New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Feb 17, 2021 at 11:10 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
  2. Feb 17, 2021 at 11:24 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Supply is .09ish, delivery is the rest. I had 830 kwh of use last month and it cost me $200.
  3. Feb 17, 2021 at 11:25 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Same here, though we don't use it often I have an 80 or 100 gallon Jacuzzi. Tankless ain't gonna cut it.
    I feel like you've been plotting the perfect time to post that
  4. Feb 17, 2021 at 11:29 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Nope......just created it on the fly. It definitely fit though.
    ABA180[QUOTED] and emelianenkov like this.
  5. Feb 17, 2021 at 12:07 PM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    WELCOME FRIEND!!!!!!!
    Dang, beat me to it.
    OUCH!
  6. Feb 17, 2021 at 12:14 PM
    crashngiggles
    Jared
    Semper Fi Sir!
    skeletron[QUOTED] likes this.
  7. Feb 17, 2021 at 12:19 PM
    emelianenkov
    Alex
    NORTH POLE
    Oops I forgot how to read a bill. Yeah... mine is more like $0.2165/kwh... damn robbery!
    Blackbeard83 and tacobell007 like this.
  8. Feb 17, 2021 at 12:28 PM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Being a single guy that is almost never home on the weekends, you guys would shit if you saw my power bill. It's like $90 on a high month. But what I don't understand is how my delivery can cost more than the power? I'm usually at about $40 for the power use and $50 for the delivery. Why the hell is the delivery that high? I understand they need to maintain the lines and it's a big deal, but after it's up, it's up. If I use less power I should pay less for delivery, but nope!
  9. Feb 17, 2021 at 12:32 PM
    Blackbeard83
    Blackbeard83 Well-Known Member
    Sam
    Massachusetts
    2020 TRD Sport 4x4 ACLB MBM MT
    currently stock
    I needed a new water heater about a year ago and we went with tankless option. Got a Navien unit that has been great for us and has definitely saved us a chunk of change in the gas bill. My wife takes baths almost everyday and it has worked great. The only time it is not great is if we have 2 showers running at the same time but we had the same issue with 40 gallon tank too. So it saved us a ton of space and does a great job with the forced hot water, 2 bathrooms, dishwasher and washing machine. Tankless definitely has come a long way IMHO.
    tacobell007 and emelianenkov like this.
  10. Feb 17, 2021 at 12:56 PM
    emelianenkov
    Alex
    NORTH POLE
    I'm just hoping I can limp my water heater along until I can recover a bit. My house has been mean to me this year. :pout:
  11. Feb 17, 2021 at 2:09 PM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Of course the bottom line is the rate they are charging you for delivery but it also helps to understand how they charge you. You will get charged more for the more peak demand that you use. It will cost you less to use the oven, dryer and electric heater separately rather than all at the same time as your peak demand for electricity will be less using each of those big items at a different time than all at once. It will also help if you can use big energy use items at other times when even lights or an active house is in effect. And they chart that demand over the entire month so you have to be quite diligent about your peak usage for the entire month in order to reduce the peak demand for your electrical bill.
    I work for a recreation department and we used to run into this all the time when people wanted to use the lights at a field. They would not understand why they were going to get charged $400 for electricity for a month for only 3 hours use or get charged $550 if they used it for 10 nights of 3 hour use. Peak usage would be the same for the month regardless of the amount of electricity used and regardless if they were using the lights for a one hour period or for 100 hours.
  12. Feb 17, 2021 at 2:29 PM
    js312
    Joe
    New England
    I always wondered how they determine this. My meter is just a typical dial meter and the bill has the old and new reading.
    Blackbeard83, Bridge4 and tacobell007 like this.
  13. Feb 17, 2021 at 3:14 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Don’t forget to check with your utility provider to see if there are rebates or other incentives to offset the cost of upgrading your water heater. I think i got either $400 or $500 back when I went w the heat exchange hot water heater :thumbsup:
  14. Feb 17, 2021 at 4:29 PM
    GarlicFarts
    Lil Rhody
    Dishwasher delay to run at 2 am is my usual. Not that I think it really matters much but whatever.
    often times a domestic setup isn’t set up for that they just charge a flat rate. A large scale commercial setup is setup for knowing draw and times for that sort of thing.
    CB update. Tuned. Ish. SWR 2.5 on 19 which isn’t great. But I will likely be doing 500000x more rx than tx right now anyway.
    I am going to order a new antenna cable and wiring stuff to wire direct to battery. I have some plans and will want to do them before the road trip (March 17th) but I need to switch my main focus onto the sleeping platform this weekend.
    my plan for those HF toolboxes might be dashed. I know I have a weird bump in the floor for the front seat mounts but I can’t tell if I have a damn floor vent or not. I thought I looked under there and didn’t but all the pictures I’m finding are showing them so I might just have that damn thing. If I do then I’ll have to likely set up just a wooden platform for support instead. Regardless this weekend as long as the weather plays nice I’ll be yanking my seats out and beginning that venture.
    Blackbeard83, tacobell007 and Pugga like this.
  15. Feb 17, 2021 at 5:04 PM
    ABA180
    East Bridgewater MA
    Houses, the gift that keeps on giving
    Different b/c it's a constant need, but I have my pool filter timed to run off peak time..works unless I have to vacuum
  16. Feb 17, 2021 at 5:17 PM
    js312
    Joe
    New England
    Makes sense. At least one of our larger buildings at work has a phone line on the electric meter that the electric company dials into to read it. I expect that gives them more information. I think that building has a 1600 amp service.
    Bridge4 likes this.
  17. Feb 17, 2021 at 5:29 PM
    jmferg
    jmferg Well-Known Member
    Interesting entrapment or some old trend of Supra-front-swapping celicas I’m unaware of ?
    Blackbeard83 and Pugga like this.
  18. Feb 17, 2021 at 5:30 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    The second one I'm pretty sure is from an internet article
  19. Feb 17, 2021 at 5:33 PM
    jmferg
    I assumed it was a scam by the license however the sellers profile is legitimate including, local workplace listed, history of items sold on marketplace, etc
  20. Feb 17, 2021 at 5:46 PM
    tacobell007
    Drew
    Western MA
    Yea i saw it posted near my parents zip, I dont know why people try and scam with legit facebooks on marketplace
