New England Mod & Meetup Thread:
Discussion in 'North East' started by AllTacosFloat, Apr 14, 2022.
  1. Jan 31, 2024 at 8:54 AM
    #5381
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
  2. Feb 1, 2024 at 4:41 AM
    #5382
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Fox and Locked suspension 63's Skinny 33's
    @AllTacosFloat If this mod day is one I could make, could I paint the new bumper there?
    I'll probably be rockin the same look as your old truck for a few days with the cut bedsides and regular bumper.
    GarlicFarts and CTSpruceMica like this.
  3. Feb 1, 2024 at 4:45 AM
    #5383
    AllTacosFloat
    AllTacosFloat [OP] If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    Should be fine once we settle on a date. Might be doing a few, lots of parts have been arriving! Patched up my lower boot so I don’t have to smell diff fluid when I open the windows
    CTSpruceMica and tacobell007 like this.
  4. Feb 1, 2024 at 4:53 AM
    #5384
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Well thats good, amazing how well the pressure worked at pulling it up. Do you have that paint that we were talking about? The DTM stuff, if not I'll get some
    I think I have everything for my bumper except for the lasercut parts. Still not sure how I am getting those made yet. A friend's work has a plasmatable, My work has waterjets and mills but I didnt pick up 3/8" plate, then there is always send cut send.
    Lmk if you need any welding stuff.
  5. Feb 1, 2024 at 4:57 AM
    #5385
    AllTacosFloat
    Boston ish
    I’ll open what I have when I get home to be sure it’s still good but we usually have a bit on the shelf
  6. Feb 2, 2024 at 8:05 PM
    #5386
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    If anyone is interested the Ultra4 class at King of the Hammers is this weekend, tomorrow I believe. I think you can stream it on YouTube.
    For anyone that doesn't know what the race is, it's a mix of high speed desert running and rock crawling
    https://youtu.be/YHHNvaE4O2Q?si=WsOe5HddRyDtyDHF
  7. Feb 3, 2024 at 5:24 AM
    #5387
    AllTacosFloat
    Boston ish
    Really makes me want to jump this truck!!
    I got some mail the other day:D
    yes we are saving the day and maybe you can come to aoaa later that month:boink:
  8. Feb 3, 2024 at 5:26 AM
    #5388
    tacobell007
    Drew
    Western MA
    Awesome! Invitations will go out in a little bit. As long as the truck is running and good to go
  9. Feb 3, 2024 at 5:30 AM
    #5389
    AllTacosFloat
    Boston ish
    Let us know anything you need! What are your motor plans right now? Doing the head gasket or doing a swap?
  10. Feb 3, 2024 at 5:35 AM
    #5390
    tacobell007
    Drew
    Western MA
    I'm just doing the head gasket for now, cheaper, easier, and quicker fix to the problem. I just got most of the parts in to fix Brian's old truck and make it driveable again. Stephs car is falling apart so going to let her take the Tundra for a year or 2.
    Thinking I'll do head gasket, seals, timing chain and maybe balance shaft chain. I think it can be done in a weekend but the biggest killer is money right now which should improve in a month or 2. My hopes is to have my tacoma done for the Jack & Jill or at the latest for sure done for the wedding
  11. Feb 3, 2024 at 5:41 AM
    #5391
    AllTacosFloat
    Boston ish
    :bananadance::bananadance::bananadance:
  12. Feb 3, 2024 at 7:31 AM
    #5392
    AllTacosFloat
    Boston ish
    Added this to the op. I happen to have needed it for my inspection. Drew was right,, “ but they don’t know the laws”:frusty:
    MGL Chapter 19 Section 90
    “Notwithstanding the provisions of this section, no passenger motor vehicle shall be operated on any way if such vehicle has the side wall or thread of any tire projecting outward beyond the outer portion of the fender or side body panel, unless such vehicle is equipped with four-wheel drive or is otherwise modified and intended for off-the-way use”
    540 CMR 4.04
    “Every passenger motor vehicle under 10,000 lbs. (GVWR) , except four wheel drive vehicles which are equipped with tires which extend beyond the fenders or body of such vehicle shall be equipped with flaps or suitable guards to reduce such spray or splash to the rear and side.”
  13. Feb 3, 2024 at 7:52 AM
    #5393
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    Yep. Dealt with a new inspector last summer with my 1ton...
    Idiot...
    I find them. You should see when I try to get my Buell inspected...
    If we are going to have obnoxious and convoluted laws, we should at least make sure that people are you know... KNOWLEDGEABLE...
    I can't wait to leave this state
  14. Feb 3, 2024 at 7:52 AM
    #5394
    tacobell007
    Drew
    Western MA
  15. Feb 3, 2024 at 7:58 AM
    #5395
    Chasespeed
    In the woods...
    2018 TRD OffRoad
    Some stuff
    tacobell007[QUOTED] likes this.
  16. Feb 3, 2024 at 8:09 AM
    #5396
    tacobell007
    Drew
    Western MA
    You have like 5 to 6 hours before its over. They're still letting people start since it's time based
    GarlicFarts likes this.
  17. Feb 3, 2024 at 9:19 AM
    #5397
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    That's a little weird because I have passed with mine and I do not have mud flaps and my tires stick out about 3 inches from my fenders. I do know that yours are much more protruding though
  18. Feb 3, 2024 at 9:37 AM
    #5398
    tacobell007
    Drew
    Western MA
    It all depends on the shop. I've been passing without flaps for years and the guys there know I'm on small tires just for inspection
    Brownmatthall and Chasespeed like this.
  19. Feb 3, 2024 at 9:53 AM
    #5399
    AllTacosFloat
    Boston ish
    I passed after he read but he was very quick to tell me they must be covered 100%
  20. Feb 3, 2024 at 6:10 PM
    #5400
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    Yeah, many hands make small work and all :D got the date saved as well!
