New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Aug 2, 2023 at 5:34 AM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    I've had luck with Moog bearings. They use NSK bearings like factory
    Chasespeed likes this.
  2. Aug 2, 2023 at 5:51 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    I only watched the 1st minute or two but I like it. It should have the Tundra V6 engine options though.
    I really want that shipping container with the retro stripes!
  3. Aug 2, 2023 at 5:59 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I had pretty terrible luck with Moog u-joints. The tolerance and fitment was awful so that turned me away from them as a company. If they can't get their tolerances in check, I wouldn't want them for a critical bearing.
    tacobell007[QUOTED] likes this.
  4. Aug 2, 2023 at 6:11 AM
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    I'm hoping it replaces the niche that the 4r occupies now and they dumb the 4runner down for us peasants :spy:
  5. Aug 2, 2023 at 6:14 AM
    tacobell007
    Drew
    Western MA
    Yea but I don't think they actually make the bearing, I think they just use the NSK bearing. Now their unit bearings with the flange, fair, since they may have manufactured the flange and the press fit diameter that goes into the ID of the bearing
    Pugga[QUOTED] likes this.
  6. Aug 2, 2023 at 11:36 AM
    Merling
    Merling Well-Known Member
    James
    NH
    2021 Black Tacoma TRD OR
    RCI IFS Skid Eibach Stage 2 Explore Overland Sliders
    IMG_4030.jpg Hour or two before high tide then riding the change of tide back at Hampton salt marsh is most excellent. If anyone wants to go I will happily meet you for a paddle
    Chasespeed and tacobell007 like this.
  7. Aug 2, 2023 at 12:04 PM
    Merling
    James
    NH
    Closed Flow Air Chuck 4 Tire Inflation/Deflation System 4 Way Tire Inflator Deflator 4 Way Tire Pressure Chuck Work Compatible with All Air Sources
    https://a.co/d/hIuvm3y
    Thoughts?
  8. Aug 2, 2023 at 12:12 PM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Dang - about 2 hours away :( I have a sweet spot down here in RI too! One fresh, one brackish.
    We gotta set up a paddle day. @AllTacosFloat I think we tried to last year and it fell through.
    We could do the Somerset Airfield/Resevoir too, can camp there the night before/after. It's an open spot though, you could get stuck next to someone with a generator all night :rant:
    I want one of those, badly. I should get one soon. That one looks fine, I like that it has the schrader valve connection, then you can go to any gas station hookup and use it too. There seems to be a couple "tiers" of those, with the lower tier being a slap-dash cheap approach, and the higher tier being similar to that one, with more robust hoses and fittings.
    AllTacosFloat likes this.
  9. Aug 2, 2023 at 12:15 PM
    Pugga
    Massachusetts
    Why? I'm not seeing what you gain by that, still going to take the same amount of time to inflate 4 tires. I've also not had good luck with those types of fittings actually sealing on a valve stem, one slightly loosens and you're pissing into the wind trying to fill your tires. Personally, I have no use for something like that, I can see it being more frustrating that useful. Single air line, one tire at a time for me.
  10. Aug 2, 2023 at 12:16 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    I started by building that, then didn’t want the pile of air lines. I basically built that but hid it in the frame.
    I have plenty of air line if you don’t mind yellow.
    Chasespeed and GarlicFarts like this.
  11. Aug 2, 2023 at 12:21 PM
    AllTacosFloat
    Boston ish
    You can air up or down all 4 at the same time.
    The valve stem is the pinch point for the air, so if the compressor is up to it it will fill all 4 faster than going from one tire to the next.
    I’m usually done airing up and helping others that are doing one at a time.
    tacobell007 and GarlicFarts like this.
  12. Aug 2, 2023 at 12:30 PM
    Pugga
    Massachusetts
    What chucks do you have that actually seal to the valve stem? I've never had a connection like that reliably seal to the valve stem, I usually have to keep pressure on it. I understand the concept, I just can't see it working in real life because of that.
  13. Aug 2, 2023 at 1:04 PM
    AllTacosFloat
    Boston ish
    These, I’ll look for the link but @crashngiggles recommended them
    Edit: these
    https://www.amazon.com/Haltec-H-526...d=1691006724&sprefix=air+chuck,aps,184&sr=8-3
  14. Aug 2, 2023 at 1:16 PM
    Brownmatthall
    2016 TRD OR DCSB
    I just bought this one last week https://www.etsy.com/listing/1244726687/ez-air-system?ref=yr_purchases
    The green color is flexzilla hose so I know that's pretty good at least, and for the price it's about what it'd cost in material to diy so I said screw it. If a component fails I'll just slowly upgrade it, but having the upfront cost out of the way is nice. Arb twin can easily pump up all 4 and I'm saving the downtime of switching tires, airing down should be nice too since pressure equalizes and I can check em from one spot :D
  15. Aug 2, 2023 at 2:08 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
  16. Aug 2, 2023 at 2:56 PM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Thank you sir
  17. Aug 2, 2023 at 2:57 PM
    crashngiggles
    Jared
    They work very well actually......never had an issue. They stay on without any issue.
  18. Aug 2, 2023 at 3:03 PM
    crashngiggles
    Jared
  19. Aug 2, 2023 at 3:04 PM
    crashngiggles
    Jared
  20. Aug 2, 2023 at 3:08 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Cool!
