New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Aug 9, 2022 at 6:23 AM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    A life time of working outside in winter cured me of that stuff.
  2. Aug 9, 2022 at 8:39 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    I enjoy that it gets cooler, but like - 40-50 is enough. RI is pretty good about that. We had a blizzard, 2 days later it was sunny and 50, I could see my grass within a couple more days. Piles/snowbanks, but the blankets of snow were gone. It's a little colder than I'd like here, but it's manageable.
    We went between Xmas and New Years in 2019-2020, right before the 'rona. I mean, in the nice neighborhoods there were 1 mil houses sure, but I found a couple 1200 sq ft and 1/3 acre lots for 3-400k, more expensive than where we're at they'd run closer to 250k (at the time), but hey, it's Austin vs. Providence. Those same houses now are 1 m + and around here they're 375-425. Bonkers, everywhere.
    ....Considering they had an accident bad enough to shut 'em down, I doubt they were that good at making furniture :rofl:
    CTSpruceMica likes this.
  3. Aug 9, 2022 at 8:55 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Yup, and it's already too hot here in the summer. Why would I want to move somewhere that's even hotter?
  4. Aug 9, 2022 at 9:06 AM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    You are most likely not far from the truth there but idiots using power tools.....:eek:
    Every time I complete a repair I find something else they did either wrong or sub standard. My favorite was where they put the toilet in the downstairs bathroom. They measured the entire length of the house, found the middle then built a wall dividing the two sides. It's time to put in a toilet and it needs to fit between where the dryer is going to be and the sink is going to be and it needs to be so many inches from the wall so it has to go right here(X marks the spot). Wait, there is a floor joist right where the toilet drain pipe needs to go. Oh my, what do we do? Let's just cut the joist and stick the pipe through, that will work. Should we sister the two joists on either side to make it sturdy again. Naw, no need to do that. And, instead of plywood let's use the sheets of particle board. When that stuff gets wet it holds up really well!:annoyed::facepalm:
  5. Aug 9, 2022 at 10:09 AM
    HisDad
    Texas at last
    We checked house prices last November when we were there. A 3 bed, 2 bath ranch in a middle class neighborhood was going for about $1 Million. Some of those were torn down to be replaced with mansions. Even south Austin, long a poor area is being gentrified. For a while Pflugerville was a reasonable alternative, but a lot of people who fled Austin moved there and prices are high.
    You have to go beyond Bastrop to find reasonable prices and that's going away fast. In other directions you need to go out to Hays County, Marble Falls, Williamson County, and other areas an hour or more away.
    GarlicFarts[QUOTED] likes this.
  6. Aug 9, 2022 at 10:24 AM
    GarlicFarts
    Lil Rhody
    Last time I did wiring I found a neutral wire was purple on a light switch. It was one of those Schroedingers wiring moments. I reattached it as I found it and walked away. If it works, I am not going to futz with it. Because THAT feels like it'll be a ball of yarn if I kept going.
    1955 construction, it has some....character.
    That's what is going on in the entire Zilker neighborhood. I saw a 3 bed 1 bath going for a mil, they'll tear it down and build one of these f'in things, and sell it for 3.
    They ALL look the same, way too much glass, you can see their ENTIRE house, insulation is piss poor, and they landscape with grass because F YOU water conservation in the desert.
    :confused:
    If I was able to work from home I would ABSOLUTELY go somewhere near the Frio. I wouldn't care about being an hour away if I was only going into the city once a week or so. But the trails and whatnot are one of the huge draws so, why would I want to move all that way just for the winters to be warmer but just sit inside all the time anyway :|
    Genuinely, RI is a huge difference even from central MA. I think I've shared this before. It's not gospel but, it's a huge difference. This has been enough for me so far, and I'm still close to family. The weather only makes my face hurt about 5-10 days a year down here, vs when I was at UMaine - one year the avg temp for Feb was -5. My record I saw was -35°, I went outside just to say I did. Bananas.
    https://en.wikipedia.org/wiki/Clima...dia/File:Köppen_Climate_Types_New_England.png
  7. Aug 9, 2022 at 10:29 AM
    HisDad
    Texas at last
    I'm not sure even eastern MA is humid sub tropical, well other than the last two weeks.
