New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Aug 22, 2021 at 1:52 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If there were trees down in central MA, i`m glad we left our camping spot early. We were around a lot of big trees.
  2. Aug 22, 2021 at 2:11 PM
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    Question for y’all, especially those with experience with POR-15 and WoolWax. My uncles 04 Tacoma has some issues where the gram has rotted through. His mechanic ended up welding some plates on the side that was completely shot, but the other side isn’t so bad. What’s the best way to go about it getting any worse?
    should I just be scraping all the loose stuff off and adding woolwax, or should I apply POR15 first, let it dry, then add woolwax on top?
    jpereira2 likes this.
  3. Aug 22, 2021 at 2:42 PM
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    Found this rubber bushing on the driver's floor while doing my brakes this afternoon. Anyone know where it might have come from?
  4. Aug 22, 2021 at 2:51 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I’ve used POR-15 quite a few times on different vehicles. Prep is key. I’d use the metal prep zinc phosphate spray per the directions and then paint with POR-15. If there are any voids in the paint, moisture will get trapped behind it causing rust to grow. It’s a bear to get off if you have to remove it. When you buy the can, don’t open it. Turn it on it’s side and put in a small hole near the top so that you can use a sheet metal screw to seal the can. Put what you need in a container and seal the can with the screw. Opening the can guarantees it will harden even if you put plastic film over it. Then spray with your favorite rust inhibitor. I prefer Amsoil HD metal protect as it’s a waxy film but others work just as well. If you can, coat both sides of the area (inside of the frame if it applies). BTW - nothing removes POR-15 from skin other than time. Don’t ask… :rolleyes:
  5. Aug 22, 2021 at 2:56 PM
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    Not the biggest fan of POR...
    I prefer rust bullet....
    I use that, and go from there.
    In fact, I will be doing some of that with my latest... project.
    CttAznRanger[QUOTED] likes this.
  6. Aug 22, 2021 at 3:07 PM
    Chasespeed
    In the woods...
    2018 TRD OffRoad
    Some stuff
    On another note, what did I miss?
    I've been embroiled in chaos the last....few weeks.... if not longer... I know no one is surprised anymore when I'm not online....
    On another note.... I sold one of my trucks.... and a bike...:annoyed:
    Thinning the herd I guess...besides ,, $ talks
    crashngiggles, Pugga and Bridge4 like this.
  7. Aug 22, 2021 at 3:17 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Prep is key. I would use a needle gun then a wire wheel or cup grinder, wire brush then clean it, let it dry use the por 15 then wool wax
  8. Aug 22, 2021 at 4:50 PM
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Satoshi grill, 3rd Gen TRDOR Bucket Seats, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, LCE Balance Shaft Delete, ECGS front diff bushing, TRD Sport LSD rear diff, Diode Dynamics SS3 Sport fog lights, Stainless Steel Brake-lines, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, Bilstein 8112 front Coilovers w/ rear Bilstein 5125's/IronMan lift leaf springs, Archive Garage Hammer Hangers, JBAs HD UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, 2019 Steering wheel, color matched door handles
    I am with @Chasespeed on POR-15, me and father have used it on his older Tundra, and it did NOT work, even though we followed the directions to a t. We have had much better luck with cans of Rustoleum Rust Reformer, and either top coating it with some other spray paint (usually the Professional Rustoleum, in the tall silver cans), or what you plan on doing, WoolWax.
  9. Aug 22, 2021 at 5:33 PM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    I'm a fan of rattle cans and rustoleum. Sand and wire brush as clean as possible, wipe down with degreasor or alcohol and go to town with paint. Let dry for a day or two then coat with woolwax
  10. Aug 22, 2021 at 5:35 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    I'm just East of upton in Hopkinton, and we got basically nothing. Some rain, barely any wind. I am disappointed, what happened to this crazy biblical storms all the dumbass talking heads told us to prepare for!
    Pugga[QUOTED] and Bridge4 like this.
  11. Aug 22, 2021 at 6:09 PM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Providence - a lot of rain and medium branches. Nothing big, no power loss. I didn’t have my radio on today so not sure if the southern part of the state got it worse along the coast though.
    work already sent out the mass text - we’re on for tomorrow :rofl:
    trash pickup got moved by a day though. Means mowing the law Wednesday so I can bag it and not have it sitting around for a few days. … means mowing on the hot day of the week :D that will be fun.
  12. Aug 22, 2021 at 10:42 PM
    Fitzwilly
    Fitzwilly Well-Known Member
    Bill
    South Central Mass
    2018 JKU "Golden Eagle" Edition
    we had a couple trees come down on our property right off 140 on the Upton/Grafton line. FWIW we’re heavily wooded and they were very wet. One uprooted, another snapped off about halfway up. Wind didn’t seem like it was that bad but we were hearing crackling and creaking all day.
  13. Aug 23, 2021 at 2:43 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
  14. Aug 23, 2021 at 5:43 AM
    steelcity2
    steelcity2 Well-Known Member
    Pittsburgh Pa
    2013 MGM DCSB TRD sport
    Bilsteins 5100's all 4 corners 1 inch rear spacer
    Hey there NE brothers, hope you all are OK from henri, after watching the news and seeing the flooding and outages makes me sick. Hang in there guys. :wave:
    jpereira2 and mach1man001[OP] like this.
  15. Aug 23, 2021 at 6:05 AM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    In eastern MA there wasn't a lot of damage. Central MA got more, but not really horrible from what I've seen. Henri over promised, but under delivered.
    steelcity2[QUOTED] likes this.
  16. Aug 23, 2021 at 6:06 AM
    GarlicFarts
    Lil Rhody
    this was the extent of it for me down here. This was even in the neighbors yard. We didn’t get anything. I’m in providence.
  17. Aug 23, 2021 at 6:12 AM
    steelcity2
    Pittsburgh Pa
    Thank god that was it. Seems terrible in some of those news clips.
  18. Aug 23, 2021 at 6:19 AM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    jpereira2 and steelcity2 like this.
  19. Aug 23, 2021 at 6:23 AM
    Pugga
    Massachusetts
    That's what the news outlets do. We get our share of storms that actually do damage houses and roads, but the news generally blow it out of proportion. They find a really windy area on the coast or the area with the worst drainage to film so yeah, it sucks for the people in that exact spot, but it's generally not nearly as bad as they make it out to be.
    HisDad, Sloth, Bruce988jl and 2 others like this.
  20. Aug 23, 2021 at 6:26 AM
    GarlicFarts
    Lil Rhody
    I had everything charged up ready to go, had a bunch of ice in the freezer ready to get the coolers going if needed to preserve it all. Now I have a bunch of ice. No idea what to do with it.
    That's a lie. Frozen rum runners.
    Yeah he already hit the nail here ^^^ sensationalized.
