New England Mod & Meetup Renaissance group
Discussion in 'North East' started by AllTacosFloat, Apr 14, 2022.
  1. Oct 18, 2024 at 7:08 AM
    #8381
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    How's the cutoff?
  2. Oct 18, 2024 at 7:30 AM
    #8382
    AllTacosFloat
    AllTacosFloat [OP] If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    They gonna burn:bananadead:
    happens every time
  3. Oct 18, 2024 at 8:23 AM
    #8383
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Yes, those are them sir
  4. Oct 18, 2024 at 8:26 AM
    #8384
    crashngiggles
    Jared
    Very definitive.......and since the are a direct replacement for a regular bulb, they can be aimed just like a regular bulb.
    GarlicFarts likes this.
  5. Oct 18, 2024 at 8:47 AM
    #8385
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
  6. Oct 18, 2024 at 9:04 AM
    #8386
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    So when are you caging the daily?
    super_white and jpereira2 like this.
  7. Oct 18, 2024 at 9:25 AM
    #8387
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    What's your suggestion? Remove LCAs? We would have to mark it out first, lol.
    Merling likes this.
  8. Oct 18, 2024 at 9:27 AM
    #8388
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    If you just did them It shouldnt be bad. Are you woolwaxxed for this year?
  9. Oct 18, 2024 at 9:39 AM
    #8389
    AllTacosFloat
    Boston ish
    Is that for before or after 37s?
    Mark them and remove. It’ll give Jack more room and you won’t have to worry about burning up the bushings.
  10. Oct 18, 2024 at 9:54 AM
    #8390
    Brownmatthall
    2016 TRD OR DCSB
    Don't temp me with a good time
    Before, less tubbing after
  11. Oct 18, 2024 at 1:35 PM
    #8391
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
  12. Oct 18, 2024 at 1:50 PM
    #8392
    CttAznRanger
    Brandon
    Boston, MA
    Nope, not yet, less chance of catching fire for now.
    jpereira2 likes this.
  13. Oct 18, 2024 at 2:04 PM
    #8393
    Brownmatthall
    2016 TRD OR DCSB
    Robs gonna be the first of us all to start lopping off factory bracketry hahaha
  14. Oct 18, 2024 at 2:34 PM
    #8394
    GarlicFarts
    Lil Rhody
    I'm already thinking about getting a welder to learn it, and be able to do my own serious stuff, mainly one of them Beatles on a razor chassis.
  15. Oct 18, 2024 at 2:59 PM
    #8395
    AllTacosFloat
    Boston ish
    jpereira2 and super_white like this.
  16. Oct 18, 2024 at 3:24 PM
    #8396
    Brownmatthall
    2016 TRD OR DCSB
  17. Oct 18, 2024 at 3:47 PM
    #8397
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Do it, best decision I ever made. I think my truck will stay fairly mild. 35s and a crawling focused flatbed. Still need truck for truck things. Going to get an older and shitter vehicle to really beat on
  18. Oct 18, 2024 at 3:48 PM
    #8398
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
  19. Oct 18, 2024 at 3:53 PM
    #8399
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    NSFW Warning
  20. Oct 18, 2024 at 5:36 PM
    #8400
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Hey, thanks John! :cheers:
    So the fuel cell was actually pretty simple. I was surprised by it. I reused the stock pump/sender to keep fuel level without any other parts or modification needed. You can keep all of the evap system if you live in an inspection state or just want to avoid the dash light. I don't for both of those, so I just ditched the evap system completely, meaning it's two fuel lines, a breather line, and extended the stock 3 wire harness.
    As for the front LT, yes, ~12 inches of travel is about the best you'll get with factory mounting locations and without sacrificing elsewhere. Of course it's no match for 22 inches of rear travel while crawling, but it should balance out pretty well for the fast stuff.
    I was thrown off by the lack of front flex, but immediately reassured by multiple people that it'll be a completely different setup once it's broken in. Makes sense when I think about it. The lower uniballs alone are so stiff that with a 6" bolt through it I still couldn't rotate it by hand. Excited to see how it changes in the next few weeks/months.
    SMKYTXN has my favorite flat bed(ish) setup. He used super heavy duty storage drawer setup as the base, which created a solid flat surface on top. It fit well with the stock axle width and frame rails.
    :wave:
