New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Oct 4, 2020 at 8:06 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Yeah but it is a diesel. Do they use that oil as part of its lubrication system for the top rings as it's got super high compression/boost? It's not like they have to worry about fouling spark plugs or anything.
    tacobell007 and Bridge4 like this.
  2. Oct 4, 2020 at 8:17 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    No, not part of the lubrication. All that blow by just mucks up the throttle body, EGR system and intake valves. It should have nothing but clean, fresh air in the intake. It also wouldn’t be terrible if it were clean oil by diesel oil is pretty laden with soot (big thanks to the EGR system). There’s a lot of nasty crap kept in suspension in diesel oil. When I changed it, oil minder was still at 65% but it was jet black.
  3. Oct 4, 2020 at 8:22 AM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    That's why I kind of liked the two Cummins Dodges I had. It was all pre emissions BS for diesel, so the crankcase simply vented out below the truck.
    GarlicFarts and vssman like this.
  4. Oct 4, 2020 at 8:23 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Yeah oil being black is pretty common. It would be cool if they come up with a way to vent the crankcase AFTER the throttle body.
  5. Oct 4, 2020 at 8:26 AM
    Pugga
    Massachusetts
    There are kits that do that. I bought the catch can trying to be responsible and not vent it straight out but still keep the oil out of the intake.
    If I could get rid of anything, i’d take out the EGR, I really don’t think that’s helping the truck’s longevity. The SCR and DPF system have lots of sensors that are prone to failing but aren’t actively trying to ruin the engine. But, lots of warranty so all the Al Gore crap has to stay for the time being.
  6. Oct 4, 2020 at 8:28 AM
    Pugga
    Massachusetts
    Or, just come up with an air oil separator that actually works!
    My dad’s Duramax has a much different system. There’s a lot more vertical travel in the crank case vent to drop oil out of the air before the separator.
  7. Oct 4, 2020 at 9:06 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    One more reason I didn’t get the duramax Colorado. I considered it but modern diesels are just all over the place in the states.
    Bridge4, Pugga and ABNFDC like this.
  8. Oct 4, 2020 at 10:28 AM
    jmferg
    jmferg Well-Known Member
    Any recommendations for a “new” canoe? I want one that can be carried short distances and loaded by myself.
    I bought this 16ish ft pelican explorer a few years ago for $200 and it has served well but the sun and dragging rock bottoms have worn it out.
    I am looking for something of similar size, capable of holding heavier loads (2 adults, child, small dog) or 2 adults fully loaded for duck hunting.
    It may see salt water as well.
    I have seen a ton of 17’ aluminum Grunmans and was curious how the riveted seems hold together on those.
  9. Oct 4, 2020 at 12:12 PM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    I've got a bottle of this...It went on every nut and bolt when I did the hubs and brakes...and trailer hitch...and....everything...the only issue can be the "Proper Torque" with a lubricant...
  10. Oct 4, 2020 at 12:15 PM
    TreeFortRichard
    Brian
    Now I need a new battery...I think AAA does an on site swap with discount...
    Pugga likes this.
  11. Oct 4, 2020 at 1:40 PM
    zjcas
    zjcas Well-Known Member
    Zach
    Hooksett
    2012 DCSB TRD Sport
    Fox 2.0 COs, Fox 2.0 Resi's, Wheeler's Prog. AAL.
    Never done one so I may take you up on it actually. Brakes, oil changes, etc and other general maintenance are all I usually attempt besides putting my lift in, but that wasn't done alone. Have plenty of hand tools just not my floor jack currently, that's down in RI...
    Edit: Would probably be a better idea to do it before I undercoat the truck for the winter. NH Oil guys spray THIIIIICCK
    tacobell007[QUOTED] likes this.
  12. Oct 4, 2020 at 1:54 PM
    ABNFDC
    Granite State
    I'm about 3 miles on the far side of Walter's Basin from you if you need a bottle jack(I'm not civilized enough for a floor jack) and jack stands. I did my wheel bearings about five years ago. They were super easy to do, but I also tend to half ass things. My biggest mistake was lifting both sides of the vehicle at once--I had to jam the opposite side into the ground to stop it from turning. That was all before I bought into the cordless impact wrench stuff.
  13. Oct 4, 2020 at 2:35 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Would be helpful to do before that so we aren't taking a bath lol
  14. Oct 4, 2020 at 2:54 PM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    I changed the oil on the girlfriend's CX5 today. It's been dealer maintained since new based on the records she had when she bought it. The access cover in the plastic splash pan was missing both screws so they just twisted it sideways and stuffed it into place. I ordered the right bolts for it so I can make it right next time, but it's a little ridiculous that would be the dealer's solution. At that point they might as well have just pulled the whole thing and pretended it fell off on a road somewhere.
  15. Oct 4, 2020 at 5:37 PM
    tacobell007
    Drew
    Western MA
    Thats like the dealer fix for cat heat shields, 2 hose clamps to keep it from rattling til they move or rust off
    js312[QUOTED] likes this.
  16. Oct 4, 2020 at 6:22 PM
    SilverBulletII
    SilverBulletII Well-Known Member
    New England
    2017 Silver Tacoma SR, MT, 4 cylinders, 4X4
    I'm a fan of Radisson Canoes.http://www.bwmarineproducts.com/canoes.htm
    Here's my 12'. It's not elegant, but its a workhorse.
    The outriggers are aftermarket and detachable. Not the best paddle canoe. It has oar locks built into the gunnels and mounted on the paddles. Rows well. Yes, a canoe you can paddle or row. Also comes with a motor mount bracket. I use an electric motor. Nice for trout trolling.
    52774C7B-534D-42B6-9744-D3FC18C5B0AF_4_5005_c.jpghttp://www.bwmarineproducts.com/images/Radisson Brochure.pdf
    jmferg[QUOTED], Pugga and tacobell007 like this.
  17. Oct 5, 2020 at 4:55 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    No, I'm past that.
    Been looking! LOL
  18. Oct 5, 2020 at 5:11 AM
    jmferg
    I hit a deer for the first time yesterday.
    I saw the large group of 8-10 deer start walking out from someones yard. I starting to slow from highway speed and hit my blinkers for the line of cars behind me. They immediately panicked and one-by-one bolted across the highway. i braked as fast as a felt comfortable without getting rear-ended. probably the fourth deer across stopped in front of my lane, turned jumped back to the shoulder, and then panicked and jumped back in front of me. At this point i was probably going 35 but hit her hip mid jump and flung her around 90 degrees and her head hit my drivers door. she rolled end over end a couples times somehow missing oncoming traffic. I looked back and to my surprise she got up and took off full speed up the hill. I ended up with a scuff on my hood and hair on the bumper. Gotta love metal bumpers.
    mach1man001[OP], Pugga and ABNFDC like this.
  19. Oct 5, 2020 at 5:19 AM
    jethro
    Geoff
    Southern NH
    I almost hit a very large black bear last night coming though Colebrook NH. Tis the season!
    Pugga, Boston10Taco and tacobell007 like this.
  20. Oct 5, 2020 at 5:31 AM
    tacobell007
    Drew
    Western MA
    My boss has his weekend house in Colebrook
    Boston10Taco likes this.
