New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Oct 3, 2020 at 5:33 PM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    Look at this crap
    Skierrichy, Pugga and GarlicFarts like this.
  2. Oct 3, 2020 at 5:34 PM
    TreeFortRichard
    Brian
    I think new wheel bearings are one of those "Oh wow...how bad was it" repairs...
    mach1man001[OP] likes this.
  3. Oct 3, 2020 at 5:36 PM
    zjcas
    zjcas Well-Known Member
    Zach
    Hooksett
    2012 DCSB TRD Sport
    Fox 2.0 COs, Fox 2.0 Resi's, Wheeler's Prog. AAL.
    Definitely noticed once my driver side got done last year. Now with the roof rack I'm so used to the wind noise this noise now didn't even phase me unfortunately
  4. Oct 3, 2020 at 5:36 PM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Have to do my wife’s wheel bearings on her Camry. :( speaking of wheel bearings recently....
    Not sure which one it is, I know it’s on the left but I’ll look at just doing all of them. It’s a hybrid so this could be fun.
    :boom::welder::itllbuffout:
    was hoping there was an electrocution emoji.
    Skierrichy and Pugga like this.
  5. Oct 3, 2020 at 5:39 PM
    zjcas
    Zach
    Hooksett
    2012 DCSB TRD Sport
    Haven't decided if I want to take a crack at this bearing. DS I was able to get done under warranty (bought the truck used) but now either way I'm paying for it.
    GarlicFarts[QUOTED] likes this.
  6. Oct 3, 2020 at 5:43 PM
    GarlicFarts
    Lil Rhody
    yeah it’s easy enough on a Camry at least. I’ll probably do both fronts and see if that fixes it. I’ll have to check the brake pads tomorrow because if those are in bad shape then I’m doing those too.
  7. Oct 3, 2020 at 5:44 PM
    TreeFortRichard
    Brian
    May it not look like this...4hrs of hammering...even resorted to a log splitting wedge to get it off...
  8. Oct 3, 2020 at 6:08 PM
    zjcas
    Zach
    Hooksett
    2012 DCSB TRD Sport
    Looks like a grand time that I'm not sure I want to experience with an 8 year old new england truck haha
  9. Oct 3, 2020 at 6:11 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    It's not terrible. I can give you a hand if you got tools, I've done several
  10. Oct 3, 2020 at 6:15 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Do the bolts for the hub screw in from the outside or inside of the truck? I had a very rusted hub on my old Cummins and the bolts screwed from the inside. Ended up loosening the bolts just a bit and wedging the socket/extension against the frame and bolt. Started the truck and used the power steering like a press to pop the hub right out. Worked like a charm.
    Pugga likes this.
  11. Oct 3, 2020 at 6:15 PM
    GarlicFarts
    Lil Rhody
    fair. I’ll be doing it on a 5 year old New England sedan and I’m still not looking forward to it.
    m603holden and Pugga like this.
  12. Oct 3, 2020 at 6:39 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    It's an easy job. Hardest part is separating the spindle from the hub. Get a dead blow hammer and just go to worn. Or whack the damn thing with a sledge since you're replacing it anyways. It can definitely take some sweat to get them separated. But it's like 10 bolts total to remove the hub/ bearing assembly after taking the wheel off. Besides the axle nut everything is standard hand tools.
    Basically don't be a bitch and once you've got the hub to spindle bolts loosened (you can't completely remove them) beat the shit out of it and it'll come off.
    Skierrichy, zjcas, m603holden and 4 others like this.
  13. Oct 3, 2020 at 6:48 PM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Nope! Calipers were all good. All pistons moved freely and no leaks. Also no parts seized!!!
    It sure is!
    I can't believe how dirty that tube is on your brand new truck!
    4hrs? :eek: Wow!!!
    Anti seize is your friend! While the rest of the world is using lock tight on all there bolts we here in NE need to use anti seize on everything. I've done my brakes before and used anti seize on the caliper bolts, brake pad pins and the little brake line retaining bolts. That's why everything went so well this time!
  14. Oct 3, 2020 at 7:24 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Only several expletives? You must have to pay the swear jar
  15. Oct 3, 2020 at 10:14 PM
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    Yeah, that helps. :D
    Bridge4[QUOTED] likes this.
  16. Oct 4, 2020 at 3:04 AM
    Bridge4
    Bridge4 Well-Known Member
    MA
    2003 DCSB Imperial Jade
    We've been working to finish part of our basement the last few weeks. Sectioned off a mechanical and storage area and then framed and drywalled the rest. The outside walls were all framed and insulated anyways, so not much work there, mostly drywall. One more coat of on the walls in the basement this morning then I'm done. I thought it would be a relatively quick job, but with all the cutting in and whatnot I've been painting for about 10 hours a day the last three days. There were alot of pipes and other things to drywall around so a lot of corners in some sections. Never thought I'd be so sore from it either. Should only take 3 hours or so to finish up today though then ready for trim and doors this week hopefully. Goal is to have it all ready by the end of this week so that if carpet installers are ready early, so are we. Free HD installs on the carpet so hopefully that goes well.
    Then we will have almost doubled our living space, and created an area where we can keep all the kids crap as she gets older and needs places to play. Insulation in the ceilings so that if she crys/screams we have a place to bring her if someone is trying to sleep etc..:amen: We created a bathroom, but don't have the $$ to finish it right away, but in the next year or so we will add the fixtures. It will be nice to have a bathroom down there, especially since we will be also using the space as a guest room.
    Oh, and I can set up a decent spot down there to hang out when the wife wants to go to bed as well:thumbsup:
  17. Oct 4, 2020 at 5:40 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Yep, sort of justifies the catch can! All that oil is just what I got on my hands from taking off the catch can and transferred to the pipe. I still took a couple microfiber towels and cleaned out the inside so it was clean. What’s sad is, Ford has an air/oil separator... you can see how well it works.
    ‘Several’ is a very broad term... plus, I had to be careful because my boys were riding their bikes on the driveway right outside the garage and I didn’t want them to learn any new words...
    Bridge4 and tacobell007 like this.
  18. Oct 4, 2020 at 6:06 AM
    dc welding
    dc welding Well-Known Member
    Dan
    Swansea Mass
    15 DCSB TRD Sport BRM / 2002 AC SR5
    sounds like it could be a u-joint
  19. Oct 4, 2020 at 6:23 AM
    Bridge4
    MA
    What if the ford separator is working and it’s still that bad :goingcrazy:
    Pugga[QUOTED] likes this.
  20. Oct 4, 2020 at 7:31 AM
    Pugga
    Massachusetts
    It is, you can see the oil that’s been put back into the engine from the OEM separator. The damn thing had a lot of oil still in it also but it’s sealed so I couldn’t even drain and clean it. Hopefully, it’ll clear itself out in the next few thousand miles now that I stopped more oil from being able to go into the system.
