New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Sep 1, 2022 at 4:45 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    They do have galvanized rattle can paint you could use that
  2. Sep 1, 2022 at 4:54 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Don't use spray galvy, it's OK for touch up but not full scale painting, in my opinion. If you're going to keep the frame upkept with WW or FF, I'd hesitantly say it doesn't much matter what the base is since it should stay protected. That said, I've heard good things about Eastwood products for encapsulating rust, that could be a viable option for you. Otherwise, I'd say any rattle can primer suitable for bare metal should work.
    jpereira2 likes this.
  3. Sep 1, 2022 at 5:09 AM
    AllTacosFloat
    Boston ish
    @Chasespeed
    Okay, cold dipping would be a little excessive and very heavy but if you're going to blast it I would look into a DTM and I can get you a sprayer to apply it or I can spray it out for you. If dtm is for you I have lots to pass your way.
  4. Sep 1, 2022 at 6:10 AM
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    For the record, truck is NOT being stripped... or I WOULD dip it.
    The person that is gonna handle the frame, does the whole thing..
    Did my buddy's SD a while ago, still looks pretty good.. he just never had it sprayed with FF/etc...
    And the frame rust isn't bad at all... just figure.. I'm going through all this, might as well freshen it up... buy another 10 years.
    Just wasn't sure on whether to paint, prime, or, as @AllTacosFloat mentioned(wasn't even on my radar) DTM.
    Just wanna clean it up, knock scale and surface rust, and encapsulate...
    tacobell007 and AllTacosFloat like this.
  5. Sep 1, 2022 at 6:20 AM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    I wouldn't recommend linex, if there's any moisture under it it will cause issues down the road
  6. Sep 1, 2022 at 7:25 AM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    I had Rhino Liner applied to both of my Tundras when they were new. Worked very well and was grippier than Linex.
  7. Sep 1, 2022 at 7:26 AM
    Pugga
    Massachusetts
    Talking about applying to a vehicle frame though, not a truck bed.
  8. Sep 1, 2022 at 7:54 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    What is DTM?
  9. Sep 1, 2022 at 8:10 AM
    AllTacosFloat
    Boston ish
    Direct to metal
    No primer needed and sticks to everything. Usually used in industrial settings
    tacobell007 likes this.
  10. Sep 1, 2022 at 9:13 AM
    Pugga
    Massachusetts
    CTSpruceMica likes this.
  11. Sep 1, 2022 at 9:27 AM
    jpereira2
    Massachusetts
  12. Sep 1, 2022 at 3:58 PM
    HisDad
    Texas at last
    Pugga[QUOTED] likes this.
  13. Sep 2, 2022 at 7:26 AM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
  14. Sep 2, 2022 at 7:32 AM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Late to the party...again.... It is a misconception that poison ivy "spreads" once the initial oil from the leave is washed off. It appears to spread as some areas of rash show up before others but really what is happening is that the areas that have had more oil exposure flare up first then the areas with less exposure flare up progressively. The same is true regarding thickness of skin. The same amount of oil exposure to thinner areas of skin will show a rash quicker than thicker areas of skin. The result is that it appears that the rash is "spreading" when it is not. Once again this is assuming that all oil has been removed and no new exposure to new poison ivy is occurring.
  15. Sep 2, 2022 at 9:26 AM
    jpereira2
    Massachusetts
    emelianenkov[QUOTED] likes this.
  16. Sep 2, 2022 at 5:42 PM
    Chasespeed
    In the woods...
    2018 TRD OffRoad
    Some stuff
    Ugh... this year, has been expensive....
    But, stupid duty is getting sandblasted, painted.. bodywork fixed. Then fluid filmed after hydro assist...
    Lower portion of rear porch is set, next phase is roof for new porch. Now she wants a wrap-around....
  17. Sep 2, 2022 at 7:01 PM
    tacobell007
    Drew
    Western MA
    Here's a teaser for the 4runner I'm getting. I feel like the hard top almost seems to belong on the tacoma
  18. Sep 2, 2022 at 7:17 PM
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    Oooooooof, jelly
  19. Sep 3, 2022 at 1:22 PM
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    TIL the JBA UCAs I have are like the old old ones where the bushings have metal sleeves… couldn’t press them out so the truck is out of commission until I can get my shop to press them out on Tuesday. THEN I’m out of state for a week, so shit will be sitting until next next weekend for me to install.
    Big thanks to @crashngiggles for the reassurance that we weren’t doing shit wrong.
  20. Sep 3, 2022 at 2:36 PM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Jared is a great guy!
