New England Mod & Meetup Renaissance group
Discussion in 'North East' started by AllTacosFloat, Apr 14, 2022.
  1. Sep 19, 2022 at 7:16 AM
    #1821
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    I was also planning on being in the office today so I made sure to get the first appointment.
    Should have known something was up when it was at the 60-90 min mark, only to tell me the welding news and that it would be at least another 2 hours. Thankfully my wife was able to pick me up and Ill work from home.
    Already behind a couple hours behind on a short work week. Off for a week and a half starting Thursday. Wooo, cant wait, its been forever since I took some time off.
  2. Sep 19, 2022 at 8:04 AM
    #1822
    Rocket23
    Rocket23 Licensed Dynacologist
    Rocket
    Pennsylvania
    2019 sr5
    The list is growing.
    Well I’m pretty sure the carrier drop will solve the slight vibration. Both the transfer case and pumpkin are almost at the same angle. Switching the blocks would not leave the the end angles equal. Isn’t equal angles what we strive for?
  3. Sep 19, 2022 at 8:07 AM
    #1823
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
  4. Sep 19, 2022 at 10:02 AM
    #1824
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    equal angles are what you are looking for yes, but when you add the carrier bearing drop, it shortens up the angle from the carrier bearing. By turning the blocks around, so the higher side is in the rear and the lower side is in the front, it tilts your yoke to the pumpkin up instead of down like we installed it. This would have been the way I would have I set it up if you had the carrier bearing drop at the time of install. I will send you a picture in a pm of an example of what I mean.
  5. Sep 19, 2022 at 10:03 AM
    #1825
    crashngiggles
    Jared
    Rocket23[QUOTED] likes this.
  6. Sep 19, 2022 at 10:06 AM
    #1826
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    No need. I’ll switch em if the problem remains after the carrier drop. But I think it’ll be fine. Mainly because the lift wasn’t that extreme to begin with.
  7. Sep 19, 2022 at 10:10 AM
    #1827
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    Yes. But the 2 piece will act like a one piece after the drop. Like I said it should be fine.
    My question is how bad would the vibrations of been if we did the lift the “right” way. Then did the carrier drop. Or would the truck have been undrivable ?
  8. Sep 19, 2022 at 10:10 AM
    #1828
    crashngiggles
    Jared
    ok....sounds good
  9. Sep 19, 2022 at 10:13 AM
    #1829
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    Let’s see if it feels good when the mod is on. :fingerscrossed:
  10. Sep 19, 2022 at 10:14 AM
    #1830
    crashngiggles
    Jared
    every truck is going to be different and with spacer blocks with angles built in.....it might now be the right angle for your truck. Vibes can be common with our trucks but literally every one truck is different. This is why they have 1, 2, 3, and 4 degree shims when people add either an AAL or new leaf springs.
    AllTacosFloat[OP] likes this.
  11. Sep 19, 2022 at 11:31 AM
    #1831
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    I think we’ll be fine. 1) it’s not a huge lift and 2) the install kept the angles right to accommodate torque on the axle.
  12. Sep 19, 2022 at 11:54 AM
    #1832
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Makes me want to install my axle shins even more now.
  13. Sep 19, 2022 at 11:57 AM
    #1833
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    You're paying for their error? They can fuck right off with that
  14. Sep 19, 2022 at 2:46 PM
    #1834
    MikefromCT
    CT
    2013 TRD OR DCSB
    The notorious clunk I had from speedbumps and pot holes is gone. Could have been the bound up LCAs, or the washer spacing issue for the lower coilover mounts that @crashngiggles identified and helped fix. Either way that makes me really happy.
    Tie rods are next on my list, and a brake job.
  15. Sep 19, 2022 at 3:34 PM
    #1835
    crashngiggles
    Jared
    Was the "clunk" only from the passenger side?
  16. Sep 19, 2022 at 4:51 PM
    #1836
    MikefromCT
    CT
    2013 TRD OR DCSB
    I think so. At least recently.
    I have been chasing down a handful of sounds from the front end the past couple months and they all seem to blend together to me.
  17. Sep 20, 2022 at 12:26 PM
    #1837
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    Well my vibration is gone :thumbsup: the carrier drop was the ticket. No more shudder between 20 an 30. Bilstiens on order. Should be here by Monday :fingerscrossed:
  18. Sep 20, 2022 at 12:37 PM
    #1838
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
  19. Sep 20, 2022 at 3:12 PM
    #1839
    Taco600mpg
    Taco600mpg Well-Known Member
    Cam
    14 regular cab 5 speed manual
    2.25 inch lift, Firestone airbags, 235/85/16 tires, k&n 63 series cold air intake, LCE header and exhaust, nfab prerunner light bar, trd skid plate 3rd gen oem knock off, ecometer, kc lights, trd grill emblem, trifold bed cover, cb radio and antenna, pedal commander, volant ram air scoop, daystar airbag cradles, trd off road 3rd gen rims, hood hinge light mounts, bilstein 5100 shocks and 5100 struts set at 1.75 lift, strut spacers to gain . 5 more inches of lift, Jba standard high caster upper control arms
  20. Sep 20, 2022 at 4:40 PM
    #1840
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    Eventually rust wins. Question is what will last longer. Ownership or life.
