New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Jan 15, 2023 at 6:04 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    OK I see what you mean. Those fill covers do look rather dorky.
    My Colorado was solid across except the indents so if you wanted fogs you could cut the holes.
    CTSpruceMica likes this.
  2. Jan 16, 2023 at 4:50 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    If theres a will theres a way.
    zu62tO8HPHFi8VOHn5P4q_1PH4jruF8AwxEzgcjK_d7a43b2a19f3ef7bea255e49b4b8348b43af3e56.jpg
  3. Jan 16, 2023 at 4:58 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    I think HID projectors are the way to go, I built my first set with these. They have great output and cutoff and the retrofit was not very hard.
    https://www.theretrofitsource.com/bi-xenon-acme-h1-stage-3-kit-CRK-ACME-H1?quantity=1
    But I am thinking I am going to swap them out for these, the acmes arent bad but Id prefer LED due to them probably being more reliable. Havent had issues yet but I think I will.
    https://www.bxbuilt.com/product-page/toyota-h4-diy-kit-4runner-tacoma-tundra-sequoia
    GarlicFarts likes this.
  4. Jan 16, 2023 at 5:33 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    There was a time I agreed with you about HID retrofits, but I've learned my lesson and won't ever do that again. The retrofit process isn't all that difficult and the results can be awesome. The issue I have is putting a high/low projector in a headlight housing puts a solenoid inside the housing that isn't serviceable unless you pull the system apart. I had the solenoid start to stick, pulled the retrofits out and will never go back to that setup again. This was a while ago, but it left a bad taste regarding retrofits. I'd only consider a retrofit in the future if the housing had a dedicated low beam and separate high beam lights. I know there are a lot of retrofits out there that are problem free, that was not my experience and I went back to simplicity (currently running a drop in LED kit).
  5. Jan 16, 2023 at 5:40 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    The only reason I dicked around with my turd gen low beams. The high beams are still factory, likely only to be changed when they die but for factory/similar halogen. They do the trick and get used infrequently. I got ditch lights, fog lights, and H9 low beams (but amber). I can see plenty with what I got. I MIGHT chuck some scene lights on the roof rack, TBD.
    CTSpruceMica and Pugga[QUOTED] like this.
  6. Jan 16, 2023 at 7:08 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Thats a great point. Did they get stuck in hi beam mode? Seems like a good place for someone to innovate to get the solenoid out of the housing.
  7. Jan 16, 2023 at 7:13 AM
    Pugga
    Massachusetts
    I don't remember which way they got stuck, I think they got stuck in low, but I seem to recall blowing a fuse because the solenoid wouldn't cycle. The issue is, the fuse you blow is for the lights themselves. TRS was fine to work with, they warrantied the part, but it's a PITA to actually replace said part. I yanked them out and went back to halogens on the Tacoma. Since then, I've not been compelled to do another retrofit.
    Again though, I know there are a lot of them out there running problem free, I just didn't like knowing there's a solenoid in there that can fail and I can't get at it.
  8. Jan 16, 2023 at 7:29 AM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    If they're anything like my projectors, Morimoto D2 gen4's then the solenoid just move the cutoff up and out of the way for high beams. Good Idea to have one you could mount to the back of the headlight housing, but I think it would be hard to do and make look good
  9. Jan 16, 2023 at 8:06 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    With a power planer, sure. If you're talking a pedestal or cabinet type machine, now you're talking
  10. Jan 16, 2023 at 8:17 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    I made one of those but the bit I used caused more tearout then it was even worth. A sharp handplane can get some work done when its set up correctly.
  11. Jan 16, 2023 at 8:30 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Yep, I use a hand plane when it's useful. When there are big misalignments between boards, lots of knots, or a lot of glue, a router sled with a large bit can save a hell of a lot of time, even if you finish with a hand plane.
  12. Jan 16, 2023 at 9:05 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    MLK Boston statue?
    I peed a little :rofl:
  13. Jan 16, 2023 at 9:34 AM
    Pugga
    Massachusetts
    I’m not seeing the vision. I think I need to see it in person, it doesn’t seem to have a ‘good side’ in the photos I’ve seen so far. I read what it’s supposed to signify, I’m just not getting the artwork at all. Of course, This is all coming from someone with the art taste of a second grader.
    JeffB and AllTacosFloat[QUOTED] like this.
  14. Jan 16, 2023 at 9:44 AM
    AllTacosFloat
    Boston ish
    I'm with you on the 2nd grade taste... this is the best angle
    Brownmatthall and GarlicFarts like this.
  15. Jan 16, 2023 at 10:10 AM
    GarlicFarts
    Lil Rhody
    :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl:
    The front:
    (arms embracing)
    The back....
    ALSO ...... it was $10 million.
    Brownmatthall likes this.
  16. Jan 16, 2023 at 10:21 AM
    Pugga
    Massachusetts
    The real estate alone that thing occupies is easily a few million…. I would have preferred they kept the green space but… it all looks the same from my house.
  17. Jan 16, 2023 at 10:24 AM
    GarlicFarts
    Lil Rhody
    Could have done a LOT with the land and funds that I think MLK would have preferred than...that.
  18. Jan 16, 2023 at 1:00 PM
    ABA180
    East Bridgewater MA
    I was about to do retrofit long ago and your experience changed my mind. Much as I hear the aftermarket ones aren't great, they at least got the right idea of a separate light for low and for high beams which would eliminate the issue you had.
    GarlicFarts and Pugga[QUOTED] like this.
  19. Jan 16, 2023 at 4:47 PM
    GarlicFarts
    Lil Rhody
    Apparently this was the picture used as inspiration for the statue.
    Which again, 10 million dollars :rofl:
  20. Jan 17, 2023 at 6:58 AM
    GarlicFarts
    Lil Rhody
