New England Mod & Meetup Thread:
Discussion in 'North East' started by AllTacosFloat, Apr 14, 2022.
  1. Mar 7, 2024 at 5:43 AM
    #5741
    InfernoAlt
    InfernoAlt Well-Known Member
    I have the BAMF Overland on order because I wanted the full headlight hoops, felt it was worth the extra $300+
  2. Mar 7, 2024 at 5:53 AM
    #5742
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Fox and Locked suspension 63's Skinny 33's
    Yeah Bamf and c4 make great stuff. Seems like they rarely have quality issues compared to other shops too.
  3. Mar 7, 2024 at 8:03 AM
    #5743
    Roody
    Roody Well-Known Member
    Ross
    SW CT
    GX460
    I do love the Aussie style look
  4. Mar 7, 2024 at 8:38 AM
    #5744
    InfernoAlt
    Just sucks that the lead time is so long, 4 months. Feel like a little kid in October counting the days until Christmas.
  5. Mar 7, 2024 at 9:10 AM
    #5745
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Im leaning that way, maybe something like 2 lp6's under the front bar.
    Roody[QUOTED] and Baja Designs like this.
  6. Mar 7, 2024 at 11:11 AM
    #5746
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Those look pretty badass. I have a set of KCs that wouldn't fit where I wanted em, just taking up space on my shelf now :(
  7. Mar 7, 2024 at 11:48 AM
    #5747
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    @AllTacosFloat what fridge do you have? I'm looking at getting a dual zone. Dometic/ARB and Iceco the smallest dual zones are like 60+QT which just seems like a lot of hassle to deal with.
    Future proofing I'm looking for something that can go into the bed, maybe 35-45QT? But I have no idea.
    Chasespeed likes this.
  8. Mar 7, 2024 at 11:56 AM
    #5748
    AllTacosFloat
    AllTacosFloat [OP] If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    I’d recommend a dual zone over the single like I have. Usually when I need both I use this as a freezer and pack a cooler,, neither is usually very full.
  9. Mar 8, 2024 at 4:30 AM
    #5749
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Hey @super_white or @tacobell007. Allegedly you set the motor at TDC then set it either 45 degrees after TDC or 45 degrees before TDC. Do you know which it is for a 2007 Tundra 4.7 (it has VVT).
    It seems different 4.7's have all different specs for that
  10. Mar 8, 2024 at 5:05 AM
    #5750
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    When you do the belt? You set it at TDC by the mark on the crank, check the cam marks and don’t move it.
  11. Mar 8, 2024 at 5:06 AM
    #5751
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Thank you
    tacobell007 likes this.
  12. Mar 8, 2024 at 5:38 AM
    #5752
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Then when you have it assembled, check the marks, turn the crankshaft twice and double check the marks.
  13. Mar 8, 2024 at 6:10 AM
    #5753
    InCogNeatOh Parts
    InCogNeatOh Parts Well-Known Member
    I have one of these brands
    https://www.bougerv.com/products/portable-outdoor-freezer
  14. Mar 8, 2024 at 6:28 AM
    #5754
    GarlicFarts
    Lil Rhody
    Cheers thanks. I want a dual zone but I want to be able to fit it in the bed under the tonneau more. I was looking at some of the higher cost ARBs that might do better in the bed, none of the ones that can fit under the tonneau (I think I have about 18" to play with, I'll have to measure again) have dual zone. Plus in the bed it will have to contend with potential rain and dust, too, when the tonneau isn't on.
    So I kind of want to prioritize size and handling the elements. If I can find a dual zone in that, yippee!
    100W panel is already in the mail. Eclipse trip it will probably be in the cab since I don't think I'll be able to run power to the bed yet by then.
  15. Mar 8, 2024 at 6:33 AM
    #5755
    AllTacosFloat
    Boston ish
    if going in the bed, remember that you will probably loose some space mounting it. My fridge slide looses like an inch… just something to keep in mind
    GarlicFarts[QUOTED] likes this.
  16. Mar 8, 2024 at 6:34 AM
    #5756
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Are any fridges actually IP54 or greater? I thought them in the elements was really a no go
  17. Mar 8, 2024 at 6:50 AM
    #5757
    InCogNeatOh Parts
    Wow, just looked at the ARB, what makes them so much $$$?
  18. Mar 8, 2024 at 7:05 AM
    #5758
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    They are also a no go in an open bed
    GarlicFarts likes this.
  19. Mar 8, 2024 at 7:06 AM
    #5759
    GarlicFarts
    Lil Rhody
    Yeah, I am planning right now to drop a sheet of ply back there with a buttload of T nuts and D rings as tie down points so I can strap down coolers, fridges, gas cans, etc etc wherever I want to, instead of shuffling it in the bed with a cargo bar and being constrained to what Toyota says goes. I will probably put it at the rear of the bed so I don't think I will put a slide in with it. But we'll see what space allows.
    ^^^ that's why. They also have a full list of spares so you can replace everything on the entire fridge. Along with a 50 page warranty/repair manual.
    And now that I look, only the Elements fridge is rated for rain (nothing about dust, just says to blow out the compressor section if it gets dusty).
    https://store.arbusa.com/63-quart-elements-fridge-freezer-10810602/
    It's 1650, BUT it's only 17.1" tall, so it would fit in the bed under the tonneau! :rofl:
  20. Mar 8, 2024 at 7:21 AM
    #5760
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    I'm a Diode Dynamics guy at heart, have spots, floods, fogs, bars...etc lol
    You've seen my truck, shoot me a message if you have any questions.
    crashngiggles and GarlicFarts like this.
