New England Mod & Meetup Renaissance group
Discussion in 'North East' started by AllTacosFloat, Apr 14, 2022.
  1. Jul 9, 2023 at 9:28 AM
    #3681
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
  2. Jul 9, 2023 at 9:53 AM
    #3682
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    AllTacosFloat[OP] likes this.
  3. Jul 9, 2023 at 9:55 AM
    #3683
    AllTacosFloat
    AllTacosFloat [OP] If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Sounds of bushings, improper torque can help it along.
    I think I would pop everything loose and properly retorque. If it’s still noisy spray down just one set of bushings with lube and take a ride. Repeat on the bushings until you find that bitch.
    Do you have a sway bar? Those links can get squeaky.
    GarlicFarts and Brownmatthall like this.
  4. Jul 9, 2023 at 12:10 PM
    #3684
    CttAznRanger
    Brandon
    Boston, MA
    OK, glad we figured it was a bushing of some sort. Not the UCA, since those are new and have been greased somewhat regularly.
    It may be improper torque, as the Toyota ROKO guys said they were rusted and just torqued so they wouldn't move. This was at least 1.5 years ago or longer.
    I used to have a sway bar, I was essentially side eyed hard enough keep it off after the front suspension swap, lol @crashngiggles .
    I'm thinking of doing the following though:
    New (to me) OEM LCAs, swap bushings for whiteline bushings (already have those), swap out ball joints (just in case), new cam bolts, new cam plates, maybe beef up alignment tabs?
  5. Jul 9, 2023 at 12:22 PM
    #3685
    Brownmatthall
    2016 TRD OR DCSB
    Solid plan
  6. Jul 9, 2023 at 12:28 PM
    #3686
    AllTacosFloat
    Boston ish
    Gonna be cuttin’ them out fo sho:sawzall:
    welcome to the club
  7. Jul 9, 2023 at 12:58 PM
    #3687
    CttAznRanger
    Brandon
    Boston, MA
    Which is what I was hoping to avoid, but that is ok, just means I get to buy those sawzall and bandsaws
  8. Jul 9, 2023 at 1:19 PM
    #3688
    AllTacosFloat
    Boston ish
    If you want, or just use one of mine. Have to do the @Bruce988jl method on those!
    take them apart every year and give them a bath in anti-seize. I do my best to not get it on the threads and clean them off if I do.
  9. Jul 9, 2023 at 3:03 PM
    #3689
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Yes and beefy the tabs is worth it if you're going to continue going offroad. Only a matter of time til the tabs get bent flat
  10. Jul 9, 2023 at 3:16 PM
    #3690
    CttAznRanger
    Brandon
    Boston, MA
    If I use yours what am I going to do with all my Dewalt batteries??? JK, I do appreciate the offer. We may just have to make a mod day out of it then.
    Might have to do routine maintenance with you guys then.
    Lol I think I just get paranoid and go overboard on stuff, like I have the warfare tie rod sleeves that I’ll throw on at some point. That and I might get that tie rod end kit that replaces ours with a massive bolt. I forgot what that one was called.
  11. Jul 9, 2023 at 4:31 PM
    #3691
    Brownmatthall
    2016 TRD OR DCSB
    If you're lucky the rears shouldn't be too bad, but the fronts are definitely gonna be FUBAR if you've got squeaks in your bushings. I'm also gonna be bathing my bolts and tabs in antisieze at least once a year after that experience lmao
  12. Jul 9, 2023 at 5:01 PM
    #3692
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    If your interested we can beef up your tabs 7/23, if I remember correctly @AllTacosFloat had some angle stock to put on those tabs
  13. Jul 9, 2023 at 5:04 PM
    #3693
    CttAznRanger
    Brandon
    Boston, MA
    I’m down for that.
    tacobell007 likes this.
  14. Jul 11, 2023 at 7:22 PM
    #3694
    RockfishTaco
    RockfishTaco Well-Known Member
    Nate
    Massachusetts
    bought this last year when I did my regear but I (obviously) didn’t get the right one. I have no use for it and hate hoarding so free to anyone who needs it or maybe plans on regearing in the future. Pick up/tw express only (fits elocker rears if I’m not mistaken)IMG_2393.jpg
  15. Jul 12, 2023 at 6:45 AM
    #3695
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    Fyi - it says it does not fit the e-locker
    RockfishTaco[QUOTED] likes this.
  16. Jul 12, 2023 at 6:56 AM
    #3696
    RockfishTaco
    Nate
    Massachusetts
    Word. Prob that’s why I bought it not realizing I had a 8.4…
    all I know is I was disappointed when it didn’t fit and had no rtv at 9 PM doing my regear
    Bruce988jl[QUOTED] likes this.
  17. Jul 15, 2023 at 2:39 PM
    #3697
    AllTacosFloat
    Boston ish
    ArmorDitch was a good time, hoped for a bit more considering location. Would be a good park for a tw wheel n meet. Not sure if the other tacos are on tw. Adam in the black/ mud brown truck I think maybe.(I’ve wheeled with him before and he’s crazy in the best way)
    From our group it was only @HAVOC and @RockfishTaco . Nate got to use his winch and Harry gets a new rear bumper:D
    We had fun but the 3bears trip was closer and free
    RockfishTaco, BadDNA, Roody and 5 others like this.
  18. Jul 15, 2023 at 3:32 PM
    #3698
    Brownmatthall
    2016 TRD OR DCSB
    Aw man, Adam's a good time hahaha
  19. Jul 15, 2023 at 3:57 PM
    #3699
    AllTacosFloat
    Boston ish
    For sure! Last year at aoaa he and I were the only two that stayed out on the trails until closing time.
    He said he’ll be at aoaa again this year, a group is slowly forming!
    And yes, 35s do in fact come with a cape!!!!!
  20. Jul 16, 2023 at 12:39 PM
    #3700
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Looks like Harold might need to invest in a new aftermarket rear bumper now lol!!!!
    "Well boys.....I sent her just a little too fucking hard bud!" I have this voice in my head right now.......Good for you Harold......Trail damage adds character.......Not that you weren't before but:
