They just removed it and welded feet on the bottom.
    Pibbles99 and Rexfordian13 like this.
  16. Dec 20, 2019 at 4:44 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Oh hell no, if I can get suckers I'll probably fish for lakers in Piermont. If I can only get redfins, which I assume will be the case, I'll probably fish for browns in Washington. I will know by this evening!
    m603holden[QUOTED] and Bridge4 like this.
  17. Dec 20, 2019 at 5:22 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    Anybody else realise the sweet spot for fuel economy on a second gen is around 45mph. My highway (65-70mph) economy is worse than what I get in town lol
    dc welding, SilverBulletII and RoNeil like this.
  18. Dec 20, 2019 at 5:38 AM
    jethro
    Geoff
    Southern NH
    Yeah, and towing that trailer you have... omg. One of the big reasons I got rid of my Taco was because it got about 9mpg on the highway even pulling my ultralight clamshell trailer. With the Sierra I easily get double when I'm towing my extra tall inline trailer fully loaded at 75mph.
    jpereira2[QUOTED] likes this.
  19. Dec 20, 2019 at 5:40 AM
    rustyfromskowhegan
    rustyfromskowhegan Well-Known Member
    2013 AC 4x4
    My old man used to get 27-28 in his AC 4x4 4cyl, but his commute was almost exclusively 45mph off-highway driving. I get 22 on the highway with the same setup lol
    SilverBulletII likes this.
  20. Dec 20, 2019 at 5:53 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Yes, it's not too bad at 65 but once I go above that the economy goes down quickly.
    dc welding likes this.
