New England Mod & Meetup Renaissance group
Discussion in 'North East' started by AllTacosFloat, Apr 14, 2022.
  1. Aug 18, 2022 at 9:19 AM
    #1541
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    2020+ double cabs are pre wired for bed lights.
    I considered the aftermarket third brake lights too - my use was for chase lights. I ended up with a roof rack for kayaks so it just makes more sense to run them off that instead.
  2. Aug 18, 2022 at 9:31 AM
    #1542
    AllTacosFloat
    AllTacosFloat [OP] If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Funny, I'm looking to do the same. Great minds
  3. Aug 18, 2022 at 10:08 AM
    #1543
    GarlicFarts
    Lil Rhody
    My dumb ass.....
    so I pulled the 10A fuse for the airbags (I think). Next to it was an empty slot. Guess what slot has ignition triggered power, and doesn't interfere with the ABS, collision BS, lane departure BS, and headlight system (PS WTF is a headlight system error...?)?
    If you guessed the wide open slot that I ignored, you would be correct!
    :tinfoilhat:
    7th times a charm, I guess.
    EDIT: PS WTF is a headlight system error...?
    Just googled it real quick - 99% chance it's from the auto high beams I forgot I have. Haven't used them in....however many days from when I bought the truck to today. Tried them a couple times, was not impressed.
  4. Aug 18, 2022 at 10:15 AM
    #1544
    Rocket23
    Rocket23 Licensed Dynacologist
    Rocket
    Pennsylvania
    2019 sr5
    The list is growing.
    That is an awesome idea
  5. Aug 18, 2022 at 11:23 AM
    #1545
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Take it from me.....I have been there and done that and it took forever and a day to air up. The small pancake compressors will fill up the tank, the tank will fill up maybe 3/4 of a tire and then you are waiting for the compressor to fill up the tank again. The compressors on those things do not have the power to do direct air. It is actually better to save and spend your money on a viair 400p or a Smittybilt 2781. ARB compressors are great as well but they are more expensive. Some guys do have an onboard air tank for both airing up or to run air lockers but they are still being powered by a direct air style compressor like an ARB, Viair, or Smittybilt.
  6. Aug 18, 2022 at 11:25 AM
    #1546
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    I have a Viair currently riding in the toolbag for tires. I want to use the tank as a burst tank for tools. Gonna make a manifold with a valve to go direct from the Viair for tires/fill the tank for impact or nailgun or whatever.
  7. Aug 18, 2022 at 11:27 AM
    #1547
    crashngiggles
    Jared
    Sounds cool.....go for it then sir :thumbsup:
    This one seems cool to go with since it has everything that you might need instead of parting one out and building one yourself.....it might be cheaper in the long run
    https://www.globalindustrial.com/p/...LZtNgGStJH2QDo4Q7KFyY6Hy_RjZ8HWkaAh4lEALw_wcB
  8. Aug 18, 2022 at 12:08 PM
    #1548
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Ordered both inner CV boots, mine are trash.
    CTSpruceMica likes this.
  9. Aug 18, 2022 at 1:23 PM
    #1549
    AllTacosFloat
    Boston ish
    So I've messed with this compressor over and over and I cannot recreate the spark. Gonna roll with it... maybe something was loose...no idea
    GarlicFarts and crashngiggles like this.
  10. Aug 18, 2022 at 1:58 PM
    #1550
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    How hot was the comp when you saw the sparking, wondering if it got hot enough to tweak something internally just enough to short that one time and now that it's cool it doesn't?
  11. Aug 18, 2022 at 1:59 PM
    #1551
    Brownmatthall
    2016 TRD OR DCSB
    Also, I think it was @adk_tacoma that has his sliders tapped as an air tank for a couple gallons? Always thought that was such a cool concept to implement
    GarlicFarts likes this.
  12. Aug 18, 2022 at 2:05 PM
    #1552
    AllTacosFloat
    Boston ish
    Not hot at all as soon as it sparked I disconnected it. When I took out the bolt it did not Spark but nothing is touching it.
    So today I dropped it and opened the on off housing, buttoned it back up and cannot get it to spark. So it's fixed but I didnt find anything wrong.
    This is why I need supervision
    Brownmatthall[QUOTED] likes this.
  13. Aug 18, 2022 at 2:08 PM
    #1553
    CTSpruceMica
    CTSpruceMica My driving scares me too
    Dennis
    2014 Spruce Mica
    Fixed
  14. Aug 18, 2022 at 2:17 PM
    #1554
    AllTacosFloat
    Boston ish
    Self medicated :rasta:
    I just want a tank and use my big smitty to fill it while I air down. Then air up would go that much faster.
    When I have work compressors with me I would have that much more tank volume.
  15. Aug 18, 2022 at 2:54 PM
    #1555
    GarlicFarts
    Lil Rhody
    Got my tpms toy. Works mint. Added toy for future work days!
    Ooo that is actually kinda cool.
  16. Aug 18, 2022 at 4:02 PM
    #1556
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    Semi-related...well not really...but the early 70s Porsche Le Mans prototype race cars were tube framed. There was a Schrader valve on the frame and they filled the frame tubes with nitrogen. At pit stops they'd check the pressure. If it was down they knew there was a crack and would look for it
  17. Aug 18, 2022 at 4:21 PM
    #1557
    Brownmatthall
    2016 TRD OR DCSB
    Shoulda filled it with helium #weight reduction
    :rofl:
    crashngiggles and GarlicFarts like this.
  18. Aug 18, 2022 at 4:26 PM
    #1558
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    DW (Darrell Waltrip) tells about the time they put lead shot in the frame, pull a lever and it would come out on the track. The hole is where the jack picks up the car so during inspection it is hidden by the jack.
  19. Aug 18, 2022 at 4:33 PM
    #1559
    CTSpruceMica
    Dennis
    2014 Spruce Mica
  20. Aug 19, 2022 at 4:18 AM
    #1560
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    Is this the 'ACC sense wire' for AuxBeam that you've been chasing? Gonna try to get mine installed this weekend was hoping to find something to tap under the hood.
