New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Sep 10, 2020 at 5:15 PM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
  2. Sep 10, 2020 at 5:18 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Free is good. I inherited my first Murray from my dad in 2010 with a bum hydro trans, which was not fixable. Found another one $200 for parts with a bum engine, but the engine fired up after I tightened the spark plugs. Still going strong.
    I'm up there at almost 47
    Yeah I drive a hydro! Wanna make something out of it?!?!?
    mach1man001[OP] likes this.
  3. Sep 10, 2020 at 5:20 PM
    crashngiggles
    Jared
    Hydro was always the way to go.....i ended up getting the standard with the push button blade clutch and regretted my decision ever since.
  4. Sep 10, 2020 at 5:32 PM
    ABA180
    East Bridgewater MA
    Turns out the Murray hydro back then at least wasn't very known for durability. I looked for a used transaxle alone first and called a place in PA that was a mower scrapyard. The guy said $700..IF I can find one.
    There were 3 different ones used in that run as well so finding the exact was a little challenging. One guy absolutely refused to provide me the tag# on the axle even though I had cash and was ready to drive 2 hours to him if it was the right one.
  5. Sep 10, 2020 at 5:53 PM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    The K46 that's in most lawn tractors isn't fantastic--at least the older ones weren't. Mine's on borrowed time and from what I see they tend to go before anything else significant does on most machines. You can find a standard transmission anywhere for next to nothing, but nobody junks the hydros so they're expensive. The K66 in garden tractors is supposed to be much better.
  6. Sep 10, 2020 at 6:58 PM
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    That grille is hideous..:puke:screaming for attention
  7. Sep 10, 2020 at 8:11 PM
    ABA180
    East Bridgewater MA
    Mine it was more they were all shitbox transaxles in that particular machine, much like finding a Chevy Luv engine.
  8. Sep 11, 2020 at 4:51 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Well, it depends on what the middle is. If I live to be 100 then I'm about at the middle.
    If I live to be 80 then I'm wayyyyyy past the middle.
    Bridge4[QUOTED] likes this.
  9. Sep 11, 2020 at 5:22 AM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    That is annoying for sure... I've literally only participated on the NE regional thread lol. Mostly, its one dude talking to himself every morning.
    I tried the index card method. FUCK that method.
    crashngiggles likes this.
  10. Sep 11, 2020 at 5:24 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The one time I used Plasti-dip, I just blasted the wheels and didn't treat the tires or do the index card method. It took a good bit of time to get all the plasti-dip off the tires but it did eventually all come off. If I ever do it again, I'll use the Tire Wet crap on the tires and I guess Plasti-dip just doesn't stick to it and comes right off.
  11. Sep 11, 2020 at 5:28 AM
    emelianenkov
    Alex
    NORTH POLE
    Honestly, I just shot it right on the tire. I mean, the tire is flat black, the wheel is flat black... I didn't see any overspray, nor did I care really lol.
    Spare Parts likes this.
  12. Sep 11, 2020 at 5:31 AM
    Pugga
    Massachusetts
    That was my one saving grace, I shot it right at the tire also and laid on on thick so it did eventually peel off, just took some time, a lot of cussing and a toothpick. I was using a dark silver color so it was noticeable. I'll likely break down and have to derp the black wheels on my truck. They're starting to get rock chips in the paint so, in a year or so, I'll either have to swap wheels again or make the decision to keep these and use dip to keep them looking decent. There are new hardeners now that make dip more durable that I'd go with as well as chemicals to specifically get brake dust out of dip. It's slowly becoming a better option than paint for things like this, in my opinion.
    emelianenkov[QUOTED] likes this.
  13. Sep 11, 2020 at 5:32 AM
    emelianenkov
    Alex
    NORTH POLE
    My solution for chipping was to hit my wheels with an aggressive wire brush in my drill, then bedline them with duplicolor in the blue can. :anonymous: :laugh:
    Bridge4 likes this.
  14. Sep 11, 2020 at 5:34 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Noted on both those, I figured the cards would be a PITA. I'll see if I can find the tire wet stuff you're talking about.
  15. Sep 11, 2020 at 6:00 AM
    emelianenkov
    Alex
    NORTH POLE
    I'm buying a chain fall tomorrow AM to be able to lift/flip the bed easier and safer, as well as help me position the sheet metal safely.
    I have to start measuring all the sections I need, primarily the center section of the bed first, then get that spot welded in place, weld on the cross supports, and work on filling the holes in on either side of the bed. Then I'll work on kinda remaking the wheel wells with diamond plate once the floor is pretty much done. The wheel wells are soft in some spots for sure.
  16. Sep 11, 2020 at 6:45 AM
    Pugga
    Massachusetts
    Chain fall, don't you have a winch on any of the 18 vehicles you own?
  17. Sep 11, 2020 at 6:59 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    The cards are super easy and only take about a minute a wheel to prep.
    Get index cards at the dollar store.
    tacobell007 likes this.
  18. Sep 11, 2020 at 7:10 AM
    emelianenkov
    Alex
    NORTH POLE
    Won't work for what I need to do lol
    zjcas likes this.
  19. Sep 11, 2020 at 9:41 AM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Yup or playing cards
  20. Sep 11, 2020 at 9:59 AM
    ABA180
    East Bridgewater MA
    Playing cards are meant to be counted..
