New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Jan 29, 2021 at 8:37 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Yeah, the Arris unit is the modem. It's hit or miss what you get from them and sometimes they'll reuse old stock.
    Mine from Spectrum is a Technicolor brand all-in-one unit and if you tell them you don't want their WiFi, they flash it with different firmware that disables it. I think that's what they always use if you get new equipment now.
  2. Jan 29, 2021 at 8:38 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    So based on the lifespan of 2 to 3 for a router, wouldn’t it make sense to “rent” the spectrum on and make them replace every two years, versus buying a new one every 2 years? That being said, I haven’t priced a new router in a while, I think the last one I bought was like 150.
    Cativelense likes this.
  3. Jan 29, 2021 at 8:47 AM
    js312
    Joe
    New England
    Spectrum typically won't replace it unless there's a documented issue, and then they have a tendency to reuse old stock.
    I haven't had a router degrade in performance or fail in a long time. I used to have that happen with old Linksys WRT54G devices (if you look those up, I'm sure you'll remember seeing them everywhere years ago). They'd start acting up and needing regular reboots. My current Netgear router is one I bought in 2017 and it's doing great. I had an old Netgear that was also doing great, but it only had 100mb ports so I replaced it (connection would test at 120mb or so direct from the modem, so it was a slight bottleneck). I've still got it in the basement, I figured if mine ever fails I could swap it in as a temporary replacement.
    Bridge4 and Spare Parts[QUOTED] like this.
  4. Jan 29, 2021 at 8:49 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Stupid question then, about modems/routers.
    Should they be rebooted/restarted once in a while? Is it necessary? meaning, unplugging it for a bit and then plugging it back in. Not talking about totally resetting it and setting it up all over again.
  5. Jan 29, 2021 at 9:03 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Yes......I reset my router and reboot/restart my modem and my router about once a week. It resets to cache, the network connections and if you think about it this, modems and routers are computer systems in and of themselves. I do leave my computers on for connectivity but restart them on average once a week as well. If you are running a network server, it may not need that short of a time span in between restarts but they still need to be maintenenced from time to time.
  6. Jan 29, 2021 at 9:09 AM
    crashngiggles
    Jared
    The lifespan of current routers are much better than older ones, like @js312 reiterated, but it really depends on how hard you use them, how many devices you generally run at the same time on them, and how good and efficient their internal software is. I had a Netgear Nighthawk and it was great but I wanted to expand my area which is the reason why I moved to the Google mesh system. The "all-in-one" modem/routers that ANY cable company will "rent" or "give" you are absolutely junk. They have an extremely limited range and do not manage the flow of data efficiently over multiple devices being used.
    Blackbeard83, Bridge4 and tacobell007 like this.
  7. Jan 29, 2021 at 9:10 AM
    Cativelense
    Nuno
    CT
    Makes perfect sense. Guess I should start doing that as well then, powering it off and back on once a week, at least.
  8. Jan 29, 2021 at 9:12 AM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    Are you "Renting" a router? Or is it included?
    So I have fios. I don't even use their router. I bought my own.
    https://www.tp-link.com/us/home-networking/wifi-router/archer-c2300/
    It's a little more complicated in general to set up, but if you can youtube and google you can find almost anything.
    The price is pretty low right now. It's a great deal for $100 and will blow away anything they give you.
    https://camelcamelcamel.com/product/B06XZ3S6B8
    TPLink has an app you use to do everything for the router including remote reboot :)
    tacobell007 and Spare Parts like this.
  9. Jan 29, 2021 at 9:48 AM
    Cativelense
    Nuno
    CT
    Ok, here's what I think is my last question if you guys don't mind.
    On the wireless network, what can or should be connected to the 2 ghz and the 5 ghz signals?
    i.e. cell phones, laptops/pcs, streaming devices, etc.
    tacobell007 likes this.
  10. Jan 29, 2021 at 9:57 AM
    Spare Parts
    Southern Maine
    I have both used my own and used cable company’s router in the past. The have all seemed to suck after a few years, which is why I currently have the cable company’s at this time. Looks like it maybe time to buy a new one again.
  11. Jan 29, 2021 at 9:58 AM
    js312
    Joe
    New England
    Put everything you can on 5GHz. Some stuff will only go on 2.4 (Smart home devices are commonly 2.4 only, like my thermostats, cameras, and washer/dryer).
  12. Jan 29, 2021 at 10:00 AM
    Cativelense
    Nuno
    CT
    Gotcha. Really appreciate all your help and input, Joe.
    Once I move my stuff upstairs, and get rid of the extender, going to put everything on the 5 ghz then. Depending on where I am able to move it to, I may try and "hard wire" my android box for my iptv service via an ethernet cable, just in case.
  13. Jan 29, 2021 at 10:06 AM
    Spare Parts
    Southern Maine
    I have my TV/Apple TV hard wired, at one time it made a big difference, not sure so much now
  14. Jan 29, 2021 at 10:11 AM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Not sure on streaming boxes, but on computers it makes a pretty big difference
  15. Jan 29, 2021 at 10:20 AM
    TreeFortRichard
    Brian
    Roku tv with 1GB wired network..I need that bandwidth for PLEX and 4K HDR
  16. Jan 29, 2021 at 10:25 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    We run 2 fire cubes, one hardwired next to the router one upstairs on wifi. And 2 firesticks on the tv's in the kitchen/ garage gym. We have Fios gigabit internet with the white cylindrical router from them. I don't notice a a difference between the downstairs hardwired fire cube and the upstairs wireless one. Though not exactly apples to apples since the upstairs wireless tv is only 720P, and the downstairs one with wired fire cube is a newer 4k one.
  17. Jan 29, 2021 at 10:50 AM
    tacobell007
    Drew
    Western MA
    Yea it might not be noticeable on playback stuff, but my pc on Wi-Fi is around 350mb/s down and around 705mb/s down on Ethernet
  18. Jan 29, 2021 at 12:05 PM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Next road trip in March (hopefully). Amarillo to Big Texan via TN, then out to LA (Cannonball Run style!), then back home via crossing the southern states (I'll go out to Jacksonville along the coast, just can't force Bing to show that oh well), then back up through the carolinas. Might stop at SOS and pick up some skids.
    Blackbeard83, Pugga, Bridge4 and 2 others like this.
  19. Jan 29, 2021 at 1:32 PM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    I'm nothing when it comes to computers (which is why I've stayed out of this conversation) but it's my understanding that the 5 ghz is faster but the 2.4 offers more range away from the router.
    BTW, we had better luck when our router was upstairs too.
  20. Jan 29, 2021 at 1:35 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    That sounds awesome
