New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Jan 22, 2021 at 7:31 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    It's possible. When I was writing service the 6.0's were much more common problem children. Of course, the 6.4's were still relatively new at that point.
    Edit-- On the other hand, the fact that 100-200k is really still pretty young for anybody else's diesel but good for an early Powerstroke is an indicator of just how unreliable they really are. :laugh:
    tacobell007 likes this.
  2. Jan 22, 2021 at 7:39 AM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    Not saying the 6.0 wasn't without issue, but the 6.4 was born to die :laugh:
    And yeah, the 7.3's go forever. And we have a few *cough*emissions noncompliant*cough* 6.7's that have well over 200k. A strong engine coupled with a body that isn't going to turn into Swiss cheese in 5 years is ending up with some promising results!
  3. Jan 22, 2021 at 9:22 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    The 6.0 and 6.4 were actually still International/Navistar engines. The 6.0 was a VT365 and the 6.4 was the MaxxForce 7.
  4. Jan 22, 2021 at 9:58 AM
    Noelie84
    Noel
    Wales, Maine
    Were they? So I guess that means that Ford decided to build their own diesel because Int/Navi's were too unreliable :laugh:
  5. Jan 22, 2021 at 10:00 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I want to drive the 6.2 with the 10 speed (requires an F350) to see how that combo does. If I were to go back to a gas, I'd go 7.3 all day long. The 6.2 is rock solid but it seems like the 7.3 is getting similar fuel economy but with a lot more low end power.
    On winter blend and commuting in and out of the city, I'm still over 17 MPG. In the summer, I can break 20 unloaded on a highway run and that's with the bigger tire package, crew cab, 4wd. I was getting 10-12 MPG towing the trailer where the 6.2 was getting 7-9 so a little better, nothing to write home about. The 6.7 is obviously a lot more comfortable towing though, set the cruise and go. I was getting 12-14 MPG with the old 6.2, best I could get was 16ish with ideal conditions.
    All that being said, you don't buy a diesel for the financial gain, you get it because if you're towing on heavy on the highway all the time, it will pull like a freight train.
    The older gas 250's weren't fantastic, thinking the 5.4. It was a complete dog. The 6.2 has been a solid engine for a long time, just not overly fuel efficient. The V10 they had for a while is an absolute beast but a gas hog.
  6. Jan 22, 2021 at 10:06 AM
    Noelie84
    Noel
    Wales, Maine
    And, just to keep you on your toes, it'd occasionally sneeze a spark plug :laugh:
    But, if you were towing at all it was head and shoulders over that 5.4; that motor was useless in anything heavier than an F150
  7. Jan 22, 2021 at 10:28 AM
    emelianenkov
    Alex
    NORTH POLE
    The only gas 7.3 that I drove was running on 7 cylinders.. and mounted in a large motor home. I want to drive a 7.3 F250 or F350 just to see what all the hype is about.
    The 5.4 is a nightmare that we are still dealing with. Usually we have at least 1 a month that we need to replace. That's always an awesome conversation with the customer. "Alright, so we found your check engine light is related to the variable timing solenoids. We can replace them, but at the same time while we're in there, we usually recommend replacing the timing chains, tensioners, and guides. Also once we do all of this, you may still end up with catastrophic bottom end failure due to a lack in oil pressure that won't present itself until you drive the truck for about an hour, and by that time, it is too late- AND we have no way of knowing if your engine has already suffered damage until after we do the repairs... So, you're looking at about $2,600 for the VCT, timing chains, and all with labor, plus you may be looking at another $3,500 for a junkyard engine to be installed if yours decides to grenade itself."
    The V10's are notorious for spark plug ejections, breaking off spark plugs in the head, and the exhaust manifold studs loosening up constantly or just simply snapping off in the head! I wouldn't wish a Triton V10 on my worst enemy.
    I get great mileage with my 7.3. I'm planning on having that as my adverse weather daily/tow pig. I also want to build a pair of bed bars to mount my RTT on, Tacoma-style :cool: I want the top of the tent level with the roofline for optimal aerodynamics lol.
    Y3jW3V8hjC_tFL-4KfngUgRCtfHNYfhbNOJgVDys_97ac37292b56075392c9b2503b0a7d60b0f10b1b.jpg
    Blackbeard83 likes this.
  8. Jan 22, 2021 at 10:39 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    JeffB, Bridge4, Blackbeard83 and 2 others like this.
