New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. May 3, 2021 at 4:48 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Yeah, saw that this morning. That guy is a bad ass. I don't think I would have got out at the end either. Gun or no gun, I'd need a change of shorts. I've been around guns all my life but never shot at. That's next level fear.
    Bridge4 likes this.
  2. May 3, 2021 at 5:11 PM
    Bridge4
    Bridge4 Well-Known Member
    MA
    2003 DCSB Imperial Jade
    Same. I can talk tough but that situation would be a real reality check one way or another :rofl:
    AllTacosFloat[QUOTED] likes this.
  3. May 3, 2021 at 8:29 PM
    88seriesiii
    88seriesiii Well-Known Member
    2007 Access Cab 4x4 TRD Off Road 6cyl MT
    OEM with ARE CAP
    Nice looking Rover.. I think I've seen that one on the road in Southern Maine
    Bridge4 likes this.
  4. May 4, 2021 at 4:45 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Morning, y'alls bitches!
    If any of you have pools, better stock up on chlorine! News had a big story on shortage and 70% higher prices!
    Someone is reading the back in time machine.
    Bridge4 and GarlicFarts like this.
  5. May 4, 2021 at 4:54 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Hell, I heard that even the pools are backordered at this point :laugh:
  6. May 4, 2021 at 5:37 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    I do not endorse this decision. Sacrificing perfectly usable space for a gym is the way.
    GarlicFarts likes this.
  7. May 4, 2021 at 5:41 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    That and hot tubs have been this whole nonsense. My FIL needed to get his hot tub serviced because it wasn't heating the water. He called in late Jan, early Feb. The earliest he could get a service appointment was late June. I just ended up picking up a heating element and pretended I knew what I was doing (thanks youtube) and replaced it. Actually pretty easy and quick.
    Bridge4, Spare Parts and GarlicFarts like this.
  8. May 4, 2021 at 5:58 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I feel like there are a lot of things like that. They seem difficult on the surface, and the techs that perform the work make it sound like it's something overly complicated, but once you dig in, it's not too bad and you can tackle most projects with just a basic tool set, some common sense and YouTube.
  9. May 4, 2021 at 6:13 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    I can't remember what it is - might be lambo or ferarri, shockingly. But they have an oil change cannister - basically you pop the hood, pull a box, and put a new box in. Oil and filter and everything is all contained in there. Pop out, pop in. Easy. I'm sure it's like a grand to do, BUT yeah a lot of stuff is easy unbolt, rebolt, done.
    Bridge4 likes this.
  10. May 4, 2021 at 6:30 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    98.9725% of people who own those makes are not doing any DIY maintenance.
  11. May 4, 2021 at 6:54 AM
    Noelie84
    Noel
    Wales, Maine
    Yeah, sounds about right. Our neighbors just got a new saltwater hot tub delivered & set up about a month ago, but they'd actually ordered it last summer :laugh:
    Bridge4 and Sloth[QUOTED] like this.
  12. May 4, 2021 at 6:59 AM
    jethro
    Geoff
    Southern NH
    So apparently the Ford 5.0L motors in '18, '19 and '20 have oil consumption problems. I am at 20% oil life remaining and decided to check it... fucking thing is down so much it barely reads on the stick. I checked it when I picked it up a few months ago and it seemed normal. So I guess I have another truck with issues.
    Bridge4 likes this.
  13. May 4, 2021 at 7:02 AM
    GarlicFarts
    Lil Rhody
    https://www.carcomplaints.com/news/...gedly be,catalytic converters and spark plugs.
    That one is kind of well known. Initially it sounded like the oil was escaping through the piston rings because they went from cast to insert or something like that. At first they were just replacing the entire engine blocks. But now they supposedly sorted it out as attributed to the timing of the valves or something like that. A reflash of programming on the service bulletin and you're good to go, I would do an oil + filter change (have the dealer do it) accompanying that, and then good to go.
    Bridge4 likes this.
  14. May 4, 2021 at 7:06 AM
    Pugga
    Massachusetts
    I still have a catch can from my 5.0, do you want it? I was getting some oil coming from the CCV. The vent is apparently right above one of the cam chains so you'd get oil sling being pushed right out through the vent and fed into the intake. I wasn't catching a lot of oil, but I bought the catch can as a piece of mind sort of thing. If the engine design hasn't changed, the can I bought was a nice one and had Ford ends on the hoses and the can itself has a drain valve in the bottom, plus it's easy to unscrew. It was like $200 when I bought it but I don't have a use for it anymore.
    Bridge4 likes this.
  15. May 4, 2021 at 7:15 AM
    jethro
    Geoff
    Southern NH
    I'll have to see what it looks like in there, I appreciate that. Let me see what the dealer does about it first, I guess the TSB is a longer dipstick and a re-flash like Garlic said.
    Pugga[QUOTED] and Bridge4 like this.
  16. May 4, 2021 at 7:26 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    A longer dipstick...so you can just read the lower oil level as higher than it actually is.....?:bananadead:
    Spare Parts, Pugga and Bridge4 like this.
  17. May 4, 2021 at 7:27 AM
    jethro
    Geoff
    Southern NH
    I know, is that hilarious or what?
    Spare Parts and Bridge4 like this.
  18. May 4, 2021 at 7:28 AM
    GarlicFarts
    Lil Rhody
    Yeah that one was kind of funny to read. It's similar to the Tacoma diff howl.
    At first - rip it apart, replacing diffs.
    Now.... "That's normal, deal with it bitch"
  19. May 4, 2021 at 7:29 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    I mean it sort of is in a half-assed kind of way. Que in 5 years a slew of Fords with scarred cylinders...
    Pugga likes this.
  20. May 4, 2021 at 8:01 AM
    jethro
    Geoff
    Southern NH
    They don't care. Probably their strategy to sell a bunch of Powerboost engines by then.
    Bridge4 likes this.