    Lots of modern fugly buildings going up in Austin.
    GarlicFarts and CTSpruceMica like this.
  8. Aug 9, 2022 at 10:31 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    @GarlicFarts
    Wiring...when we demo'd our main bath there was Romex inside the wall behind the shower wall...attached to nothing...and it was live:goingcrazy:
  9. Aug 9, 2022 at 10:36 AM
    HisDad
    Texas at last
    I'm not an electrician, but i am convinced that when a new house is built they just run wire from room to room using what ever circuit is nearby. I spent hours mapping out the circuit breakers in our house and was amazed at the randomness of it all.
    CTSpruceMica and GarlicFarts like this.
  10. Aug 9, 2022 at 10:37 AM
    GarlicFarts
    Lil Rhody
    Yeah, a lot of "modern". I dunno, felt weird. I liked it when we first went, then I went back and it felt..."California-ized". Like, I know TX as....TX...and I know Austin has always been the weird city too. But seeing all the McMansion style houses (PS that one I grabbed a rendering of was only "only" like 2300 sq ft, so not really a "mansion", that thing was 3m...), plastic surgery signs, etc etc. Just didn't feel "Texas".
    BBQ game is on point though.
    Oh that's fun! "Just in case!"
    Wow. That's...Impressive.
  11. Aug 9, 2022 at 10:39 AM
    HisDad
    Texas at last
    Just as people from Louisiana say that New Orleans isn't Louisiana, people from TX say that Austin isn't TX. I've been to other parts of TX and the feel is different.
    GarlicFarts likes this.
  12. Aug 9, 2022 at 10:43 AM
    GarlicFarts
    Lil Rhody
    Fair point - I dealt with that BS in Maine. It's like a point of pride that you're from further north for some reason. And Orono "Isn't Northern Maine" ....
    :infantry:
    I mean I'm in a city now, Providence, and I don't see the same "city-ization"/"Californiacation" as Austin was getting.
  13. Aug 9, 2022 at 10:46 AM
    HisDad
    Texas at last
    There's not the money in Providence that there is in Austin. Boston is a lot more like Austin. Or Charlotte or Nashville for that matter.
  14. Aug 9, 2022 at 10:55 AM
    ACEkraut
    Aaron
    Durham, Maine
    It's all relative. Orono is northern Maine if you live in Kittery, or Portland, but not if you live in Caribou or Fort Kent.
    Spare Parts, HisDad and CTSpruceMica like this.
  15. Aug 9, 2022 at 11:02 AM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    Used to work with a guy from Madawaska...he'd agree
    HisDad likes this.
  16. Aug 9, 2022 at 11:43 AM
    GarlicFarts
    Lil Rhody
    I was in Salem, NH - southern NH. I never said "Oh Manchester isn't SOUTHERN NH...I'm a REAL southern NH-er"
    I couldn't stand that "Northern superiority" BS in Maine. I never got it. Once you get north of Orono it's all the same, woods. Whether you're an hour north or south, it's the same pine trees and everything. Just got really really annoying.
    emelianenkov likes this.
  17. Aug 9, 2022 at 12:10 PM
    ACEkraut
    Aaron
    Durham, Maine
    Oh, I never said I agree...just that opinions change based upon locations. Now if you want a fun debate, ask where the sun first rises in Maine?
    Edit: It is a BIG state. If you are in Kittery it takes less time to get to New Jersey then it does to get to Fort Kent.
  18. Aug 9, 2022 at 12:16 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    I thought the big debate in Maine was flannel vs. camo
    :crapstorm:
  19. Aug 9, 2022 at 12:19 PM
    ACEkraut
    Aaron
    Durham, Maine
    Most likely, just not in my household. :duel:
  20. Aug 9, 2022 at 1:37 PM
    GarlicFarts
    Lil Rhody
    Machias vs Cadillac I assume?
    ACEkraut[QUOTED] likes this.
