New England Mod & Meetup Renaissance group
Discussion in 'North East' started by AllTacosFloat, Apr 14, 2022.
  1. Jan 4, 2024 at 11:06 AM
    #5121
    AllTacosFloat
    AllTacosFloat [OP] If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    isn’t this them?
    edit: wrong year
    Re edited: that’s the part number from the thread that I used
    tacobell007 likes this.
  2. Jan 4, 2024 at 11:09 AM
    #5122
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
  3. Jan 4, 2024 at 12:49 PM
    #5123
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    Amazon had 2 sets. I liked my OG spcs. Ill have to get fully new arms the next time they wear out.
  4. Jan 4, 2024 at 2:37 PM
    #5124
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Looks for a used set of icon uniball arms and do the delta joint retrofit
    Chasespeed and AllTacosFloat[OP] like this.
  5. Jan 4, 2024 at 4:39 PM
    #5125
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Building arms could be fun... and I do have a tubing bender and access to machine tools... Why do I get these ideas
    GarlicFarts likes this.
  6. Jan 4, 2024 at 4:53 PM
    #5126
    tacobell007
    Drew
    Western MA
    There's a ton of geometry that goes into them. Would be a challenging project, not sure what they go for now but I bought mine used for $250 awhile back. Icon sells a kit to retrofit their delta joints easily
    Chasespeed and GarlicFarts like this.
  7. Jan 4, 2024 at 4:56 PM
    #5127
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Not saying it would be easy or financially smart. It would be fun though.
  8. Jan 5, 2024 at 7:32 AM
    #5128
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    Thanks for the reminder - I need to do this to my ball joint version of the icon arms so I can swap them back in.
  9. Jan 5, 2024 at 8:23 AM
    #5129
    tacobell007
    Drew
    Western MA
    You'll like them. I had put a set in Tony's old truck and they worked really well. I'll be going to them when I need uniballs again
    Bruce988jl[QUOTED] likes this.
  10. Jan 5, 2024 at 8:27 AM
    #5130
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    I think they are pretty proud of thier delta joint
    Brownmatthall likes this.
  11. Jan 5, 2024 at 8:34 AM
    #5131
    tacobell007
    Drew
    Western MA
    Yea it's suppose to be on par with a uniball as far as movement goes. I like uniballs but the silty soil and if you get any road salt in them then it eats the Teflon and corrodes the chrome plating on the spherical part, creating pitting, rust and faster wear. Then they get sloppy lol
  12. Jan 5, 2024 at 8:38 AM
    #5132
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Does anyone have a set of JBA replacement bushings around? Used is ok I just want some measurements.
    I am wondering if they might work in my OG tubular SPC arms, I like JBAs bushing grease setup too.
  13. Jan 5, 2024 at 8:40 AM
    #5133
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    Jd fab just came out with a sealed uniball, probably spendy but interesting
  14. Jan 5, 2024 at 8:50 AM
    #5134
    tacobell007
    Drew
    Western MA
    Yea the delta joints are spendy too. The real rip off is icons uniball rebuild kit. It's $100 for 2 uniballs and 2 coil clips and a small thing of red locktite and antiseize. I can get the uniballs for $15-$20 each by looking up the part number. Can't imagine the clips are $30ea
    Brownmatthall[QUOTED] likes this.
  15. Jan 5, 2024 at 9:10 AM
    #5135
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Nevermind. SPC's are 51mm ID and JBA uses stock sized bushings 45.4mm.
    Could maybe press a spacer in there. Would be a decent wall thickness at around . 100"
    AllTacosFloat[OP] likes this.
  16. Jan 12, 2024 at 5:15 PM
    #5136
    AllTacosFloat
    Boston ish
    nhpoke, Roody and Chasespeed like this.
  17. Jan 12, 2024 at 5:21 PM
    #5137
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
  18. Jan 12, 2024 at 5:35 PM
    #5138
    Brownmatthall
    2016 TRD OR DCSB
  19. Jan 12, 2024 at 5:43 PM
    #5139
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    I have a fresh bumper I built that isn’t really mine and don’t want to fix. I should have the tube in 3 weeks tho
  20. Jan 12, 2024 at 5:49 PM
    #5140
    Brownmatthall
    2016 TRD OR DCSB
    Extreme field testing
