New England Mod & Meetup Renaissance group
Discussion in 'North East' started by AllTacosFloat, Apr 14, 2022.
  1. Aug 8, 2022 at 11:58 AM
    #1301
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    I'd be down for a late fall slider refinishing. I'm probably just going to leave them off for the winter.
  2. Aug 8, 2022 at 11:58 AM
    #1302
    AllTacosFloat
    AllTacosFloat [OP] If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Got this huge head unit a few years ago. Finally got around to it. Oem one was flickering and sucked from day 1.
    Love the tilting screen but wow is it big! Have to finish wiring the cameras, gets front and rear.
    Did I mention it's pretty big but I'm getting old so big print is safest for y'all.20220808_122003.jpg
    Already hit him up about it and the Ross' trailer. Asked him to try to get some baseline pricing but it's in the details. Lots of detail takes a bit longer than flat.
  3. Aug 8, 2022 at 12:00 PM
    #1303
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    27-28 look good.
  4. Aug 8, 2022 at 12:05 PM
    #1304
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
  5. Aug 8, 2022 at 12:07 PM
    #1305
    AllTacosFloat
    Boston ish
    Did I read You had headlights staying on issues a while back?
    My headlights recently started staying on after door opens with no key? Nothing else staying on?
    @HAVOC , any idea?
    CTSpruceMica likes this.
  6. Aug 8, 2022 at 12:08 PM
    #1306
    AllTacosFloat
    Boston ish
    :rofl::rofl::rofl:
    I'm blind without glasses
    Needed a bigger screen for porn:burp:
  7. Aug 8, 2022 at 12:13 PM
    #1307
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    Nah, hes got a jitterbug.
    First selling point “Large screen and buttons”
  8. Aug 8, 2022 at 12:20 PM
    #1308
    BadDNA
    Eammon
    Cabot, VT
    Yeah, my issue was corroded contacts in a multi-circuit plug under the dash that were shorting to each other when they get wet. High beams were stuck on regardless of key/switch position.
  9. Aug 8, 2022 at 12:29 PM
    #1309
    AllTacosFloat
    Boston ish
    I can't say mine is water related. No rain and record heat.
    Going to order the courtesy switch and put the stock headlights in to troubleshoot. Maybe find and revive that thread.
    Were you able to just clean them or did you put in a new plug?
  10. Aug 8, 2022 at 12:30 PM
    #1310
    BadDNA
    Eammon
    Cabot, VT
    I had to replace pins, it was an absolute shit job that I never want to do again. The connector is way up under the dash and has very little free length.
  11. Aug 8, 2022 at 12:37 PM
    #1311
    AllTacosFloat
    Boston ish
    Well shit, with my luck that's going to be mine as well.
  12. Aug 8, 2022 at 1:35 PM
    #1312
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I’ll look at a EWD when I get home.
  13. Aug 8, 2022 at 2:45 PM
    #1313
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    Easy peasy, you don't even have to deal with swapping coils at that point, just out with the old in with the new
  14. Aug 8, 2022 at 5:23 PM
    #1314
    Taco600mpg
    Taco600mpg Well-Known Member
    Cam
    14 regular cab 5 speed manual
    2.25 inch lift, Firestone airbags, 235/85/16 tires, k&n 63 series cold air intake, LCE header and exhaust, nfab prerunner light bar, trd skid plate 3rd gen oem knock off, ecometer, kc lights, trd grill emblem, trifold bed cover, cb radio and antenna, pedal commander, volant ram air scoop, daystar airbag cradles, trd off road 3rd gen rims, hood hinge light mounts, bilstein 5100 shocks and 5100 struts set at 1.75 lift, strut spacers to gain . 5 more inches of lift, Jba standard high caster upper control arms
    Mass will fail you for smoked tail lights and headlights, They even failed me for having tail light guards so I just removed them. I saw in the state inspection book at a deal that said that there can’t be anything covering or obstructing the head lights tail lights and fog lights. How ever if your truck didn’t come with fog lights and you tint them then they won’t fail you for that.
  15. Aug 8, 2022 at 5:41 PM
    #1315
    Rocket23
    Rocket23 Licensed Dynacologist
    Rocket
    Pennsylvania
    2019 sr5
    The list is growing.
    Yep. I’d rather have the same bill but a good chunk of the money actually in the truck instead of a mechanics pocket.
    Brownmatthall[QUOTED] likes this.
  16. Aug 8, 2022 at 5:58 PM
    #1316
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Here is the wiring for the LATO, light auto turn off system. I don't see anything for the key so here also is the wiring for the key reminder.
    • LATO.pdf
      File size:
      104.5 KB
      3
    • KR.pdf
      File size:
      67.5 KB
  17. Aug 8, 2022 at 6:05 PM
    #1317
    AllTacosFloat
    Boston ish
    Thank you sir:hattip:
    super_white[QUOTED] likes this.
  18. Aug 8, 2022 at 6:29 PM
    #1318
    Merling
    Merling Well-Known Member
    James
    NH
    2021 Black Tacoma TRD OR
    RCI IFS Skid Eibach Stage 2 Explore Overland Sliders
    E009CEA9-F16B-4799-AE10-97468FB67BC9.jpg Really dig the backlights on the DD elites.
    do feel like the body roll on the stock OR is kind of too… reminiscent of my grandpas towncar
    edit: point being probably leaning towards 5100s just forgot what else people said I may need
    Brownmatthall likes this.
  19. Aug 8, 2022 at 10:00 PM
    #1319
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    Although popular here I ran 5100’s on a ram. Back 10 years ago. I found the ride pretty stiff for a 7500 lb truck. Although the built in level was just what I wanted.
  20. Aug 9, 2022 at 5:22 AM
    #1320
    AwesomeLaw68
    AwesomeLaw68 Well-Known Member
    Lawson
    2022 Tacoma Off-road edition
    Brand new.
    What brand of assembled struts are those and where did you get them from?
    Rocket23[QUOTED] likes this.
