New England Mod & Meetup Renaissance group
Discussion in 'North East' started by AllTacosFloat, Apr 14, 2022.
  1. Oct 1, 2022 at 9:35 PM
    #2041
    Merling
    Merling Well-Known Member
    James
    NH
    2021 Black Tacoma TRD OR
    RCI IFS Skid Eibach Stage 2 Explore Overland Sliders
    Thanks. I'll definitely let you know how it goes
  2. Oct 2, 2022 at 6:08 AM
    #2042
    AllTacosFloat
    AllTacosFloat [OP] If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    Photo dump from overland expo with @crashngiggles and @MikefromCT. Had a blast and saw some really cool and really crazy stuff
  3. Oct 2, 2022 at 6:24 AM
    #2043
    Rocket23
    Rocket23 Licensed Dynacologist
    Rocket
    Pennsylvania
    2019 sr5
    The list is growing.
    Nice pix. I caught a cool you tube vid 4 guys 3 trucks into Canada then back to Oregon. Pretty good editing
    jpereira2 likes this.
  4. Oct 2, 2022 at 7:59 AM
    #2044
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    Whatever day your welding buddy likes, ill make work no problem @AllTacosFloat. Cmc and cam tab bead, right? Also, it seems like the shop is fighting @Merling on this install, id be down to stop by somewhere after work this week and flip them around if you are John :D each of us takes a side and have him squared within the hour?
  5. Oct 2, 2022 at 8:25 AM
    #2045
    Merling
    James
    NH
    Should know by tomorrow.
    with the way my work is, I would get home at like 630 then drive to alltacosfloat by 7? I could take a day off and come earlier if need be though. Hopefully they’ll just fix it tomorrow.
    AllTacosFloat[OP] likes this.
  6. Oct 2, 2022 at 8:43 AM
    #2046
    AllTacosFloat
    Boston ish
    :yes:
    :fistbump:
    Edit to say yes on cmc and tab gusset.
  7. Oct 4, 2022 at 2:50 PM
    #2047
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Good news! Front and center diffs are still jacked up with the skid plate on BUT I should be able to do ATF! Just watched a video on where everything was, it's all way further back than I thought. So, that will probably happen this week.
    Crap. Now I have to do that this week....
    Just doing a drain and fill nothing special. Probably get into a 30k drain and fill pattern after this.
  8. Oct 4, 2022 at 6:47 PM
    #2048
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    Sounds easy. Prolly isn’t.
    GarlicFarts[QUOTED] likes this.
  9. Oct 4, 2022 at 8:05 PM
    #2049
    GarlicFarts
    Lil Rhody
    Guarantee I'll be able to fill a swear jar within the first 7 minutes.
  10. Oct 5, 2022 at 1:57 AM
    #2050
    AllTacosFloat
    Boston ish
    Just need a bigger jar:cookiemonster:
  11. Oct 5, 2022 at 5:10 AM
    #2051
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    That’s pretty good.
  12. Oct 5, 2022 at 5:37 AM
    #2052
    GarlicFarts
    Lil Rhody
    Nah shouldn't be bad - only ~3 years on it. I know there are 3 things I need to get out. Fill, overflow, then drain. I have the hand pump already from doing my wife's camry (CVT :puke: ) a while back. I think the worst part will be needing a second drain pan and getting rid of the damn stuff. I still have the used TWS crap from the camry, I haven't been active in getting rid of it but I know I called one or two places and they don't take it. My town takes used oil so that's nice - engine and diff oils go away easy.
  13. Oct 6, 2022 at 2:54 AM
    #2053
    AllTacosFloat
    Boston ish
    My Google fu is weak today... looking for Keyed power in the engine bay fuse box to add a fuse for switch panel.
    Is efi OK?
    @crashngiggles , what did you do?
    :help:
  14. Oct 6, 2022 at 5:28 AM
    #2054
    GarlicFarts
    Lil Rhody
    OH. NO.
    I tried this. There are 2 keyed power (in the turd gens). One gave me hyperflash, which was meh. I have so much random lightning shenanigans, who knows. Can't fault that. The second one I tried lit up my dash like a christmas tree.
    Wait. No. Both in the engine gave hyperflash, the first one I tried in the cab did the christmas tree. I think I used ABS. I didn't look which it was, I just dropped it in :rofl:
    Check the cab first - if you have any open slots in your fuse panel, they'll be keyed power and perfect for switch panels. That's where mine is. If you don't have a sunroof, that's a perfect one for it. You'll have keyed power going to it, but nothing on the circuit. Drop an add-a-circuit through it and you're golden.
    There are some constant power in there though, my dash cam is on one now. Forget which circuit it is.
  15. Oct 6, 2022 at 5:33 AM
    #2055
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    I think I wasn't able to find anything in the engine bay. Here's my interior fusebox, any of these should work.
    And I know I could combine all of these into 1 but I got lazy so it looks cancerous.
    AL9nZEUGvJOVj_qPiYP1mrJ2k8NIzqlfHd0VHk1__51312d8e8d9a8c02c2c44435c787de9a9f0c624f.jpg
  16. Oct 6, 2022 at 5:34 AM
    #2056
    AllTacosFloat
    Boston ish
    Sunroof sounds like the one.
    Perfect. Thanks:hattip:
  17. Oct 6, 2022 at 6:46 AM
    #2057
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    I tapped into the ACC Fuse. 7.5 AMPS, but mine was inside the truck, not in the engine bay.
  18. Oct 6, 2022 at 6:46 AM
    #2058
    crashngiggles
    Jared
    @AllTacosFloat This is the same one I used.
  19. Oct 6, 2022 at 7:09 AM
    #2059
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    If you are going to add a new fuse box, did you want all them controlled by keyed power?
    If that doesn’t really make a difference, I would put it direct to battery via a switch on the interior to control it. But that’s cause I’m lazy and don’t want to tap into the existing fuse box, lol
  20. Oct 6, 2022 at 7:39 AM
    #2060
    AllTacosFloat
    Boston ish
    Yeah, being for a switch panel I figured I would put everything on the switch panel for stuff I do not want to leave on. So I'm okay with needing to put the key in to use certain lights. Most importantly I don't want anything to get turned on for left on without the truck running
