New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Nov 9, 2021 at 7:18 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    2 bolts, 5 min.
    tacobell007 likes this.
  2. Nov 9, 2021 at 7:33 AM
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    OME kit good?
    AllTacosFloat[QUOTED] likes this.
  3. Nov 9, 2021 at 7:35 AM
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    At the end of the day, they're all just chunks of metal with a hole through them. You could accomplish the same thing with a longer bolt and a stack of washers. I've got the OME CB drop sitting in my garage somewhere, if you're not in a rush, I'll send it to you for free.
    tacobell007 and AllTacosFloat like this.
  4. Nov 9, 2021 at 8:28 AM
    Brownmatthall
    2016 TRD OR DCSB
    I'm thinking I should fix it before it breaks worse lol, at least it's only 15 bucks. Thanks though! :thumbsup:
    BadDNA[QUOTED] likes this.
  5. Nov 9, 2021 at 8:42 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    No, I get that. But you realistically want the tranny flange and the diff flange to be parallel and all angles through u-joints to be as small as possible. Dropping the carrier I thought only accomplishes making the angle between the transfer case and the carrier worse and doesn't really do anything in the way of vibrations since you aren't messing with any of the flange angles. It would help if you're lifted a long ways because you create a steep angle between the carrier and the rear axle but I thought for moderate lifts the carrier drop doesn't do much. I could be wrong, it's been a long time since I've had a Tacoma...
  6. Nov 9, 2021 at 8:43 AM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    Go for the whole arm. It's a pain in the ass to press out the old one.
  7. Nov 9, 2021 at 8:49 AM
    Pugga
    Massachusetts
    It can be a complete pain in the dick to get the lower arm out if the bolts rust together also... Ask me how I know... Right @johnnym and @mach1man001 ?
  8. Nov 9, 2021 at 8:50 AM
    AllTacosFloat
    Boston ish
    You're absolutely right. We installed new leaf springs that gave lift in the rear thereby lowering the rear diff in relation to the transfer case. So the carrier bearing ( u-joint) angle changed. Being recently lifted I would suspect vibes do the the carrier bearing over u-joints going bad but I could be wrong. Happens daily
    Pugga[QUOTED] likes this.
  9. Nov 9, 2021 at 8:53 AM
    BadDNA
    Eammon
    Cabot, VT
    The big caveat here though, is that if your alignment cams are seized, you're in for a a bit more fun, you can cut the old ones out to remove the LCA as long as you have replacements on hand, and either way you're definitely going to want an alignment afterward.
  10. Nov 9, 2021 at 9:02 AM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    This is why I rip my LCA's out every year just to make sure the cam hardware doesn't seize. I never want to have to cut them out again - that was horrible....
  11. Nov 9, 2021 at 9:50 AM
    Pugga
    Massachusetts
    Yep, horrible experience and an absolutely stupid setup, in my opinion.
  12. Nov 9, 2021 at 10:12 AM
    emelianenkov
    Alex
    NORTH POLE
    Oh it's nightmarish. I cut the stock ones off of my FJ when I did my LT.
    I have the SPC alignment bolt kit to keep things moving freely. So far, they've been in since 2017 and I can still align it with ease.
  13. Nov 9, 2021 at 11:09 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    @Brownmatthall , yup, what you appear to be experiencing is driveline angle vibe. That is due to us lifting the rear with your new (Frankly awesome leafs) without doing the Carrier bearing drop. it is simple to put in yourself. I can walk you through it when you get it in.
    AllTacosFloat and Brownmatthall like this.
  14. Nov 9, 2021 at 11:11 AM
    Brownmatthall
    2016 TRD OR DCSB
    You the man :fistbump:
  15. Nov 9, 2021 at 11:59 AM
    rustyfromskowhegan
    rustyfromskowhegan Well-Known Member
    2013 AC 4x4
    My alignment cams are 100% frozen. Waiting for a good deal on either new LCA’s or some used OEM ones that can be rebuilt with good bushings and ball joints. Or for a lower ball joint to go. Whatever happens first. Pretty much same with UCAs except I don’t think OEM are rebuildable.
    JeffB likes this.
  16. Nov 9, 2021 at 12:05 PM
    Pugga
    Massachusetts
    Have you priced out the LCA hardware? It was a few hundred just for the stupid, I mean special bolts to attach the LCA to the frame.
  17. Nov 9, 2021 at 1:21 PM
    rustyfromskowhegan
    2013 AC 4x4
    I actually have all the lca hardware new in boxes. Bought it new from Boch because i thought I would need it for an alignment because the original ones were pretty crusty. My mechanic informed me they were most definitely seized and it would be an expensive job in labor to take shit apart, cut lca bolts off, extract old bushings and sleeves, put in new ones, etc. since i was still well within spec with alignment and the ball joints were fine i decided to ride them out until they really need replacing. So i have all new oem lca cam tabs, bolts, etc for a rainy day, unless someone wants to buy them lol
  18. Nov 9, 2021 at 2:22 PM
    Tacosfordaysndays
    Tacosfordaysndays Member
    18 taco sr5
    Bed rack with rtt
    Does anyone know if the guy that does the undercoat spraying, in the Taunton area, is doing it again? Or did I miss it maybe
  19. Nov 9, 2021 at 2:28 PM
    Brownmatthall
    2016 TRD OR DCSB
    Hes done for the season i believe, gotta wair til spring (its @jpereira2 btw, he'll usually post a thread a couple weeks before the start date so keep your eyes peeled for next time)
    jpereira2 likes this.
  20. Nov 9, 2021 at 2:32 PM
    Tacosfordaysndays
    18 taco sr5
    Bed rack with rtt
    Thanks, I kind of figured that I missed it. I will definitely need to be better prepared come spring
