New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. May 11, 2023 at 2:14 PM
    dc welding
    dc welding Well-Known Member
    Dan
    Swansea Mass
    15 DCSB TRD Sport BRM / 2002 AC SR5
    tacobell007 likes this.
  2. May 11, 2023 at 7:55 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Yessir, it will happen one of these days lol.
    Thanks Joe!
    Thanks Dan!
  3. May 12, 2023 at 2:02 AM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    I cut through my old one recently with the sawzall and open ports without issue. Did see a few articles showing what not to do though!
    CTSpruceMica likes this.
  4. May 12, 2023 at 2:03 AM
    Clark27
    Springfield, MA
    2015 Lexus GX460
    Also happy belated Drew @tacobell007
    Hopefully enjoying your day off!
  5. May 12, 2023 at 4:03 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Yep. Aleve lives in the rucksack.
    I'll figure that out once the plum trees are in.
    vssman[QUOTED] and CTSpruceMica like this.
  6. May 12, 2023 at 4:28 AM
    tacobell007
    Drew
    Western MA
    Thanks Chris! I will definitely enjoy the day off
    CTSpruceMica and GarlicFarts like this.
  7. May 12, 2023 at 6:11 AM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Happy belated @tacobell007 !
    I've been swamped all week, lurking but not posting. I had my PDR done. It's better than it was, not 100% but for $100 I suppose I should be pleased. My perfectionist streak is kicking in so I'm pretty sure nothing short of a fender would really "fix" it for me. It's one of those if you're catching light and reflections you can tell it's not 100% but if you just look at it I'd have to show you what to look for. I suppose at the end of the day it's an almost seven year old daily driven truck.
    Water pump #5 is in the Jeep. I love the upsell that dealers try. I fundamentally get that's their source of income, but at least base it in some fact. When I had the original pump done at 60K I did a coolant flush. When it was replaced two more times in the next three months they didn't mention anything about coolant, just changed the pump and gave it back. This time I get the message oh we have to flush the coolant as part of the process and it's going to be $270. I politely explained that the coolant was flushed 10,000 miles ago. They came back with well there could be something in the coolant causing the failure. I politely reminded them the coolant wasn't flushed the last two times and asked them to replace the pump only.
    Like, if you're going to upsell, be consistent. Maybe if I didn't know how to read the manual I'd have replaced it every time, but c'mon. The coolant is a 10 yr / 100K fluid anyways. Such is life, it's back, it was free, so I'll count that as a win.
  8. May 12, 2023 at 6:33 AM
    tacobell007
    Drew
    Western MA
    Thanks Mike!
  9. May 12, 2023 at 7:46 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Who'd you use for PDR? I have a spot I'd like to get done, haven't started even researching yet though.
  10. May 12, 2023 at 1:27 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Stone wall around the whole plot
    Pugga, jpereira2, Chasespeed and 2 others like this.
  11. May 12, 2023 at 2:35 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    “Plot”? A cemetery?? :D
  12. May 12, 2023 at 3:01 PM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    New England is covered with stone walls. Most of them date back to the Colonial era when most of land was covered with farms. The farmers would have to clear their fields of trees and big rocks before they could start to plant. The wood went to buildings and fire wood. The stones were moved to the edges of the field and walls were built. Often they marked the property lines between neighboring lots.
    There's one in my neighbors back yard that trails off into the conservation land behind our houses.
    It used to take a lot of acreage to grow enough food to feed people. Now modern farming techniques increase the yield per acre so smaller farms can grow more food so not as much farm land is needed.
    It was backbreaking work since it was all done by hand, maybe with horses, oxen, or mules to move the heavy stuff.
  13. May 13, 2023 at 4:16 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    Built a spot for a chainfall yesterday, picking up the mill today.
    Overbuilt or under-built for 800lbs?
  14. May 13, 2023 at 4:32 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    800lbs is probably okay but my concern is that the vertical supports don’t run down to the floor. Now you’re relying only on the shear strength of the fasteners in the wood. Any reason why you didn’t run the beam across the top of the timber frame?
    Merling likes this.
  15. May 13, 2023 at 4:48 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    The span was 12 foot long and I had 12 foot 2x10s.
    As for not running them all the way to the ground yeah that would be the better way to do it but I would have had to move a bunch of wiring. I used screws/lags for clamping then a bunch of nails sense they’re better in shear. Hard to see but there is 2 2x10s running across with the diagonals going into the middle.
    vssman[QUOTED] likes this.
  16. May 13, 2023 at 7:19 AM
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    Dude that's beautiful.
    That and I wish I had a barn/shed that big.
    Brownmatthall likes this.
  17. May 13, 2023 at 8:50 AM
    bucktales
    bucktales *Retired* curmudgeon
    Litchfield County Ct.
    2012 TRD Sport AC / 2014 FJC/ 1972 Rally Nova
    Most of New England was clearcut and because of that, Winters pushed up all those stones every year.
    Looked pretty labor intensive hauling all those stones with oxen and by hand for years on end.
    I've done a bit of research on stone walls in New England. Pretty cool stuff.
    I've been following this guy since he started making videos...
    https://www.youtube.com/@GMMD
    He hunts mostly in Vermont and is interesting to see what he pulls out of the ground near those walls and cellar holes.
  18. May 13, 2023 at 9:58 AM
    HisDad
    Texas at last
    From my Forsythia clearing project a few years ago I became convinced that roots like to grow around rocks. Just about every larger bush I cleared had a big rock right in the center of the root network.
    Those rocks were probably 50-75 pounds and it was exhausting to dig one or two a day out of the ground. I can't imagine what it would be like to clear a field with 100s of them in it. That would be AFTER cutting down the trees and then digging up the stumps.
    NOTE: Maybe they got so much accomplished because they didn't have cell phones, DVDs, Facebook or YouTube! ;)
    bucktales[QUOTED] likes this.
  19. May 13, 2023 at 12:30 PM
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    I agree. I would at least run a 2x to the floor under the small piece of 2x that is attached to the column to transfer some load to the ground and not rely 100% on fasteners.
  20. May 13, 2023 at 2:35 PM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    @TacoTuesday603
    I think you'll be ok for only 800lbs. I think of the way decks are made like the one on my mother's house. We've had 20-25 people on her wrap around deck and it holds fine.
    AllTacosFloat likes this.
