New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Nov 2, 2021 at 3:08 PM
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    I may want wheel spacers, and eventually wanna try out those kenda skinny 35s. Again, future-proofing for my inevitable stupidity :D
  2. Nov 2, 2021 at 3:40 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    My 1.5 inch spacers make my 265’s rub pretty bad :D
    and yeah those kenda’s look interesting! I forget how heavy they are
    Brownmatthall likes this.
  3. Nov 2, 2021 at 4:05 PM
    Brownmatthall
    2016 TRD OR DCSB
    I wanna say in the 60s, definitely on the heavier side
  4. Nov 2, 2021 at 4:42 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    My mastercraft 35x12.5x17s are 65lbs each if I remember right and they were on the lighter side for 35s
  5. Nov 2, 2021 at 4:47 PM
    Brownmatthall
    2016 TRD OR DCSB
    Yeah just checked and they're 66 a pop
  6. Nov 2, 2021 at 5:00 PM
    tacobell007
    Drew
    Western MA
    General tires are heavy, my mastercrafts were only a pound heavier than my load range C grabber AT2s, and my MXTs are a load range E. Grabber X3s in the same size are 77lbs each
    GarlicFarts likes this.
  7. Nov 2, 2021 at 5:11 PM
    Brownmatthall
    2016 TRD OR DCSB
    Yeah, now that I'm really thinking about it mid 60s isn't bad at all
    tacobell007[QUOTED] likes this.
  8. Nov 2, 2021 at 5:46 PM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Rogers tire in Woonsocket is very well known for doing a great job for alignments.
  9. Nov 2, 2021 at 5:52 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Cab chop and shims should only be done if needed. The wider the wheel the more likely you will need to trim/chop.
  10. Nov 2, 2021 at 5:54 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
  11. Nov 2, 2021 at 5:59 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
  12. Nov 2, 2021 at 6:21 PM
    MikeWa86
    MikeWa86 Member
    Father in law has one. Used it one season when he had a knee replacement to clean up his yard 1 acre. I liked it more than a Dr my grandfather and I had on 2 acres years ago. Does a good job and mulches well, stores easy. Just another small engine to maintain.
    This is what I use now. Im currently on 1/2 acre against conservation land. Wind blows my direction. I use mulching or bagging blades on my 42” Deere and it’s SO MUCH EASIER than the 2-bagger. Lot more leaves per dump especially with the mulching blades. It “floats”over the grass but drags when it gets full/heavy obviously. If you’re 2 acres look at the “tough” version it may hold up better in the long run.
    Bruce988jl and Fitzwilly[QUOTED] like this.
  13. Nov 2, 2021 at 6:34 PM
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Satoshi grill, 3rd Gen TRDOR Bucket Seats, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, LCE Balance Shaft Delete, ECGS front diff bushing, TRD Sport LSD rear diff, Diode Dynamics SS3 Sport fog lights, Stainless Steel Brake-lines, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, Bilstein 8112 front Coilovers w/ rear Bilstein 5125's/IronMan lift leaf springs, Archive Garage Hammer Hangers, JBAs HD UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, 2019 Steering wheel, color matched door handles
    Yup, I was going to say the same thing, but they are not open on Sundays :(.
  14. Nov 2, 2021 at 7:00 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Does anyone know what these things are? I've been seeing them pop up here in Providence.
  15. Nov 2, 2021 at 7:02 PM
    Fitzwilly
    Fitzwilly Well-Known Member
    Bill
    South Central Mass
    2018 JKU "Golden Eagle" Edition
    looks like big brother…
    Pibbles99 likes this.
  16. Nov 2, 2021 at 7:07 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    Eye in the sky. I see them in lots of home dump and Lowe's parking lots
  17. Nov 2, 2021 at 7:08 PM
    MikeWa86
    MikeWa86 Member
    Yeah looks like mobile surveillance setup. Is this near a mall or venue? Some event coming up nearby? That’s where I’ve seen them especially around holidays
  18. Nov 2, 2021 at 7:10 PM
    jsnow77
    jsnow77 Well-Known Member
    Jake
    New Hampshire
    2022 Limited Nightshade
    Yeah looks like the eye in the sky. I've seen them around the UNH tailgates.
  19. Nov 2, 2021 at 7:15 PM
    replica9000
    2019 T4R ORP
    The first one I saw was at a Lowes, this one was at a Walmart.
    I just looked it up. I guess it's "lot cop" for security.
  20. Nov 3, 2021 at 8:19 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    we may have to have a little chat about your "aggressiveness" when it comes down to you are "daily driver" LOL...... trust me, doing things in small stages, will help you overall. Just ask yourself, is my truck paid off yet? If the answer is no, you might want to think about slowly dialing it back a little bit....lol. J/K..... Go balls to the wall kid!!!
    Brownmatthall[QUOTED] likes this.
