New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Feb 4, 2023 at 7:09 PM
    Rocket23
    Rocket23 Licensed Dynacologist
    Rocket
    Pennsylvania
    2019 sr5
    The list is growing.
    Mine is a slant Finn. I hope it has that feature.
  2. Feb 4, 2023 at 10:32 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    My wife had a part Maine coon with triple paws. The joke was he could kill a mouse by stepping on it.
    Mine have caught a couple in the house through the years.
    Plus they're so damn cute.
    Stuck in VT likes this.
  3. Feb 5, 2023 at 2:07 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Could be the nozzle for the pilot. I had that happen on a camper, doesn’t take much to screw up the nozzles. Could be the Thermo couple that senses that flame also (more than likely that’s your culprit)
  4. Feb 5, 2023 at 4:36 AM
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    House has two pilot lights , water and furnace. Which also heats water. But I need to mend a downspout that was ripped off by the wind Friday nite
  5. Feb 5, 2023 at 7:48 AM
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    @replica9000 if thr pilot lights okay, and eventually stays light, but goes out...
    Could be thermocouple. Very common.
    Wind will also do it, shifting directions, etc, can cause slight pressure changes in the combustion area,and "blow" pilot out. Especially if the wind cap on the flue is damaged, or missing.
    With the calmer weather, if it settles out, I'd lean in that direction, but, still have it checked by someone.
    Now, it's time for a new battery.
    Went to Mohegan for a show Friday night, truck started okay, etc, just, when it's COLD, it's lazy. Started it yesterday @ 0700, and it still started unassisted
    But, I'm sure at this rate if I try to use the winch, the battery will give up. Original.
    Just thinking out-loud. Not sure whether I should deal with going AGM or just get a new L/A that fits, but, has more CCA.
    CTSpruceMica likes this.
  6. Feb 5, 2023 at 8:05 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    Cost/benefit analysis time. Duralast Gold $210, Optima red $270, Odyssey $350 and all are 720cca or better...
  7. Feb 5, 2023 at 8:15 AM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    24F has more CCA but is smaller than the 27F you probably have
  8. Feb 5, 2023 at 8:32 AM
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    Unbelievable. 70 bucks would get you 700 Cca amp 24 f battery in 1985.
    At least it’s not at a dollar an amp yet.
  9. Feb 5, 2023 at 8:58 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    The first time, I thought it might have been due to the wind. I have an unused dryer exhaust vent that was flapping in the wind. I fixed it so it wouldn't open. The other couple times, I'm not sure what caused it. With the temperature not being in the negatives today, so far it's staying lit.
    Chasespeed[QUOTED] and Rocket23 like this.
  10. Feb 5, 2023 at 10:17 AM
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    Downspout is fixed. It ain’t going anywhere for awhile
    Stuck in VT and HisDad like this.
  11. Feb 5, 2023 at 10:40 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Any of ya'll put in ground loop heat pumps (water to water geothermal)? If so, what kind of quotes did you get and what was your tonnage?
  12. Feb 5, 2023 at 12:52 PM
    Chasespeed
    In the woods...
    2018 TRD OffRoad
    Some stuff
    Well, tonnage will be determine by a Manual J.
    So, make sure you use someone that KNOWS what they are doing.
    Second, I would ask, are you close to any water?
    WHY is a ground source heat pump on your radar?
    I've worked on several. Not even on my radar as far as what I do day-to-day, but...
    If it isn't done right, you'll be pissed, and never get a R.O.I.
    @CTSpruceMica and @tacobell007
    Yep. More alone the lines of making the right choice. I have no real need for a huge battery, other than the winch...
    And it isn't dead yet... so, have some time. But, I'm sure once I put that draw on it..... :help:
    @Rocket23 if it makes you feel better, in the last year, I relaced both 1100CCA batteries in my diesel.....
    New Lithium in my Bagger, and the motor in my Dyna kills a battery a year(next will be lithium as well)... those are about 300 a pop... so, about $1/per amp... in fact, might be more, as they aren't arated that way.
    tacobell007 likes this.
