New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Oct 20, 2021 at 11:15 AM
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    There's a lot of truth to this. I have used FluidFilm on my '15 truck since new, and just had the frame inspection/CRC coating done a couple of weeks ago. The areas where they cleaned off the frame as part of that service look brand new. Now to get back under there soon and load it up with FluidFilm again...
  2. Oct 20, 2021 at 11:45 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    boston23 likes this.
  3. Oct 20, 2021 at 5:46 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I just ordered another gallon of FF that I'm going to pick up tomorrow morning at Advance. Tomorrow is FF day for me. I probably have enough laying around to do my truck, but I load up, so I don't want to run out.
    I hate FF date, I truly do. It's SO, SO worth it, but I loathe the days I do it. I actually have some rust on my LCAs where the paint chipped off the welds and the water spray removed the FF, so I'll go do that, but ultimately those unbolt so I'm not nearly as stressed. I'll have to see what I can do with the new boxed blocking plates. There's a hole in the center as well as other areas to get into the box section, I think, but Toyota never sprayed in the box section on me, just the covers, so I'm good.
    @jpereira2 does the 360° wand fit in that hole? I've got the 18" one from my FF kit. One of these days I'll swap over to WoolWax, but for now I like my setup.
    I need to cut and buff some scratches out of my winter wheels as I'll probably change those over the first week of November or so. Hopefully I've finally cured my wheel addiction and can live what I've got for awhile.
    Also, FWIW and I've mentioned this before, I've got an ATEQ Quickset X so I can program OEM TPMS sensors for anyone that needs sensors programmed in if you've done a rotate on a 3G truck and want the placement right, or if you've got snows with TPMS like I do.
    MaineFarmer, boston23 and ABA180 like this.
  4. Oct 20, 2021 at 5:55 PM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    I may come to you re TPMS after the winter. I will be swapping to a new set of wheels and will be doing a mix of rotating and a 6 wheel rotation so I'll need to learn how to do that too. I need to get a USB and techstream to recal the airbags so if I can do it in there I'll be good with that too.
  5. Oct 20, 2021 at 5:57 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    I believe my device will capture the sensor ID, so if you get Techstream up and working you won't need to go through me after you have the sensor IDs. The only thing about my device is that it's specified to only work with OEM TPMS, so I don't know if it will read non-OEM (if that's even an issue with you).
  6. Oct 20, 2021 at 6:30 PM
    nhpoke
    nhpoke Well-Known Member
    jason
    nh
    21 DCLB OR AG
    I have an ATEQ VT36, which can definitely read the OEM sensors on my 21.
    It also cannot reprogram the ATUL MX "universal" sensors (I have tried every setting).
    If you need your OEM Sensor ID's read I can help.
    If you need some of the other common (not ATUL) sensors cloned, I can help.
    If you message me with your year / wheel type I can reply with what aftermarket sensors can be programmed / reprogrammed with this tool.
    I have a Schrader EZ Sensor inbound to verify that I can reprogram it with my OEM sensor ID, but it could be a few days before it arrives and I can verify things. They go for $25-$30 in places I've looked.
    SR-71A likes this.
  7. Oct 20, 2021 at 6:55 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    When Toyota did yours, did they use the white/beige fill type stuff or an actual black liquid? And remind me roughly when yours was done by them..
  8. Oct 20, 2021 at 7:09 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Nothing. They skipped the spray and just did the plugs since I FF’d everything. I did it 12/2020. I got it in writing that skipping the spray was approved by Toyota and I still got the warranty. In the Owner’s Portal K0D says it’s done.
    jpereira2 likes this.
  9. Oct 20, 2021 at 7:10 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Yes the 360° wand fits in the hole lol
  10. Oct 20, 2021 at 7:14 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
  11. Oct 20, 2021 at 8:11 PM
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    I would really like to do this to mine. I’m in Nashua on the Tyngsboro line and I’m not sure how far I am to the closest member that does this. I have a compressor but no undercoating gun or even a 360° Wand as mentioned. What is the charge for this? I would even provide a gallon just for the help and leave the rest . I can’t imagine my frame would take a whole gallon or will it? Maybe overthinking?
    AllTacosFloat likes this.
  12. Oct 20, 2021 at 10:08 PM
    ABA180
    East Bridgewater MA
    I didn't have plugs, but 2g to 3g of course..
  13. Oct 21, 2021 at 2:08 AM
    tacobell007
    Drew
    Western MA
    Youre probably closer to @jpereira2 than you are to me, i use to work on Nashua in that area though. I think Jason was charging $75 for tacomas this season, and no you wont need a whole gallon for a Tacoma, my dads double cab long bed 3rd gen I put over 2 of the quart botles on, but thats all over the frame and the underside of the cab
  14. Oct 21, 2021 at 2:59 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Definitely do it! I'd pay because it kinda sucks. Both guys that do it in the area are top notch and meticulous. I trust either of them with my truck. The ride out west isn't bad(I'm in n Chelmsford) I'd go to either based on availability.
  15. Oct 21, 2021 at 3:34 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    You can get it in spray cans as well. I still have a fluid film kit (gallon, spray jar and wand) that I got a couple years ago, but never got the compressor. I have also read about some one using a paint sprayer and thought about going that route.
    Pibbles99[QUOTED] likes this.
  16. Oct 21, 2021 at 3:44 AM
    Pugga
    Massachusetts
    I think there was a YouTube video of a guy using a paint sprayer. He was warming it slightly to keep the viscosity low enough so it wouldn't muck up the sprayer.
  17. Oct 21, 2021 at 6:03 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    You can absolutely use a paint sprayer. But that will not work for the hose/wand
  18. Oct 21, 2021 at 7:04 AM
    zjcas
    zjcas Well-Known Member
    Zach
    Hooksett
    2012 DCSB TRD Sport
    Fox 2.0 COs, Fox 2.0 Resi's, Wheeler's Prog. AAL.
    Some big news for my online acquaintances here. I've done probably the only 2 spontaneous things in my entire life in the last month. First being that a few weeks ago I ended up trading in my Tacoma for an Outback Wilderness (the only new car I've ever bought), the second being I just accepted a pro hockey AT job with the Charlotte Checkers, the AHL affiliate of the Panthers. I finish up here at Plymouth State mid-November and tentatively report the 20th in NC. This will be my first time living outside New England and still doesn't really feel real even though it's been a couple weeks in the making.
  19. Oct 21, 2021 at 7:12 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Congratulations! That sounds like fun!
    You should have kept the Tacoma though! What were you thinking!!! :der: Lol
  20. Oct 21, 2021 at 7:20 AM
    zjcas
    Zach
    Hooksett
    2012 DCSB TRD Sport
    Thanks Rob! My original plan was to keep it and still get something for my commute but for right now the only thing I truly used my truck for was hauling my kayak. I'll get back in one one day probably but hey from how I've seen things work here on TW, I'm on the right track to becoming a mod, always ditch the tacoma first then you can be in charge! (Says the guy who is fairly inactive on here :notsure:)
