New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Sep 18, 2021 at 1:36 PM
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Satoshi grill, 3rd Gen TRDOR Bucket Seats, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, LCE Balance Shaft Delete, ECGS front diff bushing, TRD Sport LSD rear diff, Diode Dynamics SS3 Sport fog lights, Stainless Steel Brake-lines, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, Bilstein 8112 front Coilovers w/ rear Bilstein 5125's/IronMan lift leaf springs, Archive Garage Hammer Hangers, JBAs HD UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, 2019 Steering wheel, color matched door handles
    If you need to, I modified the stock bump stops to fit onto the u-bolt flip kit I bought, granted they might not be tall enough, but at least they are there.
    Brownmatthall[QUOTED] likes this.
  2. Sep 18, 2021 at 1:55 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Buy beads and when you have your tires mounted they pour them in for you instead of balancing.
    tacobell007 and GarlicFarts like this.
  3. Sep 18, 2021 at 1:58 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    And the longer valve stems
  4. Sep 18, 2021 at 1:59 PM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    Got my stainless brake lines on. Ordered pads and rotors and even though it's not sure the rest from parts as well. Now I need brake fluid and some oem calipers. Shopping around for prices
  5. Sep 18, 2021 at 2:01 PM
    AllTacosFloat
    Boston ish
    I believe the tire shops/ mechanic has them. Don't quote me on it cause I've never done it. I just know they keep some valve stems in stock
  6. Sep 18, 2021 at 2:05 PM
    AllTacosFloat
    Boston ish
    Napa has reman OEM usually in stock. I'm doing my front with stainless tomorrow. Just got home with fluid.
    jpereira2[QUOTED] likes this.
  7. Sep 18, 2021 at 2:22 PM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Rockauto is my go-to. Some of the "modified" stuff (lifts etc) isn't in there but almost everything oem is. Mine is a 2020 so for a bit there I didn't have everything in there for oem would have to go back to 2017s because the 2018s had the radar BS so they counted them differently even though brakes for example were the same. Seems that for 2020s at least they're pretty caught up.
    tacobell007 likes this.
  8. Sep 18, 2021 at 2:59 PM
    jpereira2
    Massachusetts
    I checked but didn't see oem
  9. Sep 18, 2021 at 3:14 PM
    AllTacosFloat
    Boston ish
  10. Sep 18, 2021 at 3:27 PM
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    I need to pull my plates, drill and tap... but, need to make a choice of brand first.... and need to do it kinda soon...
    Curious how you did that?
    I still have my Tacoma! Just not online much... once it gets colder and I can't stand to be outside, I'll be back to annoy everyone consistently....
  11. Sep 18, 2021 at 6:18 PM
    nickonfire700
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    It has been awhile since I put them in, but I cut off the ends where the stock u-bolt holds on to the bump stop, and then drilled holes (in the metal of the bump stop) that lined up with tapped holes in the flip kit plate.
    I honestly didn't think about bump stops when I bought the kit (I bought it brand new in box from another member that was going in a different direction with their truck), and it was the quickest/cheapest way to keep bump stops on the truck.
  12. Sep 18, 2021 at 6:34 PM
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    Might go that route, do I really risk bottoming out 5160s with stockers?
  13. Sep 18, 2021 at 8:01 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    My opinion, I currently run 11" travel shocks without issue with the stock bumps. Going to a 14" travel shock inboard setup for crawling though
  14. Sep 19, 2021 at 11:03 AM
    Fitzwilly
    Fitzwilly Well-Known Member
    Bill
    South Central Mass
    2018 JKU "Golden Eagle" Edition
    Multi tasking today, need to get a permanent tv to swing away mount to the garage wall
  15. Sep 19, 2021 at 5:17 PM
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    Finally got around to installing some Rigid floodlights in the back bumper. Hooked them up with a SPDT switch and relayed through my Bussman fuse block. They can be always off, on with the factory reverse lights, or continuously on if the parking lights are on.
  16. Sep 19, 2021 at 5:40 PM
    Fitzwilly
    Bill
    South Central Mass
    looks great
    i was thinking about ordering some diode dynamic ssc1 or Baja design s1’s to flush mount to the bumper in a similar fashion, factory reverse and from the switchpro.
    I have the meso hitchpod that taps the factory reverse but I wanted to go a step further with manual control.
  17. Sep 19, 2021 at 6:10 PM
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    92CF5841-1F68-49FA-B69A-D0B2FA2ACA7E.jpg C324533F-EC72-4AAE-A746-8ABF1E6C6733.jpg
    All done. Need two more hangers up front, but it’s all lined up, bolted in, and sounds very subdued. So quiet, compared to my old exhaust at least.
  18. Sep 20, 2021 at 4:34 AM
    BadDNA
    Eammon
    Cabot, VT
    The manual control is where it's at. I'm no electrical engineer, so it took me a bit to figure out how to make it work, but I got it.
  19. Sep 20, 2021 at 5:24 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I really like the way you set them up. I had my forward lights wired up similarly. DPDT switch that could be off, on with high beams or manually turned on whenever the ignition is on. Eventually, I'll get around to rear facing lights wired up the same way you did, but I haven't found a mounting solution that I like.
    GarlicFarts likes this.
  20. Sep 20, 2021 at 5:30 AM
    GarlicFarts
    Lil Rhody
    That's the way to go - I might do that with my ditch lights, on off or on with highbeams. But, at least for those I might just leave it on as normal. Might get an auxbeam controller TBD