  13. Feb 5, 2023 at 1:06 PM
    ABA180
    East Bridgewater MA
    Jealous, I wanted to hit that show so badly
  14. Feb 5, 2023 at 2:39 PM
    2ndtaco4me
    2ndtaco4me Well-Known Member
    MA
    13 Tacoma ltd & 02 Tacoma
    don't forget.....TACOMAS ROCK :headbang:
  15. Feb 5, 2023 at 2:41 PM
    Chasespeed
    In the woods...
    2018 TRD OffRoad
    Some stuff
    Was good.
    Exodus and Anthrax NEVER disappoint.
    Even set the wife up for a M&G Exodus.
    First time @ Mohegan other than as a contractor.
    I'm hot and cold on it. Was nice having a spot to have a drink while waiting for the doors to open... but, just 1 merch stand... and price of drinks.... damn
  16. Feb 5, 2023 at 2:48 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I was in the city last night for the Bert Kreischer show. I paid the extra cash to be in the North Station garage rather than trudge through the city. It was freezing
    I was resetting tire pressure in the Jeep when I noticed one sidewall has enough wear I’m having the tire shop take a gander at to make sure it’s safe, I’m feeling 50/50. I’ve been pretty diligent about pressures and load, rotate every 5,000, just under 34,000 miles of use, 8/32nds of even tread, 4019 date code. I’m miffed if I’m going to be on the hook for a new set.
    I’ve heard Cooper has some sidewall issues, so we will see what happens with a pro-rate to help. I’ll probably cross-shop the Michelin CrossClimate 2 vs the Nokian WR G4 and see which is less on the Jeep.
  17. Feb 5, 2023 at 3:11 PM
    ABA180
    East Bridgewater MA
    Solid bill there, any one of the 3 alone would get my money. That said it worked out I didn't buy tickets back when they came out.
    I'll go there to see a show but that's it, never really had a slight bit of luck at the slots or felt there.
    Definitely wise especially this weekend. Where was the show at?
    Not sure right now but Copeland has had decent prices on tires before, got mine there just because they had the best price on them.
  18. Feb 5, 2023 at 3:19 PM
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Satoshi grill, 3rd Gen TRDOR Bucket Seats, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, LCE Balance Shaft Delete, ECGS front diff bushing, TRD Sport LSD rear diff, Diode Dynamics SS3 Sport fog lights, Stainless Steel Brake-lines, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, Bilstein 8112 front Coilovers w/ rear Bilstein 5125's/IronMan lift leaf springs, Archive Garage Hammer Hangers, JBAs HD UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, 2019 Steering wheel, color matched door handles
    What type of wear on the sidewall? Dry cracks? Usually that is the only damage I see from older tires (2017 and older now). The only other thing I see is when people drive on them almost flat (<5psi) is a ring around the whole sidewall, and the inside of the tire/sidewall will have chewed itself down to the cords, but again, you would see that ring on the outside, and it could also lead the sidewall bubbling.
  19. Feb 5, 2023 at 3:26 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    TD, I like working with Kenwood as they usually match whatever best deal I can find.
    The lowest pressure I ever remember any tire on the truck being was 27-29 psi, anytime my wife got a light she’d limp it home (maybe 5-6 miles), I’d fill it and get it repaired. I can’t even be certain that tire was ever low. Last night was probably the lowest they’ve been at 30 psi cold.
  20. Feb 5, 2023 at 4:20 PM
    nickonfire700
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    That is not good looking! I can see some light dry rotting above that line/crack, but that crack is definitely something to worry about. As long as you don't take it anywhere for long distances at highway speeds, I would think that tire would hold up okay, but with higher temperatures, something might fail. I would take it to you whoever you bought it from to see what they think.
    Tomorrow when I head into work I will take some pictures of a tire someone ran very low on air, and show what type of damage it can do.
