New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Sep 29, 2023 at 9:08 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    mach1man001[OP] likes this.
  2. Sep 29, 2023 at 9:13 AM
    InCogNeatOh Parts
    InCogNeatOh Parts Well-Known Member
    im still trying to sort thru the info dump that day.
    that being said, I plan to order a kit this winter and get stuff made up. If others are interested, I wonder if we can get a big ass kit and split it up
    CttAznRanger[QUOTED] likes this.
  3. Sep 29, 2023 at 9:16 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    My setup is mostly all good but I'm down to either attend or host something. Might be intelligent to do it in the fall though.
    Brandons wiring needs it.
    CttAznRanger likes this.
  4. Sep 29, 2023 at 9:20 AM
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    Yeah. I might end up buying a large assortment and make a separate harness to get it cleaner. Get the wires routed inside or wherever they need to go and whatnot.
  5. Sep 29, 2023 at 9:22 AM
    CttAznRanger
    Brandon
    Boston, MA
    On a random note, anyone end up installing extended length wheel studs for spacers? If so, what did you get exactly?
    I ended up throwing the 1.25” spacers that I got from John, and it only engages about 50% of the nuts it comes with. Not a fan, but it has worked so far.
  6. Sep 29, 2023 at 9:24 AM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    What brand spacers? My spidertrax I had on the tacoma and the ones on my 4runner thread all the way to the end of the nut
  7. Sep 29, 2023 at 9:27 AM
    CttAznRanger
    Brandon
    Boston, MA
    Some Amazon special ones I believe.
    tacobell007[QUOTED] likes this.
  8. Sep 29, 2023 at 9:40 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If that happens, I'd be down. I'm pretty competent when it comes to electrical and would be happy to help and maybe pick up a few tricks and tips myself. I've quite a few things on all my trucks over the years. No fires yet, but i do carry a fire extinguisher :anonymous:
  9. Sep 29, 2023 at 10:18 AM
    CttAznRanger
    Brandon
    Boston, MA
    Another mod I need, fire extinguisher bracket and fire extinguisher, lol.
    Pugga[QUOTED] and tacobell007 like this.
  10. Sep 29, 2023 at 10:21 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    I don't have anything bigger than 4 pins, but I tell you what - if someone buys one of those assortment kits I linked in the last mod day PM, I'll do a video on how DT/DTP/DTM work, pin size/compatibility, and various looming techniques.
    InCogNeatOh Parts likes this.
  11. Sep 29, 2023 at 10:31 AM
    tacobell007
    Drew
    Western MA
    Ah okay. Trail Gear are the cheapest I've ran in the past and those were still good
  12. Sep 29, 2023 at 10:42 AM
    GarlicFarts
    Lil Rhody
    The 3.3 is an NA V6 that is probably one of the best engines ever made. The complaints it's had: Overheating when towing over 8k (the limit is 8.2, people who are overloading that are complaining....). Otherwise, yee haw. It has all the power I'd want or need, and it's cheaper than the 2.7. It has zero turbos instead of two. Not that the 2.7 isn't relatively reliable, but the 3.3 has that much less moving parts. It's the one used by every fleet out there, because it's not reliable as anything, it's more reliable than anything else out there. Not trying to brown-nose the Ford badge with this, but that's an amazing engine, and the extra cab space in an F150 vs a Tacoma would be nice.
    I don't want to be towing what the 3.5 can tow, I don't need the grunt of the 3.5/5.0, essentially just a bit more cab space than the tacoma - and the 3.3 gets me there :rofl:
    Though to be fair, the base of the base 3.3 V6 w/ 4x4 F150 is 45k (super cab, not the single cab, that MIGHT be cheaper, to be fair). TRD Pro Tacoma is about the same. At least on the "build your own" options on both websites. An SR5 long bed is 40 (full cab, same as above, the extended cab tacoma might be a bit cheaper, but I need that cab length for sleeping in :D)
    Dunno. Still 130k ish off from even considering pitching this thing, 230k ish before I pitch it (gone at 300k, might consider at 200k). I'm super spartan with what I want, relatively. A sunroof would be nice now that I have the cab sleeping setup, but otherwise a gas and brake pedal is all I need. All the other stuff is aftermarket anyway (roof racks/kayak racks, bed bars, bike mounts, etc etc).
  13. Sep 29, 2023 at 10:55 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    Anybody at work want an aluminum knock off skid plate? Guy at work didn't mount it as it requires removing the runner braces or whatever they are called and he didn't want to do that. $180 is what he's asking.
  14. Sep 29, 2023 at 11:26 AM
    Pugga
    Massachusetts
    Obviously, this being a Toyota forum, lots of people here have great experiences with their Tacomas, but there's an ass for every seat. Personally, I've had better luck with Ford than I have with Toyota (I've owned and maintained 6 Ferds in my lifetime and 2 for my wife). My old man had the 7.3 (diesel) when it was current and had lots of issues with it, he'll never own another Ford. A lot of it just comes down to personal experience.
    I agree, I think COVID production and quality issues are plaguing Ford now. I wouldn't buy a new truck now unless I really needed to, they've had some significant quality issues in the past 2 years, especially with the feature-rich trucks.
    I mean, mine's still in the box it came in just tucked under my seat. I guess you could say i nailed that mod? It's been a very problem free mounting solution so far :notsure:
    Brownmatthall likes this.
  15. Sep 29, 2023 at 11:31 AM
    InCogNeatOh Parts
    It’s about dropping the few hundred it might possible cost. Need to get the checkbook back up to a comfortable level
  16. Sep 29, 2023 at 11:33 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    True, seems to be common with all of us. We can do wiring in the snow.
  17. Sep 29, 2023 at 11:48 AM
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    Not hard... just time consuming. I make as much of my own as possible.....
    Me 6.0 surprisingly, only issues are due to sitting. ..
    Nope. Nothing good happens in the snow.... too cold. Too wet. Like today.....
  18. Sep 29, 2023 at 11:58 AM
    GarlicFarts
    Lil Rhody
    I thought I had pictures but I didn't find any. I went through Michigan in Oct 2021. Right off the highway was fields, FULL of trucks. I'm talking thousands. Fords, GMs, all of them. Waiting for chips/finishing touches. Those trucks were sitting for months and months on DIRT fields.
    Mice, vines, bugs, you name it. MY 21 and 22 from the big 3 are a big NO from me after seeing that.
    ^^^ :thumbsup: After my last trip in October I am doing an oil change, making sure my filters are good, then the hood stays closed until April :)
  19. Sep 29, 2023 at 12:04 PM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Im hoping skids for and bumpers this winter. But house projects are getting in the way.
  20. Sep 29, 2023 at 2:50 PM
    tacobell007
    Drew
    Western MA
    The local dodge dealerships park their trucks on dirt, must all come "pre-rusted"
