New England Mod & Meetup Thread:
Discussion in 'North East' started by AllTacosFloat, Apr 14, 2022.
  1. Feb 26, 2023 at 1:16 PM
    #2721
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    I have a couple of them.....all of them 10 mm lol
  2. Feb 26, 2023 at 1:28 PM
    #2722
    crashngiggles
    Jared
    We will let you know well in advance sir.
    AllTacosFloat[OP] likes this.
  3. Feb 26, 2023 at 2:13 PM
    #2723
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    Are these the uca bolts I need? Slowly picking away at parts leading up to everything I wanna get done
  4. Feb 26, 2023 at 2:20 PM
    #2724
    AllTacosFloat
    AllTacosFloat [OP] If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    That's them
    Brownmatthall[QUOTED] likes this.
  5. Feb 26, 2023 at 2:37 PM
    #2725
    Brownmatthall
    2016 TRD OR DCSB
    Cool beans, got these ordered and ordered my new intake piping as well. Gonna grab a 4" pvc cap to plug up the existing hole in the box and seam seal everything once it's warm enough. What was the stuff you were telling me to go with?
  6. Feb 26, 2023 at 2:38 PM
    #2726
    gugman
    gugman analog
    bob
    Vermont
    I think mine are ASE
  7. Feb 26, 2023 at 2:50 PM
    #2727
    AllTacosFloat
    Boston ish
  8. Feb 26, 2023 at 2:55 PM
    #2728
    Brownmatthall
    2016 TRD OR DCSB
  9. Feb 26, 2023 at 3:19 PM
    #2729
    AllTacosFloat
    Boston ish
    I'll grab it at home dump in the morning. Need a few plugs.... Friday didn't go as planned at work:bananadead:
    gugman, Clark27, jpereira2 and 2 others like this.
  10. Feb 26, 2023 at 3:30 PM
    #2730
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    Ima probably need some help figuring out a clunking lol. Could be lower control arms, could be sway bar, could be steering rack.....not a clue and it's too cold lol. Could also be cross member possibly. I've had a noise over some bumps but it does it now in reverse with wheels turned. I mean 9 yrs so could be time for a bunch if bushings
  11. Feb 26, 2023 at 3:58 PM
    #2731
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    I know I have my LCA bushings to get done... If it is something else that would suck.
  12. Feb 26, 2023 at 3:59 PM
    #2732
    CttAznRanger
    Brandon
    Boston, MA
    If anything, I do have this:
    jpereira2 likes this.
  13. Feb 26, 2023 at 4:06 PM
    #2733
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    What is behind that? If it's the plastic fitting, just break it and buy a new fitting at the local store.
  14. Feb 26, 2023 at 4:20 PM
    #2734
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    As far as I know, it's a metal nut welded on the inside. Definitely would have snapped by now if it was plastic. One of my screwdrivers was already starting to bend. I bought some left handed drill bits. Hopefully that will work.
  15. Feb 26, 2023 at 4:22 PM
    #2735
    ABA180
    East Bridgewater MA
    Sounds right if you're bending a driver. And yeah my thought would be the drilling it out next also.
    Went through this on the wife's Rav4 but that had the plastics.
  16. Feb 26, 2023 at 4:27 PM
    #2736
    replica9000
    2019 T4R ORP
    The front plate has plastic with the self-tapping screws. The back uses M6 bolts. I need to move out of the rust belt.
    ABA180[QUOTED] likes this.
  17. Feb 26, 2023 at 5:26 PM
    #2737
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Satoshi grill, 3rd Gen TRDOR Bucket Seats, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, LCE Balance Shaft Delete, ECGS front diff bushing, TRD Sport LSD rear diff, Diode Dynamics SS3 Sport fog lights, Stainless Steel Brake-lines, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, Bilstein 8112 front Coilovers w/ rear Bilstein 5125's/IronMan lift leaf springs, Archive Garage Hammer Hangers, JBAs HD UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, 2019 Steering wheel, color matched door handles
    Try hitting the end of the screwdriver with a hammer while it is engaged with the screw, it might help loosen the screw. I would also say try using an impact driver on that screw, but you don't want to dent the lift gate or worse, break off the tack welded nut that is on the inside of the lift gate. If worse comes to worst, break the screw head off, and use a self tapping screw into the the old screw threads.
  18. Feb 26, 2023 at 5:52 PM
    #2738
    ABA180
    East Bridgewater MA
    That makes 2 of us
  19. Feb 27, 2023 at 12:54 PM
    #2739
    replica9000
    2019 T4R ORP
    I'll try the hammer, though I'm not sure I can hit it hard enough to be effective without damage to the lift gate. I might just keep spraying some PB Blaster on it for a bit, and maybe on a warmer day it might cooperate. Otherwise the drill comes out.
  20. Feb 27, 2023 at 3:17 PM
    #2740
    nickonfire700
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    I have only had a couple plate screws come out with an impact driver, but like you said, you don't want to to hit it so hard that you damage the lift gate. Just keep soaking it with some sauce, and it might eventually cooperate!
    replica9000[QUOTED] likes this.
