New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Feb 27, 2021 at 4:55 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I missed the flag piece, I see now what they’re doing.
    Interesting. It works, i’ve never seen a device like that. Living in MA, i’d be surprised if it were legal here.
    Bridge4 likes this.
  2. Feb 27, 2021 at 5:03 PM
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    I never seen it before either. I already bought the switch panel and just never got around to installing it but I might go this route instead.
  3. Feb 27, 2021 at 5:04 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    That way of feeding the panel from a generator technically allows you to power any circuit but... you still need a meter for each pole so that you don’t overload one side of the generator. Honestly, a transfer switch is simple and they usually have meters on them. Not to mention, the circuits that one would use during a power outage probably won’t change. It’s not like a ‘standard’ size generator is going to power central AC, electric dryer, etc... Typically, it’s the boiler or furnace, well pump (if one has a well), refrigerator, kitchen outlets, etc...
  4. Feb 27, 2021 at 5:06 PM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Cool system. It works, probably was the easiest way to set it up. My in laws have an automated whole house switch. So if the power goes out it’s only for about 30 seconds while the switch flips and the generator kicks on. They buried a 500 (300? Big bastard) gallon propane tank. Right now the only thing that runs on propane is that generator. Slick setup. Overkill, but when the power goes out they’re all set to go probably for a month I’d say, depending on the weather. I’m planning something much smaller scale and much more manually controlled.
  5. Feb 27, 2021 at 5:07 PM
    GarlicFarts
    Lil Rhody
    Yup. It works and it might be the simplest or cheapest setup but it’s not the best.
  6. Feb 27, 2021 at 5:13 PM
    williams63
    chili
    nh
    2011 dblcb
    When I first moved up here to NH we lost power enough that I bought a generator. Paid for itself December 11 2008.
  7. Feb 27, 2021 at 5:32 PM
    NukedTaco
    NukedTaco Well-Known Member
    Wyatt
    Saratoga Springs, NY
    This is pretty neat. I’ve only ever seen interlocks/mbt’s like this on submarines for loads with redundant power supplies, never in a residential application.
  8. Feb 27, 2021 at 8:48 PM
    Fitzwilly
    Fitzwilly Well-Known Member
    Bill
    South Central Mass
    2018 JKU "Golden Eagle" Edition
    This; literally all we chose was boiler, fridge/freezer, well pump and some lights/ outlets
  9. Feb 28, 2021 at 2:56 AM
    Bridge4
    Bridge4 Well-Known Member
    MA
    2003 DCSB Imperial Jade
    Ordered my generator a few weeks ago, luckily before the TX storm added even more time to the delay, 18kw and I plan on powering my entire house or close. I'll get a 250 gallon propane put next to it, should last about 3 days of full time use according to the generator specs. I would consider a larger tank but I live on a highway and my line is the school/townhall/library, we get fixed quickly. I think 24 hours is the longest its been out here
    Ordered a few weeks ago but isn't supposed to get here until April.
    We have two at our business. One for the main building we just got used, $2500 for a 25kw! It will do our 3 a/c systems and the music/fridges for our weddings. We previously had a national guard diesel manual connect the town fire department lent us. It wouldn't send the power TO the building though, and the part cost almost as much as the "new" automatic generator. Then we have a smaller 16kw that runs our fire pump system, kitchen and bridal suite. They also stop the never ending phone calls and alarms when the power goes from said fire system, which mentally pay for itself fast
    I think after my tank gets added, we will have 3k gallons of propane storage between it all. For the business it makes a lot of sense, because well, its our business and a 150 degree room, or a cold dinner would ruin the night and hurt us a lot. Our personal set up has been delayed a few years now because it isn't super necessary, and it is super expensive, at least how I want mine set. With the baby though and not wanting to deal with power outtage+baby, it was time.
  10. Feb 28, 2021 at 3:18 AM
    Fitzwilly
    Bill
    South Central Mass
    When we lived in NH we had a 100Gal propane tank but it was tough to fill/transport since you’re not supposed to lay it down. That went with the house when it was sold. i got dual fuel for the house here in Upton. Typically keep 2 20# tanks and 2 5gal gas cans on reserve as we can get about 2-3 days out of that for essentials. We’re right off 140 and get our feed from Grafton so restoration usually doesn’t take much longer than a day or two.
    tacobell007, emelianenkov and Bridge4 like this.
  11. Feb 28, 2021 at 4:53 AM
    GarlicFarts
    Lil Rhody
    anything above a 20/30 gallon tank just call for delivery. My house growing up had a pair of 120 gallon tanks, we just got delivery. But we were also not in the sticks so delivery was an option.
    tacobell007 and Bridge4 like this.
  12. Feb 28, 2021 at 6:00 AM
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    My 40 gallon electric water heater was going cold quick I suspected the anode was ng . Called my nephew who’s a plumber and he tested everything. Took a look at the rod and it was junk. $23 later and I now have crazy hot water with new anode. Also flush it yearly .
  13. Feb 28, 2021 at 6:05 AM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    got this in the mail Friday. Much too late to plan for this . Bummed because fishing is great there
  14. Feb 28, 2021 at 7:22 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Must have been sent expedited
  15. Feb 28, 2021 at 9:00 AM
    DoubleRGirl
    DoubleRGirl Hello Kitty Edition
    Rebecca
    Rhode Island
    2015 DCSB TRD Sport 6speed
    Thanks @Bridge4 they fit perfect. I just have to get new hook thingies (I forget what my husband was calling them), they were a little bit too long. Hopefully find another dog bed the same size for Lilly
  16. Feb 28, 2021 at 10:40 AM
    Bridge4
    MA
    Awesome glad it worked out how I imagined it! I think the guy who made it had an idea that those hooks go to the tie downs back there? Once you get a new dog bed they will have an A+ view out the windows!
  17. Feb 28, 2021 at 10:45 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    emelianenkov, Pugga and Bridge4 like this.
  18. Feb 28, 2021 at 11:30 AM
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Satoshi grill, 3rd Gen TRDOR Bucket Seats, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, LCE Balance Shaft Delete, ECGS front diff bushing, TRD Sport LSD rear diff, Diode Dynamics SS3 Sport fog lights, Stainless Steel Brake-lines, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, Bilstein 8112 front Coilovers w/ rear Bilstein 5125's/IronMan lift leaf springs, Archive Garage Hammer Hangers, JBAs HD UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, 2019 Steering wheel, color matched door handles
    tacobell007 likes this.
  19. Feb 28, 2021 at 12:40 PM
    DoubleRGirl
    Rebecca
    Rhode Island
    Yeah they were just a tiny bit too long to stay put. We grabbed some at Lowe’s that should work
    the dog bed is exactly the same dimensions as one drawer. Crossing my fingers we can find a second one
    Bridge4[QUOTED] likes this.
  20. Feb 28, 2021 at 12:43 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    The one I have is slightly dinged and scratched up.
