New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Oct 24, 2022 at 6:51 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I’m very lucky in that I effectively have three options now to heat my house in an emergency. I’ve got basic forced hot air, a Mitsubishi Hyper-Heat ducted and ductless hybrid system and then a Jotul wood stove.
    My stove is fine to use, although I haven’t used since my kids were born. When I had it reinstalled after it was disconnected for the tiling work I had done the stove guy said the stove was too close to the wall / my tile wall wasn't fire rated. I'm sure he's right, but that being said, I used it at least two dozen times over the years and I never felt like the wall behind the stove was even hot enough you couldn't touch it. I would only use the stove in an emergency at this point and I have largely given away my wood collection.
    My oil system is a bit of a mess, but that's more my house than the heating system. I don't have any forced hot air ducts in my master bedroom and my family windows are exceedingly drafty, so that room is usually cold. The only other drawback is my hot water is oil fired, so I would need oil for that. I do have a backup generator with more than enough oomph to run both of those systems if I lost power.
    My mini-split gets the house warm, but the electricity costs are exorbitant when the temperature dips below 40°F. It's integrated into my furnace system such that below 40°F the furnace runs as well and then below 30°F only the furnace runs. The biggest issue with that is the location of the sensor that runs the system. Because my house is only one zone only one sensor can trigger the changeover. The install contractor used the wall mounted mini-split sensor as the trigger, but that's conveniently located in the coldest part of the house, my family room. So on a cold day the oil heat will kick on and get that sensor location up to whatever we set it to (say 68°F) but then the rest of the house ends up at 74°F because of the differential. So do we freeze in that room to keep the costs down? I don't know. I know we can de-integrate it temporarily and run just the oil heat when it gets cold, but it's supposed to be a seamless system. I do run the electric heat before bed to get some heat into our master so it's not 60°F getting ready for bed.
  2. Oct 25, 2022 at 5:25 AM
    Rocket23
    Rocket23 Licensed Dynacologist
    Rocket
    Pennsylvania
    2019 sr5
    The list is growing.
    Compare that to the 500+ a tankful in 2008. (Lasted the whole year). I still think I’m lucky to have natural gas. Our gas bill in the winter is around 120.00. Under 30. When we shut off the heat. We try not to put it on til after thanksgiving. But the folks that have oil are gonna feel not as lucky
  3. Oct 25, 2022 at 6:15 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    This is kinda cool. Wish it would give me month ranges, or a way to pick out seasons instead of years. 22 is already better. Well probably be at zero in October.
    I think some of those tiny bits on crossovers is me turning everything on to make sure it's all good, not necessarily running it for the HVAC.
  4. Oct 25, 2022 at 6:56 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Natural gas is really only available in the densely populated areas here. I think the closest gas line is about 3 miles from me.
    tacobell007 and Rocket23[QUOTED] like this.
  5. Oct 25, 2022 at 7:05 AM
    GarlicFarts
    Lil Rhody
    Ah yes, add a layer of inefficiency by burning the NG to create electricity, THEN turn that into heat!
    :facepalm:
  6. Oct 25, 2022 at 7:32 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    What an awful game yesterday from the Patriots!
    Merling and Bruce988jl like this.
  7. Oct 25, 2022 at 7:43 AM
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    The scary part is their are thoughts about exhaust fumes that are downright inaccurate
  8. Oct 25, 2022 at 9:09 AM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Funny that that is actually how a NG power plant works. They burn fuel to create electricity, the exhaust super heats water to make steam to power a steam turbine (if the plant has one, could just be a NG plant as well), which the steam turbine by itself creates more electricity than two NG ones. Then the steam goes down the line for building heat, and other things, and the end for heating water for hot water in the building
  9. Oct 25, 2022 at 9:14 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    Whats this software your using? Looks really good to keep a keen eye on everything?
  10. Oct 25, 2022 at 9:18 AM
    GarlicFarts
    Lil Rhody
    Honeywell. It's a Honeywell t stat. Our nest failed miserably even with a c wire. This app (Honeywells) has taken some time. Run times is relatively new. But I've always been able to control remotely and set vacation etc. For the cost of the t stat vs a non "smart" one, it was worth it. Only about another 20$ and I can set vacation blocks, control it a loooot easier for schedules, etc.
    Merling and tacobell007 like this.
  11. Oct 25, 2022 at 9:27 AM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    Which NEST and what failed? I have three coming from the MassSave program.
  12. Oct 25, 2022 at 9:36 AM
    GarlicFarts
    Lil Rhody
    It was like 5 years ago. The first one fried a board so we ran a c wire. The second one after about a month just stopped sending the call for heat. It said it was but multimeter determined that was a lie.
    tacobell007 and Clark27[QUOTED] like this.
  13. Oct 25, 2022 at 11:32 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    It's already under fire, but quietly. A lot of new town/city funded buildings are all electric (and sometimes the grid is not able to handle that sort of load).
    banned parts[QUOTED] likes this.
  14. Oct 25, 2022 at 11:48 AM
    Clark27
    Springfield, MA
    2015 Lexus GX460
    Good to know. I’m planning to run C Wires to the two on the main floor since the basement is all exposed right now so hoping I have no major issues with a few Nest E thermostats
    GarlicFarts[QUOTED] likes this.
  15. Oct 25, 2022 at 11:57 AM
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    I’m hoping the new stove we got will cut down on oil usage. I won’t have to babysit it like the old one and constantly feed it. Hopefully when I get up at 0400 it will be burning enough to revive and keep it going till around noon . That’s my plan anyway.
    Rocket23[QUOTED] likes this.
  16. Oct 25, 2022 at 12:22 PM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    Anybody recommend a good heat activated fan for the stove?
  17. Oct 25, 2022 at 1:03 PM
    DoubleRGirl
    DoubleRGirl Hello Kitty Edition
    Rebecca
    Rhode Island
    2015 DCSB TRD Sport 6speed
    what's up bitchezzz, @mach1man001 was over the other day and reminded me i need to check in more often. this rain is bananas
  18. Oct 25, 2022 at 1:31 PM
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    Heading into work. The horror. The horror
  19. Oct 25, 2022 at 1:54 PM
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    Do any of you know what the deal is with Toyota fuel pumps and a class action lawsuit? I just got a letter about it. I assume it’s for our 4Runner not the Tacoma.
  20. Oct 25, 2022 at 2:28 PM
    GarlicFarts
    Lil Rhody
    C wire is worth it. It's easy too, usually. Was for me.
    Don't know about the "E". To me they're all kinda the same. We only have one zone for heat and AC though so it's just one t stat for the whole house. My in laws have two zones and two nests t stats.
    Tacoma pre 2020 had some fuel pump issues. I think it was only turd gens. Probably the 4runner.
    Clark27[QUOTED] likes this.
