New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Feb 6, 2022 at 7:07 PM
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    Alright y’all. I need new rubber on my truck. The debate is what to get in terms of size. I guess the question is, what’s the fattest tire I can throw on the OEM 17” sport rim (with Rick’s old suspension)? If nothing like a 285, then I’m going to have to get aftermarket rims, probably 17x9 0 offset. Then if I do that, can I technically shove 305 in there? Then I’m gonna have to trim and crap, so there’s that debate too…
  2. Feb 6, 2022 at 7:24 PM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    Another pro to being single...
    jpereira2 likes this.
  3. Feb 7, 2022 at 2:38 AM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Backspacing at least on a 2nd Gen, you'd want 4.5" or less to pull the tire away from the UCA. Which with my Icons and 4.5" backspacing I run 12.5" wides. Also ran 12.5s on stock UCAs, but in a 33. So 315 or 12.5 wides
  4. Feb 7, 2022 at 3:56 AM
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    When you say fattest are you specifically looking for width or bigger diameter?
  5. Feb 7, 2022 at 5:08 AM
    CttAznRanger
    Brandon
    Boston, MA
    More so width. Like, anywhere from a 285 to a 305. I'd like to keep the stock rims if possible as well.
  6. Feb 7, 2022 at 5:11 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    @replica9000 was running some pretty wide tires. I don't remember if he had 295's or 305's, they were wide though.
  7. Feb 7, 2022 at 7:00 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I have 295/70R17 on my 4Runner, and had 305/60R18 on the Tacoma. Both on aftermarket 9" wide rims.
  8. Feb 7, 2022 at 7:08 AM
    Pugga
    Massachusetts
    I couldnt' remember if you had aftermarket or stock wheels, but I remember the wide ass tires you had without a lift.
    tacobell007 likes this.
  9. Feb 7, 2022 at 7:29 AM
    replica9000
    2019 T4R ORP
    Tacoma had a lift. At the time, it was just a spacer lift with AALs
  10. Feb 7, 2022 at 7:39 AM
    CttAznRanger
    Brandon
    Boston, MA
    For you Taco, what was the offset of that rim, if you remember? That and, what other stuff did you have to cut/bend?
  11. Feb 7, 2022 at 8:17 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
  12. Feb 7, 2022 at 8:26 AM
    replica9000
    2019 T4R ORP
    The rim was 18x9" +0. I had the cab mount chop, removed the front mud flaps, and moved the plastic forward at the front of the wheel well.
  13. Feb 7, 2022 at 8:27 AM
    Pugga
    Massachusetts
  14. Feb 7, 2022 at 8:51 AM
    CttAznRanger
    Brandon
    Boston, MA
    oh, that's not too bad at all. What tires are those by the way? I'd love to run Wildpeaks, but they only have 285/70r17 or 285/75r17 or 315/70r17
  15. Feb 7, 2022 at 8:55 AM
    replica9000
    2019 T4R ORP
    They were the original Nitro Terra Grapplers. I think they make the new version in the same size.
  16. Feb 7, 2022 at 11:27 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    You should see the next I want!
  17. Feb 7, 2022 at 11:31 AM
    Pugga
    Massachusetts
    :worthless:
  18. Feb 7, 2022 at 12:16 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Go down about a 3rd of the way down this page to "collectors elite #1"
    GarlicFarts likes this.
  19. Feb 7, 2022 at 12:17 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    ^^^ This is getting ridiculous!
    GarlicFarts, AllTacosFloat and Pugga like this.
  20. Feb 7, 2022 at 12:19 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
