New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. May 9, 2023 at 4:10 PM
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    Noted, and thank you.
    Ah, I hadn't actually taken that into account.
    Just the rear? Or front?
    Biggest hurdle is actually properly compressing, and swapping the coils, and I have my old stuff away, so, I don't even have anything to stuff under there...
    CTSpruceMica likes this.
  2. May 9, 2023 at 4:18 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    I have a spring compressor. Worked for 6112s and no one died. Still sketchy.
    rear lines would need to be extended or they become limit straps
    edit: front should be fine
    CTSpruceMica and tacobell007 like this.
  3. May 9, 2023 at 4:39 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Claw spring compressors scare the dogshit out of me. I think I have 6112s in my future. Ever do the bigger coils "on truck" using the weight to compress?
  4. May 9, 2023 at 4:47 PM
    AllTacosFloat
    Boston ish
    Yes, way less sketchy imo. I think it should be a set of 3 instead of 2.
    I think mine would be fine on 887s after seeing them work on 650# springs
    how did you make out with your caliper bolts?
  5. May 9, 2023 at 4:52 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Rounded off the first upper softline flare nut with a brand new decent flare wrench and said "F this" and took it to a shop. Shop was a mistake for other reasons, but dude said he had never seen the caliper bolts fight like that.
  6. May 9, 2023 at 5:10 PM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    I had the loan of one when I needed it way back when. I hated using it because like you, they scared the hell out of me.
  7. May 9, 2023 at 5:18 PM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    Should have seen me put spacers on the infiniti last weekend...... rented compressors but could only use one as it wouldn't fit..... talk about sketch
  8. May 9, 2023 at 5:19 PM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Just the rear.....fronts are fine. Last time we did my 6112's, we had 3 of the clamp compressors on each spring. Also used a ratchet as well instead of an impact......a lot less sketchy.
    CTSpruceMica and deanosaurus like this.
  9. May 9, 2023 at 5:53 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Just rears unless you want to give a stiffer pedal feel with front stainless lines as well. Make sure you get the Teflon lined ones so you can pinch them off if needed. I had/have a guy that will come out and make lines on the spot as needed as well if you want
  10. May 10, 2023 at 7:48 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Got the deed to 17 acres in my hand. Headed out to find the best place to put up a cabin and see how far into the woods I dare creep with the truck.
    BadDNA, Merling, Chasespeed and 11 others like this.
  11. May 10, 2023 at 5:49 PM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    If anybody wants to try out their new suspension just take a ride to Bellingham. The paved part just south of the center is worse than the gravel part near the middle school!
  12. May 11, 2023 at 1:53 AM
    AllTacosFloat
    Boston ish
  13. May 11, 2023 at 1:56 AM
    tacobell007
    Drew
    Western MA
    Thanks John! :cheers:
  14. May 11, 2023 at 2:06 AM
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
  15. May 11, 2023 at 2:25 AM
    Chasespeed
    In the woods...
    2018 TRD OffRoad
    Some stuff
  16. May 11, 2023 at 2:30 AM
    tacobell007
    Drew
    Western MA
    Thanks guys!
  17. May 11, 2023 at 2:41 AM
    jpereira2
    Massachusetts
    Happy birthday!
  18. May 11, 2023 at 2:41 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Happy Birthday, Drew! :rockband:
  19. May 11, 2023 at 3:31 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    Happy Birthday Drew :hbd:
    tacobell007 likes this.
  20. May 11, 2023 at 4:10 AM
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Satoshi grill, 3rd Gen TRDOR Bucket Seats, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, LCE Balance Shaft Delete, ECGS front diff bushing, TRD Sport LSD rear diff, Diode Dynamics SS3 Sport fog lights, Stainless Steel Brake-lines, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, Bilstein 8112 front Coilovers w/ rear Bilstein 5125's/IronMan lift leaf springs, Archive Garage Hammer Hangers, JBAs HD UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, 2019 Steering wheel, color matched door handles
