New England Mod & Meetup Renaissance group
Discussion in 'North East' started by AllTacosFloat, Apr 14, 2022.
  1. Oct 23, 2022 at 5:21 PM
    #2221
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Didn't look at the link but if you don't have a pump, get it in the bags. 1000x easier. Especially the front diff.
    Also I'm not going to advise reuse of hardware but I will just say that a new crush washer is the Toyota maintenance routine. Many have done a successful oil change with reusing the washers. :spy:
    AllTacosFloat[OP] likes this.
  2. Oct 23, 2022 at 5:32 PM
    #2222
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    MikefromCT[QUOTED] likes this.
  3. Oct 23, 2022 at 5:49 PM
    #2223
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
  4. Oct 23, 2022 at 5:56 PM
    #2224
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    Yeah they really should change that...though I'm sure there's also somebody somewhere wondering why their Google search took them to a muffler shop
  5. Oct 23, 2022 at 5:57 PM
    #2225
    AllTacosFloat
    AllTacosFloat [OP] If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    :rofl::rofl::rofl:
    I did like 3 times
  6. Oct 23, 2022 at 6:09 PM
    #2226
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    You sound disappointed
  7. Oct 23, 2022 at 6:19 PM
    #2227
    AllTacosFloat
    Boston ish
    1st wtf!
    2nd huh
    3rd oh
    Little disappointed :rolleyes:
  8. Oct 23, 2022 at 7:50 PM
    #2228
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Lou's in Brockton just replaced part of the main pipe in mine...about an hour or less, $150, sounds fine.
    Haha..the original exhaust in my truck lasted longer than the original frame.
  9. Oct 24, 2022 at 4:50 AM
    #2229
    Rocket23
    Rocket23 Licensed Dynacologist
    Rocket
    Pennsylvania
    2019 sr5
    The list is growing.
    Think of our driveline like a big canfer joint. That might help.
  10. Oct 24, 2022 at 4:51 AM
    #2230
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    I hope the pup is doing better
  11. Oct 24, 2022 at 5:50 AM
    #2231
    Merling
    Merling Well-Known Member
    James
    NH
    2021 Black Tacoma TRD OR
    RCI IFS Skid Eibach Stage 2 Explore Overland Sliders
    She’s still acting herself, just a bit more licking to soothe.
    There was a snaggle before when it first happened but it’s broken off so now that tooth is just shorter but I think some dentin or something is exposed so I still want it out.
    Just very grateful she still seems playful, crazy self.
  12. Oct 24, 2022 at 6:07 AM
    #2232
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
  13. Oct 24, 2022 at 7:19 AM
    #2233
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Agreed on both......I have the pump anyway but yes, the bags are 100% better.....unfortunately they are more expensive and harder to find. You are also correct in the crush washer aspect. I have reused them in the past but it is best to make sure that people know the proper way of doing it and the things that they will need to do it the proper way first and then make their own determination afterwards. It all honesty, if a person does reuse one and it happens to fail....bye bye diff....it is also making sure that the plugs are also properly torqued as well.
  14. Oct 24, 2022 at 7:27 AM
    #2234
    GarlicFarts
    Lil Rhody
    Fair dues. I have a TQ wrench that I used for the rear. I haven't done front and centers on this truck yet, but done them in the past on others. THAT'S where the bags come in handy. I've been able to find the bags at walmart.
    I'm not picky with oils. If it's the right synth/non, and it's the right weight, I just let it ride. Walmart brand or NASA. It does what it needs to do either way. Same with my engine oil. I run walmart oil if that's what's available. If not, I grab whatever oil is 0-20 and in stock. I typically use the Toyota filters just because (also at walmart) they usually only have 2 OEM branded Toyota filters, and it's the smaller one. 1-2$ more, but don't have to spend any time finding the Wix/Fram part numbers, then hunting through the shelves to find them. :D
    When I did my wife's CVT I used WS, for my truck I'll probably just use valvoline or whatever is available. There's a decent thread somewhere showing the alternatives and their suitability, I think it was the Valvoline that comes in good. I'll check before I actually do it though.
    Side note. My town takes spent oil, it's just a big igloo. No difference between gear oil and engine oil. But, no ATF/other fluids. I think some of the Vato zones take spent ATF, I have to get rid of some I've just ignored it for so long :rofl:
    They are usually "press fit" onto the bolt and don't come off the bolts. If it's not there, then it sounds like they missed it :eek:
  15. Oct 24, 2022 at 8:14 AM
    #2235
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    So. Am I to assume there is no one cracking their pumpkins to drain the fluids? Just sucking out the oil ?
  16. Oct 24, 2022 at 8:16 AM
    #2236
    MikefromCT
    CT
    2013 TRD OR DCSB
    Theres a drain plug and a fill plug on both the front and rear diffs, and the xfer case.
  17. Oct 24, 2022 at 8:37 AM
    #2237
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    Yes!! My ram had a crack the pan. Scenario
  18. Oct 25, 2022 at 3:40 AM
    #2238
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Are we still on for the 6th?
  19. Oct 25, 2022 at 3:44 AM
    #2239
    Merling
    James
    NH
    Anyone wanna swap fluids (heh) in the spring? I’m still low 20k miles so I wanna wait.
    I think everyone’s going to crash’s on nov6
    CTSpruceMica and crashngiggles like this.
  20. Oct 25, 2022 at 4:34 AM
    #2240
    crashngiggles
    Jared
    NO problem sir.......even if you wanted to just come down on Nov 6th to check out what we normally do that might be cool as well. If not, we will be starting the mod meets back up in the spring and we can do you diff's and other fluids then.
