New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Jan 28, 2023 at 9:15 AM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    crashngiggles and CTSpruceMica like this.
  2. Jan 28, 2023 at 9:30 AM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    I stuck my head under the Highlander today to take a look. Sway bar is there and attached as are the other rear suspension parts. Which, of course, does not mean that a bushing is worn or gone. Once I get my truck back from the body shop, the Highlander will go to an independent shop near me for an oil change. I'll ask them to look at the rear suspension and check for loose bushings or whatever.
    Last time I was there they mentioned that the driveshaft was a bit noisy, but i don't think it's related. I hope.
  3. Jan 28, 2023 at 10:58 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    That does not inspire confidence…. A driveshaft is fairly simple and shouldn’t be ‘noisy’. It’s either a bearing or a u joint that would be noisy and there shouldn’t be play across the joints or bushings. A bit noisy usually means something is starting to fail and should be addressed.
    tacobell007 likes this.
  4. Jan 28, 2023 at 11:37 AM
    HisDad
    Texas at last
    It's a two piece drive shaft and the bearings are not replaceable. Well they are, but it costs as much as an aftermarket drive shaft.
    The noise I'm hearing is not from the driveshaft because it happens when I go over a bump. It will probably be easier for the shop to see what's happening when they have it on the lift. If I were younger and still did my own work, I'd definitely want a lift.
  5. Jan 28, 2023 at 12:07 PM
    Pugga
    Massachusetts
    I would have a drive line shop check it out. According to Toyota, the Tacoma carrier bearing is not replaceable either, they try to sell you the whole unit flange to flange. In reality, you just need to press out a u joint and you can get the flange off and the drive shaft comes apart. If the Highlander is similar, it’s absolutely doable, but a lot of shops may not want to deal with pressing universals out. May be way off base, I’m not familiar with the Highlander, I just recall the dumb responses I got from dealerships when I needed my carrier bearing replaced. They would only replace the whole thing to the tube of $1k. I ended up doing it myself in my basement.
  6. Jan 28, 2023 at 12:09 PM
    HisDad
    Texas at last
    When the shop told me about it, I did some research. There are companies that do it, but it is very expensive. I looked at replacements drive shafts and there are some non Toyota units available.
    Keep in mind that our plan is to replace this in the spring, so I'm not thinking long term replacement.
  7. Jan 28, 2023 at 12:29 PM
    tacobell007
    Drew
    Western MA
    Sounds like that highlander shaft is like a Subaru shaft and isn't worth trying to replace since the ujoints aren't suppose to be serviceable so the bearing caps sit on top of the ears instead of inside
    GarlicFarts and Pugga[QUOTED] like this.
  8. Jan 28, 2023 at 1:45 PM
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    Have you checked the exhaust heat shields? I just had to fix one on my wife’s 4Runner that was rattling when hitting bumps.
  9. Jan 28, 2023 at 1:47 PM
    Rocket23
    Rocket23 Licensed Dynacologist
    Rocket
    Pennsylvania
    2019 sr5
    The list is growing.
    Watching a few horse races. That is all.
  10. Jan 28, 2023 at 2:35 PM
    Pugga
    Massachusetts
    I feel like you can age a NE vehicle by how many heat shields are still on it. You're right though, they can make a hell of a racket when they start to loosen up.
    ABA180 and Turd Ferguson[QUOTED] like this.
  11. Jan 28, 2023 at 4:23 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    This. Cheap and easy enough to at least have a look see at it first. Mine would start making a rattle at odd times and got looser, I just had it removed.
    CTSpruceMica likes this.
  12. Jan 28, 2023 at 4:29 PM
    HisDad
    Texas at last
    Might be a heat shield, but it doesn't sound like it. I've rescrewed heat shield in this car before. It's not that sort of higher pitch rattle that heat shields usually have.
  13. Jan 29, 2023 at 6:03 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Pine, brass, and a hell of a lot of labor.
  14. Jan 29, 2023 at 6:48 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    deanosaurus likes this.
  15. Jan 29, 2023 at 9:14 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    I think today the coldest 50° day in recent memory! I walked outside after checking the temperature and it felt so much colder than I had expected.
    GarlicFarts and Rocket23 like this.
  16. Jan 29, 2023 at 11:54 AM
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    Welp, don't ask me how but they fit with only a tiny bit of rub at full lock/reverse :D dirty5s baby
  17. Jan 29, 2023 at 11:57 AM
    HisDad
    Texas at last
    It's nice in eastern MA, or was this morning. 52 with next to no wind. If it's windy, it will feel colder. If for some reason it's humid and cold, it will feel colder.
    The worst is a cold, windy, humid day.
  18. Jan 29, 2023 at 12:26 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    Looks sick:cheers:
  19. Jan 29, 2023 at 12:29 PM
    Brownmatthall
    2016 TRD OR DCSB
    Your turn :D
  20. Jan 29, 2023 at 12:38 PM
    AllTacosFloat
    Boston ish
    Half waiting on Drew to move to 37s so I can get his.... but the kenda 35s are at a good price.
    What's your wheel offset? I need/ want new ones. Sounds like you'll be fine uca wise. I think I'll pop the spc ones in soon if so.
