New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Jan 25, 2013 at 4:35 PM
    Boston10Taco
    Boston10Taco Dented
    MA
    2017 Tundra
    This is why I want to get Toytec's ultimate lift. Up to 3" lift and adjustable with spanner wrenches
  2. Jan 25, 2013 at 4:36 PM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    Or you could buy those fox coilovers for $500 :D
  3. Jan 25, 2013 at 4:52 PM
    Boston10Taco
    Boston10Taco Dented
    MA
    2017 Tundra
    That't front lift only though, and didn't he say add the cost of the rebuild to that? maybe I read that wrong.
  4. Jan 25, 2013 at 5:10 PM
    jdkilroy
    jdkilroy Well-Known Member
    Jon
    Southern NH
    '02 4x4 SR5 Access Cab
    I've read as many back posts as I can Alex, what are you getting for tires ?
  5. Jan 25, 2013 at 5:10 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Duratracs, that was like 15 pages back :D
  6. Jan 25, 2013 at 5:19 PM
    jdkilroy
    Jon
    Southern NH
  7. Jan 25, 2013 at 5:22 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    So you're a plumber or something Mike?
    Having a similar issue. It's been good for a bit but back at me again. I don't know much about plumbing in general but even I can figure out you shouldn't run a pipe parallel to the rear of the foundation..plus I am getting a draft somewhere in the bathroom under the Jacuzzi. GRR!!!
  8. Jan 25, 2013 at 5:25 PM
    mtn3172
    mtn3172 Well-Known Member
    2011 SR5 LB
    Mtn3172(Chris): I will make it, 430'ish
  9. Jan 25, 2013 at 5:26 PM
    Pugga
    Massachusetts
    No, just a DIY homeowner. Not a licensed plumber or electrician but know enough to fix my own stuff.
  10. Jan 25, 2013 at 5:29 PM
    Pugga
    Massachusetts
    When the contractor who built the bathroom for the previous owner plumbed the shower, he ran the lines on an exterior wall. I'm capping those and re-running them in my crawl space. I insulated the entire crawl space with spray foam insulation (that was a fun project) so I know it won't freeze under there and it gets the lines off the exterior wall.
    I tell you one thing, the Pex pipe and fittings make plumbing a LOT easier. I can and still do a lot of copper sweat fittings but you really can't beat those press on fittings.
  11. Jan 25, 2013 at 5:35 PM
    Boston10Taco
    Boston10Taco Dented
    MA
    2017 Tundra
    I'm not going to be able to get out of work early Monday, someone else took the day off. I don't get out until 5, it's looking like I'm going to need some help from someone.
  12. Jan 25, 2013 at 5:36 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    285
  13. Jan 25, 2013 at 5:37 PM
    Boston10Taco
    Boston10Taco Dented
    MA
    2017 Tundra
    The same thing happened to my friend last night. The pipes were on the exterior wall. We are repiping his shower tomorrow
  14. Jan 25, 2013 at 5:38 PM
    Pugga
    Massachusetts
    How late does this place stay open or what time do we need to pick them up by?
    Tony, I can pick yours up and bring them up to Millis if you want. Not sure if that's closer for you or not.
  15. Jan 25, 2013 at 5:39 PM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    Jon, I don't know if you're with your phone or not, I've been texting you.
    I'm getting duratrac 285/70/17's
  16. Jan 25, 2013 at 5:39 PM
    ABA180
    East Bridgewater MA
    That's part of it. The Jacuzzi is on the wall right against the crawl space. I don't know how it was done but you can feel an awful draft coming from underneath it as well, so my guess is it's not sealed properly.
    I'm a DIY guy as well but plumbing is not something I know how to do..I would hate to drop the $$ to call a plumber but it's beyond me.
  17. Jan 25, 2013 at 5:40 PM
    Boston10Taco
    Boston10Taco Dented
    MA
    2017 Tundra
    Mike, are those 265/75/16 duratracs with a 3" lift in your sig pic?
  18. Jan 25, 2013 at 5:44 PM
    Pugga
    Massachusetts
    If you have a draft then the plumbing isn't your problem, insulation is. Are the lines themselves at least insulated? You can buy pipe insulation cheap and it's very easy to instal (it's like those pool noodles, you just slide them over the pipe). You really need to seal off that draft. Can you access the space and see where the air is coming from? Maybe try that Great Stuff spray foam to seal it up (be careful, that stuff expands a LOT, don't put it in a confined space, make sure it has enough room to expand)
  19. Jan 25, 2013 at 5:51 PM
    ABA180
    East Bridgewater MA
    I got them insulated in the crawl space and heat taped as well.
    I can get in the space as well..I have a small panel to get in under the tub but not sure what's going on. IMO I think I have 2 issues..the pipes routing in the crawl space and the draft from the crawl space to under the tub. Even if the heat tape and such is working in the crawlspace the draft coming under the tub could do it, plus it's robbing me of heat.
  20. Jan 25, 2013 at 5:55 PM
    Boston10Taco
    Boston10Taco Dented
    MA
    2017 Tundra
    That would be awesome, I can prob be in Millis by 630-7, or I can grab them whenever works best for you.
