New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Aug 26, 2022 at 9:15 AM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    I lived in Northern Manchester in 2020 into early 2021. It was nice and quiet over there at Waterford Place. I like Hooksett from the been I've experienced and have a buddy that moved there at the end of 2020. My other buddy lives in Weare and works at GE, I think he said it's about a half hour commute to work if you wanted a more rural area
  2. Aug 26, 2022 at 9:30 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    The Max Modular Taco Max rack will allow a rolling BAK Revolver cover to full roll up with the rack installed.
    https://www.max-modular.com/toyota-tacoma-years-2005-to-present
    Then you can put TMS kayak cradles on the rack, and you can mount Roam boxes to it.
  3. Aug 26, 2022 at 10:09 AM
    AwesomeLaw68
    AwesomeLaw68 Well-Known Member
    Lawson
    2022 Tacoma Off-road edition
    Brand new.
    AWESOME ! Can you show me a close up picture as how the bracket attaches to the truck with the cover track on too i have the same cover just in all black.
  4. Aug 26, 2022 at 10:26 AM
    AwesomeLaw68
    Lawson
    Brand new.
    I wonder if the item that is 24" tall would be the best, so the kayak doesn't hit the roof line
  5. Aug 26, 2022 at 10:33 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    What kind of condition:anonymous:
    They old and ugly with an aal.
    I have a new set of allpro expo leafs for 1/2 of whatever they are new...lifts 3" with weight
  6. Aug 26, 2022 at 10:44 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Vermont sucks. Tell your friends.
    DEI universal heatshield banged onto the passenger front cat to shield the new trans lines. The standoffs and included XXXL worm clamps are stainless, but the heat shield is mild steel. I did it up with VHT header paint and used stainless zippies instead of the worm clamps, because they hardly ever have stainless screws in them:
    IMG_20220826_082117.jpg IMG_20220826_083154.jpg IMG_20220826_102215.jpg IMG_20220826_103448.jpg
    Took the first long drive since the cooling upgrades. The trans cooler (a Hayden unit) appears to work as advertised re: thermal bypass. Trans temps came up faster than with factory cooler and stayed cooler and more stable especially under load on steeper grades. CSF radiator was rock solid as expected. Ambients about 70F, temps shown below are after ~2hrs on hilly VT highways, mostly with cruise on.
  7. Aug 26, 2022 at 10:56 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Fair point. @Nimble9 it's terrible. You'd be better off going down to NJ, NY for wheeling. Pine barrens, ADK, BHM, etc. in NY. :spy:
    At folk fest I saw a guy wearing a shirt that says "Austin sucks, move to Ohio!" :rofl:
    JDSmith, Nimble9 and Brownmatthall like this.
  8. Aug 26, 2022 at 10:57 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    I think @CttAznRanger has me covered, thanks anyways.
  9. Aug 26, 2022 at 11:05 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    You could get away with our 14" and the kayaks still wouldn't hit the cab.
    The tonneau brackets add 2.5" to the height, and the kayak cradles also give it a little boost.
    AwesomeLaw68[QUOTED] likes this.
  10. Aug 26, 2022 at 4:03 PM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
  11. Aug 26, 2022 at 4:46 PM
    GarlicFarts
    Lil Rhody
    Nope. Not with a ten foot pole. That thing has to have been sitting around doing F all for long stretches. Gaskets that get lubed from use gonna be dry. Corrosion protection from use drained off and then had some corrosion. Perfect example - the rear diff is usually getting sprayed by its own oil and sloshing around. Over time the top bit has been exposed for however long. Now it doesn't have oil coating it and corrodes, even if it is minor.
    That's happening all over the truck. No thanks.
  12. Aug 26, 2022 at 4:51 PM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    Some rube will come along, see the mileage, and...well...there's an ass for every seat
  13. Aug 26, 2022 at 5:00 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Meh, it'll be fine, will likely need some maintenance but it'll ok. If it was a 50's car with that mileage, people would be all over it. I. An't see the postthough, only the description so i couod be missing xomething obvious.
    GarlicFarts[QUOTED] likes this.
  14. Aug 26, 2022 at 5:06 PM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    I fixed the link
    Edit: In July a 2002 with 52k miles went for $30,750
    https://bringatrailer.com/listing/2002-toyota-tacoma-sr5-4x4-23/
  15. Aug 26, 2022 at 5:23 PM
    GarlicFarts
    Lil Rhody
    Slap my ass and call me Sally. The Carfax shows service records - happening every 1-2k miles spread throughout purchase to now. It didn't sign for 6 years like I guessed.
    V6 4x4 OR? I'd bid on that. Damn. Probably gonna be in the 30k neighborhood.
  16. Aug 26, 2022 at 5:34 PM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    Austin didn't used to suck, it was a fun city. Now it's a big, expensive city, with overpriced housing and a growing crime rate.
  17. Aug 26, 2022 at 6:22 PM
    GarlicFarts
    Lil Rhody
    Oh I know. We've talked about it before here too.
    Gotta add the homeless population too. Northern states will ship their homeless south where it's warm. Then they in turn ship them to Hawaii one way where they can't get off the island. As bad as it is in CA and TX, it's easily 10x worse in Hawaii.
  18. Aug 26, 2022 at 7:17 PM
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    Only 14K miles and a frame that’s ready to break in half. It would be a great truck if it was from the desert not PA. Why did it need new front brakes already? My truck is only one year newer but has 145K more miles than that one and my frame has way less rust. WTF!
    GarlicFarts likes this.
  19. Aug 27, 2022 at 3:09 AM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    Exactly. Somebody is gonna overpay.
  20. Aug 27, 2022 at 4:24 AM
    GarlicFarts
    Lil Rhody
    That should still qualify for the frame recall. I think.
