New England Mod & Meetup Thread:
Discussion in 'North East' started by AllTacosFloat, Apr 14, 2022.
  1. Dec 19, 2023 at 5:33 AM
    #4981
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    :annoyed:
    scrap-metal-rusty-iron-plate-rusty-pieces-scrap-iron-old-metal-surface-corrosion_338311-2124.jpg
    TwistedOmYoga likes this.
  2. Dec 19, 2023 at 5:35 AM
    #4982
    Chasespeed
    In the woods...
    2018 TRD OffRoad
    Some stuff
    You're not TOO far from @tacobell007 , not sure if he done spraying or not though...
    Brownmatthall[QUOTED] likes this.
  3. Dec 19, 2023 at 5:35 AM
    #4983
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Fox and Locked suspension 63's Skinny 33's
    Matts truck come February.
    A buddy asked me to... weld this... back together. That is no longer steel sir, that is known as iron oxide
  4. Dec 19, 2023 at 5:35 AM
    #4984
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    Just gotta get the important bits, I can clean the rest up when it's not frozen out lol
    Chasespeed[QUOTED] likes this.
  5. Dec 19, 2023 at 5:35 AM
    #4985
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    ATF? You might not want to do your ATF, you're kinda just at that cusp where you shouldn't.
    Someone a lot smarter than me can start to get into it, something to do with detergents and the transmission is adapted to the older fluid and new fluid will wash out some of the stuff in the fluid that's making it work :notsure:
    You need to try the old soda bottle and length of fuel line trick.
    Drill a hole in the cap for fuel line and a small hole for blow gun. Pressure blows the oils right in there. Just gotta be easy on the pressure :rofl:[/QUOTE]
    I can see that going well
    Nah I'll give it a whack. I'm not shy. I gotta do the brakes too, so the compressor will get a workout. Little tiny pancake but it should do the trick :rofl:
    Brownmatthall likes this.
  6. Dec 19, 2023 at 5:36 AM
    #4986
    Brownmatthall
    2016 TRD OR DCSB
    I wouldn't be able to get in before he wraps, running down to SC/GA for Christmas
    tacobell007 likes this.
  7. Dec 19, 2023 at 5:37 AM
    #4987
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Nah I'll give it a whack. I'm not shy. I gotta do the brakes too, so the compressor will get a workout. Little tiny pancake but it should do the trick :rofl: [/QUOTE]
    Ive done a drain n fill for atf at 100k,125k, and now 150k. I am doing all the other fluids too. Brakes and front diff are done.
    Also gunna take off the drums and see how bad it looks in there.
  8. Dec 19, 2023 at 5:43 AM
    #4988
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    When you coming back? I might have to extend my spraying due to something that recently came up. Could use the extra money
  9. Dec 19, 2023 at 5:50 AM
    #4989
    Brownmatthall
    2016 TRD OR DCSB
    New years I think, the weekend after work?
  10. Dec 19, 2023 at 5:51 AM
    #4990
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    Oh shit, forgot you moved. Closer to
    me now. I can help if you need, would need it to be a warmer day. Doesn't spray too well if it is cold out.
    Also need to figure out why my sprayer is shooting woolwax out the top two breather holes in the sprayer every now and then. :bananadead:
    edit: go to drew first if you can if he can
  11. Dec 19, 2023 at 5:52 AM
    #4991
    GarlicFarts
    Lil Rhody
    Yeah reminds me I needed to take the drums off to get that done too.
    Okay, if you've been on the ATF, good. You can probably trim that down from 25k, but it's cheap and easy, so do you :)
    Technically I'm at 67.9k, without plans to do much this winter, but a plan for a trip to the grand canyon in the spring. I was thinking to do it all before that, but it might make more sense to do it all after. Would put me up around 80k, I THINK, for miles, when I'd be doing all the stuff. Plus you see threads/posts of people who don't do nearly anything for about 100k miles, so that's reassuring.
  12. Dec 19, 2023 at 5:54 AM
    #4992
    tacobell007
    Drew
    Western MA
    As long as the weather is semi decent
  13. Dec 19, 2023 at 5:54 AM
    #4993
    Brownmatthall
    2016 TRD OR DCSB
    Pencil me in for Saturday then :D
    tacobell007[QUOTED] likes this.
  14. Dec 19, 2023 at 5:55 AM
    #4994
    Brownmatthall
    2016 TRD OR DCSB
    Where are you in CT?
  15. Dec 19, 2023 at 6:01 AM
    #4995
    MikefromCT
    CT
    2013 TRD OR DCSB
    Collinsville
  16. Dec 19, 2023 at 6:17 AM
    #4996
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    @TacoTuesday603 Little busy with work this week but I will try to make it over to pick up that spline socket.
  17. Dec 19, 2023 at 6:18 AM
    #4997
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Sounds good, you can either pick it up after 5 at my place or weekdays in andover, MA anytime from 7 to 4.
  18. Dec 19, 2023 at 6:27 AM
    #4998
    tacobell007
    Drew
    Western MA
    You want an earlier appointment or afternoon?
  19. Dec 19, 2023 at 6:56 AM
    #4999
    Brownmatthall
    2016 TRD OR DCSB
    Earlier, I can hit the road whenever
  20. Dec 19, 2023 at 6:59 AM
    #5000
    Brownmatthall
    2016 TRD OR DCSB
    Shows me as 10 minutes closer now hahaha, it's wild how many things are basically as close as I was before now
    MikefromCT[QUOTED] likes this.
