New England Mod & Meetup Renaissance group
Discussion in 'North East' started by AllTacosFloat, Apr 14, 2022.
  1. Nov 28, 2022 at 7:57 AM
    #2401
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    2nd gens have a perfect spot for a MXT 275
    zrzW0SSjRSvA0xnjLGe6XmIHfexkbBGWn_YpYHxI_654e4cfc3d9e79cf57926803b1ad8685b24618d3.jpg
  2. Nov 28, 2022 at 3:42 PM
    #2402
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Holy crap!!! I am so doing this. Thank you sir
  3. Nov 29, 2022 at 4:46 AM
    #2403
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    MikefromCT likes this.
  4. Nov 29, 2022 at 4:57 AM
    #2404
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    Such a good spot. I put my cb in there a while ago.
    4B77FC03-077F-46FF-A6A2-83C40A79CD53.jpg 14DD76AF-A6A1-4620-B549-384DA51B5CF2.jpg
    williams63 and CTSpruceMica like this.
  5. Nov 29, 2022 at 4:58 AM
    #2405
    crashngiggles
    Jared
    GarlicFarts and CTSpruceMica like this.
  6. Nov 29, 2022 at 4:59 AM
    #2406
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    Where did you find that molle panel, perfect fit.
    What size did you use and how did you attach it?
    MikefromCT[QUOTED] likes this.
  7. Nov 29, 2022 at 5:15 AM
    #2407
    MikefromCT
    CT
    2013 TRD OR DCSB
    CTSpruceMica[QUOTED] likes this.
  8. Nov 29, 2022 at 5:45 AM
    #2408
    Rexfordian13
    Rexfordian13 Well-Known Member
    J
    Albany/NY Capital District
    2015 TRD Sport DCSB MT
    So, @GarlicFarts if Santa brings me the GMRS radio you linked below (or above, I guess) can you help me program it? Thank you for being a radio nerd that can explain this to me.
    AllTacosFloat[OP] likes this.
  9. Nov 29, 2022 at 5:46 AM
    #2409
    MikefromCT
    CT
    2013 TRD OR DCSB
    Now that I am safely in the office, a couple disclosures/thoughts.
    I did have to trim it slightly for clearance for the latch. Which means you also have to sew the side seam (which is what the molle fabric is secured by). Sewing it was fairly simple but there is a plastic backing inside that you have to get though.
    I have noticed that if I have it loaded with a bunch of items, the spring that opens the console cannot overcome the additional weight. I have yet to find time to try and adjust the spring for more tension; cannot confirm if it can even be done.
    Other than that, its nice to have. I usually have a spare knife, pen, and some other small items on it.
  10. Nov 29, 2022 at 5:55 AM
    #2410
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    If you get a GMRS radio, it will be ready to go out of the box.
    If you get a Baofeng or other HAM radio, it would need to be programmed, and yes - I can help with that.
    The Midland GMRS radios have weather channels too I think.
    I really like that idea...I have one of those in the "intended" place on the passenger visor, but under the console is pretty slick. I might look at moving it/adding another....
  11. Nov 29, 2022 at 5:58 AM
    #2411
    MikefromCT
    CT
    2013 TRD OR DCSB
    Full disclosure, I found the idea on here. I cant take credit for it. Pretty sure this is the thread, but I went with self tapping screws for a secure attachment.
    https://www.tacomaworld.com/threads/grid-it-center-console-lid-organizer-no-drilling.352463/
  12. Dec 1, 2022 at 8:34 AM
    #2412
    GarlicFarts
    Lil Rhody
    Who wants to help me create a fire hazard?
    I want to set up a button on my switch panel to a seat heater and cooler. Whatever the amp draw is, I am thinking run that to a connector somewhere in the cab under-ish the seat, using these.
    https://www.amazon.com/gp/product/B083J3VXLB?smid=A2WGJZQ5PAOUTT
    Then get slip-on seat covers, cooling fans for the summer swamp ass, and heated for the winter. Snip the 12V ends, put those connectors on, and then I'll be able to easily swap them out hot and cold.
    ....Am I making a fire hazard doing that? I just figure I already have the switch panel, and open switches.
  13. Dec 1, 2022 at 10:56 AM
    #2413
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    Well, we can make that work, but we would need to know the current draw of the seat heater. Depending on that, those connectors MAY work. If you want to be super safe, run the button on the switch panel to a relay with a much larger cable so that you can never burn down the cables. Just make sure that the seat heaters have over heat protection of some sort to avoid burning the covers and whatnot.
  14. Dec 1, 2022 at 11:40 AM
    #2414
    GarlicFarts
    Lil Rhody
    Yeah I don't know what the amp draw is yet, I'd have to pick one then look at the specs. I have 2x 20 and 2x 30A fuses open, and 1x 10A (I THINK, it's either 1x 5A or 1x 10A is open, I have 3 occupied).
    It's a very early stages thought, TBD if I pull the trigger. I will suffer with a cold ass this winter at least, and see how bad it is. I think doing the cooled seats in the summer for swamp ass would see a ton more use than heated seats.
  15. Dec 1, 2022 at 11:41 AM
    #2415
    CttAznRanger
    Brandon
    Boston, MA
    We need a callback to the crotch coolers
  16. Dec 13, 2022 at 6:26 AM
    #2416
    GarlicFarts
    Lil Rhody
    I will be here: 1 Kettle Point Ave, Riverside, RI 02915
  17. Dec 20, 2022 at 1:38 PM
    #2417
    AllTacosFloat
    AllTacosFloat [OP] If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    :spy:
    Looks like 1/21 will be the brewery meet. I've been stupid busy with life n work but let's make this happen!
    :cheers:
  18. Dec 20, 2022 at 4:01 PM
    #2418
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Wheres this one at?
    NoFear9491 likes this.
  19. Dec 20, 2022 at 5:35 PM
    #2419
    AllTacosFloat
    Boston ish
    Lost Shoe Brewery Marlborough Ma
    Not to bad of a hike for us:D
    CTSpruceMica and GarlicFarts like this.
  20. Dec 21, 2022 at 4:32 AM
    #2420
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Hour and 15 isnt bad, Im going to try to make it but I close on the house the week before so no promises.
