New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Dec 3, 2021 at 6:43 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    I've noticed I can only find chi-com shear pins for my early 90s snapper blower. And those fucking things might as well be brass, I change at least 1 per use, they suck balls. The ones I used to be able to get from sears online were leaps and bounds better. So now I've got a pile of about 40 of the chi-com ones.
  2. Dec 3, 2021 at 7:21 PM
    Fitzwilly
    Fitzwilly Well-Known Member
    Bill
    South Central Mass
    2018 JKU "Golden Eagle" Edition
    About to just put grade 8 bolts in vs shear pins like my old 1970s bobcat snothro.
  3. Dec 3, 2021 at 7:47 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    A wise move regardless, I don't want to look at my damn snowblower when I don't have to use it
  4. Dec 4, 2021 at 3:29 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Makes sense. Their sense of raw material and heat treating is a little bit more ..... Relaxed.
    Do and don't. Grade 8 might have a higher shear strength than the pins did - which is not great.
    Need more details do you have an old shear pin still that you can measure the diameter of. Or do you have the model number. I've been in QA for 6 years you kidding me I get to put my engineering skills to use here yee haw! I can see if I can find something that's near the shear strength - hell it may be grade 8 bolts still.
    Fair enough. I put my shovels out back in the winters too. Same idea.
    She's cold out there this mornin boys!
  5. Dec 4, 2021 at 4:16 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I use standard grade bolts for shear pins. I did break one last year. It’s a 20+ year old snow blower, everything in it is steel. Shear pins are for peasant snow blowers. :stirthepot:
    Sloth and Fitzwilly like this.
  6. Dec 4, 2021 at 4:42 AM
    Fitzwilly
    Bill
    South Central Mass
    i understand the purpose of the shear and bought a dozen or so 2 packs last time I needed some. I’m just sick of having them break so often on just heavy snow. Ariens budget models aren’t built like their more expensive counterparts and have thinner pins.
    GarlicFarts[QUOTED] likes this.
  7. Dec 4, 2021 at 5:07 AM
    GarlicFarts
    Lil Rhody
    Ah gotcha I don't know a whole lot about snow blowers.
  8. Dec 4, 2021 at 7:35 AM
    zjcas
    zjcas Well-Known Member
    Zach
    Hooksett
    2012 DCSB TRD Sport
    Fox 2.0 COs, Fox 2.0 Resi's, Wheeler's Prog. AAL.
    Wife and I are finally starting to settle down in Charlotte I've learned 2 things these last 2 weeks...1) Apparently cockroaches getting indoors are a common problem down here this time of year and no one is the slightest bit bothered by that (disgusting) and 2) So far our fall/early winter lasted about 3 days around Thanksgiving and its been anywhere from 65-80 everyday this week. In other news, if anyone is down this way and wants tickets to a Charlotte Checkers game (AHL) let me know and I'll leave em for you at the box office
    raspy87, Chasespeed, Merling and 3 others like this.
  9. Dec 4, 2021 at 8:06 AM
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    Quick question for y’all. I replaced my cig lighter socket with a usb-c and usb socket with a digital readout. Was working fine for a little over a year until a few days ago. Plugging in a regular usb cable shuts it off, and the usb-c port is intermittent. Any ideas what could possibly be wrong?
    If anything, would it even be a good idea to hook up the OEM wires to a relay and draw power direct from the battery that way? In case those thin wires can’t handle all the juice.
  10. Dec 4, 2021 at 8:38 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Hankook DynaPro AT2 (Summer), Blizzak DM-V2 (Winter)
    I have a 24" Ariens snowblower. It works great but I don't use it very often. I figure the attachment would be the best of both worlds - it'd do a big wide pass like the ATV plow, but with the ability to throw snow like the small snowblower. I found some used ones for around $1k, but they were all far enough away where It'd be most of a day to go out and back and at that point with the gas factored in I figured I might as well just buy a new one. With chains and some suitcase weights, I think this machine (John Deere x500) would do it no problem, but then I'm up to $2k.
  11. Dec 4, 2021 at 9:35 AM
    ABA180
    East Bridgewater MA
    Mine is a 24" Simplicity, roughly 8HP. Paid $800-850 new in 2015. I was actually debating getting 1 more year from my old Ariens 20" 4HP but it was tired..and man if I had only got that one year from the Simplicity it was still worth it, that was the horrible winter. My old one wouldn't have made it out of the garage.
    I refer to my driveway as 4x4. Can fit my truck and her Rav4 side by side, you could get 2 more cars behind that..and then maybe a motorcycle.
    Agreed your example is about $2K there, on top of the tractor cost and the increased wear on it. As I see it, I'd rather put less wear on my tractor if possible because that would run me quite a bit more than $800 if I had to replace it new. That said I got mine about 10 years ago for $200 originally intending to use it as a donor for the one I inherited with a junk transaxle..turns out this one started right up when I tightened the spark plugs.
  12. Dec 4, 2021 at 10:52 AM
    Tacosfordaysndays
    Tacosfordaysndays Member
    18 taco sr5
    Bed rack with rtt
    Wondering if anyone could maybe help me out. I have a horrible shake when braking. I just had the rear drums replaced and I measured the front rotors and they have under .002" runout. Has anyone had this issue or heard of a known issue that causes this? Edit. All stock sr5 with just a bed cap installed but has done it since before that went on.
  13. Dec 4, 2021 at 11:24 AM
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    Is the shaking coming from the front or the back? And does the vibration match your speed when you accelerate/decelerate?
    AllTacosFloat likes this.
  14. Dec 4, 2021 at 11:25 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    Maybe a stuck caliper piston or rotors need turning.
    Pibbles99 likes this.
  15. Dec 4, 2021 at 11:32 AM
    AllTacosFloat
    Boston ish
    Going wheeling next weekend? :boink:
  16. Dec 4, 2021 at 12:01 PM
    Brownmatthall
    2016 TRD OR DCSB
    Possibly, I do wanna try the new rubber out...
    AllTacosFloat[QUOTED] likes this.
  17. Dec 4, 2021 at 1:10 PM
    Tacosfordaysndays
    18 taco sr5
    Bed rack with rtt
    The entire vehicle shakes, as I slow the shake slowed as well.
  18. Dec 4, 2021 at 1:12 PM
    Tacosfordaysndays
    18 taco sr5
    Bed rack with rtt
    The rotors have under .002" of runout.
  19. Dec 4, 2021 at 1:32 PM
    AllTacosFloat
    Boston ish
    Stuck caliper is what happened to mine. These are simply the most common reasons.
    From there got to look at tires, how's your alignment? Worn bushings or ball joints?
  20. Dec 4, 2021 at 1:35 PM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    I sell a ton of them
