New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Dec 30, 2022 at 11:24 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    For the sake of my marriage, I really can't! I appreciate it, but I need to stick to stock wheels and tires. It seems to tow well now, everything is set up and level, the 34
    s look pretty good in the wheel wells. I can't (and shouldn't) rock the boat.
  2. Dec 30, 2022 at 12:29 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Pretty good temperature for the end of the year.
  3. Dec 30, 2022 at 12:47 PM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    64 here in the south of Boston area. Took advantage of the beautiful weather to head to the range.
    tacobell007 likes this.
  4. Dec 30, 2022 at 1:53 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    I think the 35s would look good on my 4runner for summer but I don't have any toyota wheels for 20s and I don't even know if they make adapters and if that would fit regardless
  5. Dec 30, 2022 at 2:06 PM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    https://youtube.com/shorts/8OqUshc7HFQ?feature=share
    Hey yall so my truck has been making some noises since taking it on the trail after toys fir tots. Still trying to figure out what is causing it but my cross member is just a hair dented in and is this supposed to click like this? All the u joints seems fine. Not consistent or rotational noises. It's like when shifting and turning at times. Need to pull wheels off at some pint to inspect further.
  6. Dec 30, 2022 at 2:51 PM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    One is dedicated for email one was dedicated for our MRP system, and one portrait orientation for reading documents. Usually the vertical screen was my email screen too unless I needed to overlap.
    Personal computing I basically use my phone and that's it. But as a desk worker I use the shit out of 3 monitors. Now I'm down to 2 and my laptop instead but it's a standing desk so win some lose some.
  7. Dec 30, 2022 at 6:21 PM
    tacobell007
    Drew
    Western MA
    That on the tcase? If so, then yes, it's the gear backlash. You'll need to hold both sides of the ujoint and see if you have play that way (hold tcase or pinion side stationary and the driveshaft side try to move) to check for play in the ujoints themselves
    jpereira2[QUOTED] likes this.
  8. Dec 30, 2022 at 6:26 PM
    jpereira2
    Massachusetts
    Yup tcase rear drive shaft
    tacobell007[QUOTED] likes this.
  9. Dec 30, 2022 at 6:48 PM
    tacobell007
    Drew
    Western MA
    I'd say that normal. Mine does it, it's the backlash in the gears and the sprocket and chain lash in the tcase
  10. Dec 30, 2022 at 6:50 PM
    jpereira2
    Massachusetts
    Glad to know! Still to figure out the noise lol. Might remove sway bar and see if that helps lol
  11. Dec 31, 2022 at 8:22 AM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I tried getting a 3rd monitor to work with my setup at work, but our docking stations are trash. We finally went from circa-2006 19" monitors to 24" monitors and I had a plethora of 19s to play with. I was playing with USB to VGA which I could get the PC to recognize but not display anything on. I didn't care enough to try and more.
    I got my door bowl LEDs connected up yesterday. I dig they a lot more than I ever thought I would.
  12. Dec 31, 2022 at 8:29 AM
    HisDad
    Texas at last
    My fairly ancient Acer has two HDMI and one VGA port. I use a fairly low "Element" TV as the third monitor. I think I paid five dollars for it and another eight to buy a remote on Ebay. The remote is because you need that to change things like the imput. It's small which is why I bought it.
  13. Dec 31, 2022 at 9:24 AM
    jpereira2
    Massachusetts
    Took a few minutes this morning to touch up the woolwax. The can of fluid film didn't cut it. It all washed off so it was warm enough I filled the compressor and wheeled it over after and warmed a quart of woolwax.
    Also, happy new year!
  14. Dec 31, 2022 at 5:07 PM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Hankook DynaPro AT2 (Summer), Blizzak DM-V2 (Winter)
    I have three 24" monitors at work, but because I run everything off my laptop on a Thunderbolt dock, I can open the lid for a fourth smaller display in a pinch.
    I only have two monitors in my home office, but a similar docked laptop setup. It gives me the flexibility to connect either my home or work laptop at home - very helpful if I need to get some off hours stuff done.
  15. Jan 1, 2023 at 6:20 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    All this talk about monitors reminds me of a pic I took of my work monitor the day I retired in 2018. It's a shot of my Outlook calender for the next month. Blank. I waited a lot of years to see that.
  16. Jan 1, 2023 at 7:30 AM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Fun fact, Outlook's calendar range is wild. It starts at the year 1600 and heads out to something like the year 4400. I thought about putting some historical events into my calendar to see if anyone noticed.
  17. Jan 1, 2023 at 7:40 AM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    My first day at work...
  18. Jan 2, 2023 at 7:32 AM
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    Is this anyone here? Warwick MA.
    Clark27 likes this.
  19. Jan 2, 2023 at 9:24 AM
    Pugga
    Massachusetts
    Oh boy...
    HisDad likes this.
  20. Jan 2, 2023 at 10:00 AM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    Would LOVE to know the story