  9. Jan 22, 2021 at 10:56 AM
    Noelie84
    Noel
    Wales, Maine
    Takes a lot of determination to ignore what's going on to get stuck that badly :laugh:
  10. Jan 22, 2021 at 11:07 AM
    js312
    Joe
    New England
    We have a 350 at work with the 5.4. It's a pig and feels like I'm torturing it just to get up hills with an empty 14' landscaping trailer.
  11. Jan 22, 2021 at 11:18 AM
    Noelie84
    Noel
    Wales, Maine
    Throw a dump body on the back of one and even when it's empty calling the skinny pedal the 'accelerator' is no longer an accurate term.
    emelianenkov, Blackbeard83 and Pugga like this.
  12. Jan 22, 2021 at 11:42 AM
    Blackbeard83
    Blackbeard83 Well-Known Member
    Sam
    Massachusetts
    2020 TRD Sport 4x4 ACLB MBM MT
    currently stock
    Two questions... How? And why? :duh:
    Also, I think that could have been done with a shovel and 4 MaxTrax. Just sayin'!:D
  13. Jan 22, 2021 at 11:45 AM
    Pugga
    Massachusetts
    When I was down south, we had some nasty clay sites that could get an inexperienced operator into trouble in a hurry. The more you wiggled on the stuff, the more you sank. If you weren't paying attention, you'd bury the tracks in no time and just make it worse trying to dig yourself out at that point.
  14. Jan 22, 2021 at 12:04 PM
    Blackbeard83
    Sam
    Massachusetts
    currently stock
    Good point. I still think they probably did a bad job inspecting the site and operator error.
  15. Jan 22, 2021 at 12:24 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    IDK. You can't even see where that guy was working. It looks like what Mike said. It just went in and sank.
    Blackbeard83[QUOTED] likes this.
  16. Jan 22, 2021 at 12:29 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Found out I need a radiator for my tundra while changing my oil earlier
  17. Jan 22, 2021 at 12:31 PM
    BINK05TRD
    BINK05TRD Well-Known Member
    Massachusetts
    TRD OR AC SILVERSKY 15
    I watched the whole video waiting for the recovery excavator to get stuck :rofl:
    Glad they got it out. Guys got talent for sure :thumbsup:
  18. Jan 22, 2021 at 1:14 PM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    This. Mill rate is only half the equation. It is expensive for towns/cities to complete a town wide assessment of property values so they only do it every so often. Over time new properties added to the municipal tax roll end up paying more than their fair share as they are assessed at current market value and other properties may not have been reassessed for a number of years. So each municipality tweaks the mill rate to make sure they collect enough taxes to run their community. Often a municipality will reassess the value of property in their town then adjust the mill rate down so the taxes are roughly the same as before the reassessment but the reassessment helps to put everyone on equal footing so everyone is paying their "fair share" of taxes.
    So looking at just the mill rate may not reflect how much is paid in taxes. If similar properties are assessed differently in different towns then the mill rate can make it so the amount of taxes paid is the same. If Town A has not done a reassessment in awhile then a property that is really worth $100,000 may only be assessed at $50,000. If the same house in Town B is assessed at $100,000 instead of $50,000 and Town A has a mill rate at twice that of Town B then the two owners will still be paying the same amount of taxes, even though it looks like it is much more expensive to live in Town A then Town B.
  19. Jan 23, 2021 at 6:41 AM
    SilverBulletII
    SilverBulletII Well-Known Member
    New England
    2017 Silver Tacoma SR, MT, 4 cylinders, 4X4
    Took advantage of yesterday’s relatively mild weather. Washed the road salt off and waxed the Tacoma. B4B7B9C8-A517-44E7-B4BE-EF15341FD624.jpg
  20. Jan 23, 2021 at 6:46 AM
    trdtacomabob
    trdtacomabob 2020 TRD Sport MGM
    Bob
    Westford, MA 01886, USA
    2020 TRD Sport
    Running boards, LED lights all around, Bed Step, Auto Start, Backup Anytime Front\Rear camera, relocated ECT PWR switch, under hood lighting, chrome delete kits, Gas Hole, Integrated locking tailgate, bed USB & 12V ports, access cab USB & 12V ports
    Looks nice, I'm jealous. My Access Cab is currently covered with a dusting of snow! We had several squalls just outside of Boston late yesterday.
