New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Feb 14, 2023 at 9:51 AM
    Odlcjro01
    Odlcjro01 Well-Known Member
    Lee
    Rhode Island
    2021 Tacoma MGM DBC SR5
    LT265/75R16 tire, side steps
    We just had to replace the zone valve on our system. It seemed difficult until I realized they just turn to be removed and then turn the new one on and connect the wires. Still need to replace the controller though. The small piece of wood holding the circuit together is getting old. You realize it moved when you are cold because the heat didn't come on. Will have the heating company install that though.
    tacobell007[QUOTED] likes this.
  2. Feb 14, 2023 at 9:52 AM
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    It always surprises me how many people will mess with all kinds of things but electrical is the hard limit, nerve wracking sure but just take your time and remember the basics and you'll be fine
  3. Feb 14, 2023 at 9:54 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    RI - not MA, would need to be licensed in RI, I think. I have other electrician friends too but none are in RI.
    (to be on the up and up)
    Brownmatthall likes this.
  4. Feb 14, 2023 at 9:56 AM
    Brownmatthall
    2016 TRD OR DCSB
    Yeah that is the buzz killer for sure :anonymous:
  5. Feb 14, 2023 at 9:59 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    My transfer switch nearly was :bananadead:
  6. Feb 14, 2023 at 10:04 AM
    Brownmatthall
    2016 TRD OR DCSB
    Just don't open ever again :anonymous:
  7. Feb 14, 2023 at 10:25 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Yeah, I'm pretty decent with electrical. Electrical I can also just disconnect or flip a breaker. Plumbing I might not have a shutoff where the problem is, so I need to keep the whole house shut off.
    I'm working on doing minor improvements to my basement to make it less horrible. I plan to put a wall up to separate the unfinished/utilities side from the "finished" side. I started framing in around the staircase because that was a mess of cut off studs and destroyed sheetrock. I had boxes of cedar closet planks left from the previous owner, so I decided to use them for this purpose:
    I'm going to add another outlet at switch height in the center of the wall in case I decide that's the most logical spot for a TV. Otherwise, I'm happy with how it looks.
    The floor is actually from a basketball court. It's 2" thick foam type material with a thin fake wood layer on it. I figure it's perfect to get some elevation off the concrete and I can use it as a base. I'll either carpet or put laminate/vinyl planks over it later.
    AllTacosFloat, Pugga, JeffB and 6 others like this.
  8. Feb 14, 2023 at 10:34 AM
    Roody
    Roody Well-Known Member
    Ross
    SW CT
    GX460
    Easy for you to say! Haha
    CTSpruceMica likes this.
  9. Feb 14, 2023 at 10:54 AM
    Brownmatthall
    2016 TRD OR DCSB
    You get used to the zaps it's fine :D
    Roody[QUOTED], HisDad and GarlicFarts like this.
  10. Feb 14, 2023 at 11:00 AM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    My Father in Law was a Master Electrician and contributed to a couple of versions of the National Electrical Code. When we first got the house back in 1980 he was young and spry enough to help me with a lot of wiring. He taught me a lot, but it wasn't until years later that I truly appreciated it.
    He was so good that he got a deferment during WW 2 to work at the Watertown Arsenal wiring the equipment used to make artillery.
  11. Feb 14, 2023 at 11:06 AM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    That's pretty cool! My FIL is a retired firefighter that knows how to do pretty much everything house related which is nice to have and learn from
    CTSpruceMica and Brownmatthall like this.
  12. Feb 14, 2023 at 11:17 AM
    HisDad
    Texas at last
    I would guess that your FIL is from the generation of firefighters that all had "side jobs." Groups were pretty tightly knit and they often helped each other at their side jobs on their days off.
    I interviewed for a fire job, which I ended up turning down. On the application there was a question about what licenses I had. Plumbing, electrician, carpenter, and so on. I used to joke that they'd hire and assign guys to specific groups based on what openings they had. ;)
  13. Feb 14, 2023 at 11:33 AM
    tacobell007
    Drew
    Western MA
    Yes I would say so. He definitely knows his way around a house
    HisDad[QUOTED] likes this.
  14. Feb 14, 2023 at 11:34 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    interesting to hear everyone's do's and do nots. I like electrical, must be the engineer in me but i enjoy the tidiness. I follow code to the best of my knowledge, and i just dont get as good of a feeling when plumbing as far as what not to do. I do minor repairs in plumbing, but feel like there is some black magic in there sometimes.
    Brownmatthall and tacobell007 like this.
  15. Feb 14, 2023 at 11:41 AM
    HisDad
    Texas at last
    The friend who helped me with the electrical could also do plumbing, but his son ended up as a plumber so I just called him instead. My friend was an electronics "engineering technician" that worked on high tech electronics the last 25 or so years he worked. Before that he did about 100 things in electronics going back to the late 1950s. He had an intuitive grasp of electronics that was amazing. People he worked with whom I met over the years described him as brilliant.
    When we did electrical work he was meticulous about following the code and doing everything absolutely right.
    tacobell007 likes this.
  16. Feb 14, 2023 at 7:12 PM
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [ED] Entune Audio Plus [TO] V6 Tow Package
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass and Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All Weather Floomats (summer).
    I heard that Moosehead is still virtually ice-free at this time. Is that the case? My son goes ice fishing up there with his friends and snowmobile around this time
    every year and he hasn't gone up yet. His buddies up there told him to hold off coming up. He's up near Winnipesaukee and says it is the same, even near the shore you break right through. Not
    sure about Rangeley but I imagine it's probably marginal up there too?
  17. Feb 15, 2023 at 2:00 AM
    tacobell007
    Drew
    Western MA
    I would say so since it's been getting above freezing during the day, at least at night it's below freezing from what I've seen. My family owns a cabin in Eustis
  18. Feb 15, 2023 at 5:11 AM
    GarlicFarts
    Lil Rhody
    https://www.maine.gov/ifw/fishing-boating/fishing/fishing-report.html
    These were updated around Jan 30th. Just looking at Rangely, weather seems to have warmed up.
    https://www.youtube.com/watch?v=lh78tE6kJfA
  19. Feb 15, 2023 at 7:15 AM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    If I mess up plumbing I get wet. If I mess up electrical I can kill myself. Before I do any electrical I have to make sure I understand exactly what I am doing or I won't touch it.
  20. Feb 15, 2023 at 7:33 AM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    Exactly, I can see water leak. Those pesky electrons...not so much
    ACEkraut[QUOTED] and tacobell007 like this.
