New England Mod & Meetup Thread:
Discussion in 'North East' started by AllTacosFloat, Apr 14, 2022.
  1. Apr 25, 2024 at 10:24 AM
    #6221
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Fox and Locked suspension 63's Skinny 33's
    Thanks for all your help
    CTSpruceMica and Chasespeed like this.
  2. Apr 25, 2024 at 11:49 AM
    #6222
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
  3. Apr 25, 2024 at 5:33 PM
    #6223
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    You can also try: https://belmetric.com/ They are in Massachusetts.
  4. Apr 26, 2024 at 8:37 AM
    #6224
    InCogNeatOh Parts
    InCogNeatOh Parts Well-Known Member
  5. Apr 27, 2024 at 8:43 AM
    #6225
    Merling
    Merling Well-Known Member
    James
    NH
    2021 Black Tacoma TRD OR
    RCI IFS Skid Eibach Stage 2 Explore Overland Sliders
    Can you tell my gf is the decorator?
    pretty happy with $4 aluminum yard stick from HF lol
  6. Apr 28, 2024 at 10:26 AM
    #6226
    InCogNeatOh Parts
    Ok, my suspension discussion from this weeks reading.
    Option one: Bilstein 5100s all around, but why bother.
    Option two: Bilstein 6112/5160 route, seems well liked in the taco world, discussions of leaking in 4Runner world, and overall there seems to be some thoughts the Bilstein are prone to leaking.
    option three: Ironman Foampro stage 3 kit, which seem to be liked in the Land Cruiser and 4Runner world, but according to my local color guide, the green springs will detract from the lunar rock color.
    Option four: Buy once, cry once. Bilstein 8112 zone control upfront and 8100 bypass in the rear.
    If I go aftermarket Upper Control Arms, I like the iron man one. Most corrosion resistant and uses O.E.M. ball. Not sure on the springs still, but based on what I understand the Bilstein shocks warranty requires their springs.
    I almost ordered RCI Skid package yesterday and just put this on hold, they are offering 15% off and an additional 10% if your over a grand, and the aluminum package with power coating is like 20 bucks more than with out due to the sale.
  7. Apr 28, 2024 at 11:39 AM
    #6227
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    Speaking of suspension I attempted to delete my wife's infiniti rear air and failed. I can't even get the nut lose on top
    AllTacosFloat[OP] likes this.
  8. Apr 28, 2024 at 1:37 PM
    #6228
    AllTacosFloat
    AllTacosFloat [OP] If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    I like kroil for rusted stuffs. It needs time to work. Is cutting an option?
  9. Apr 28, 2024 at 2:03 PM
    #6229
    AllTacosFloat
    Boston ish
    I’d pick option 3 and paint the springs. I believe Jared has a wall mounted spring compressor in the works or I’m sure they could be brushed while assembled in like an hour then clear coat the whole enchilada for extra protection.
    crashngiggles likes this.
  10. Apr 28, 2024 at 2:36 PM
    #6230
    InCogNeatOh Parts
    https://ironman4x4america.com/suspe...ted-for-toyota-4runner-2010-non-kdss-stage-3/
    2.5 medium (0 to 110 lbs Additional payload) front springs, Rear either 2 inch medium (0 to 660 lbs additional) or 3 inch (440 to 880 lbs additional). What counts as additional payload. whatever is added over those axles? Or myself and all the extra twinkies I store in my belly?
    Merling likes this.
  11. Apr 28, 2024 at 3:05 PM
    #6231
    AllTacosFloat
    Boston ish
    Technically everything added to the vehicle. You’re probably in the 3” category with your anticipated weight and lift you want. How much are new coils if you change your mind and want to drop an inch? I like options
  12. Apr 28, 2024 at 3:12 PM
    #6232
    InCogNeatOh Parts
    Theirs 225.
  13. Apr 28, 2024 at 3:13 PM
    #6233
    InCogNeatOh Parts
    How does it work with the front and back springs, do you add together?
  14. Apr 28, 2024 at 4:29 PM
    #6234
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    NotARoss has a compressor too
  15. Apr 28, 2024 at 4:30 PM
    #6235
    InCogNeatOh Parts
    All I need to do is hit the pay button, ill wait a day or so to get some other feedback.
    Foam Cell Pro, Non Kdss Stage 3, 3 inch medium load 0 - 110 lbs, fronts, 3 inch, medium plus, 440 - 880 lbs, rear. No airbag delete kit, and prebuilt Coil Overs. My thinking is 3in front and 3 in rear will keep me from putting my nose in the air when I’m loaded.
    I also added the diff drop spacer kit $40, and the adjustable Rear Panhard bar $299. After the 5% discount I’m just under $2800. They say ships in 48 hours typically.
    current vehicle extra weight-150 lbs Sliders, 150 lbs RTT, 50 lbs roof rack. 350 in added accessories plus me easily over 440.
  16. Apr 28, 2024 at 4:33 PM
    #6236
    InCogNeatOh Parts
    I’m not overly stressed about the color, I don’t think it will be seen that easily, and then if your looking under the skirt, you’ll see the hulk parts.
  17. Apr 28, 2024 at 4:59 PM
    #6237
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    I'd skip the diff drop. At best, your losing some clearance up front and at worst, you're shifting where the oil in the diff sits so the back of it gets a little less. Besides that it doesn't really do much anyway
    InCogNeatOh Parts likes this.
  18. Apr 28, 2024 at 5:02 PM
    #6238
    InCogNeatOh Parts
    what about changing the angles, and the possible needle bearing issues. I’m operating on my internet research, so I’m just knowledgeable to be confused. And I’m also ok be on the better safe than sorry.
    What’s funny, is I was think of passing on the panhard, think the 300 isn’t worth it and the 40 was money well spent.
  19. Apr 28, 2024 at 5:08 PM
    #6239
    AllTacosFloat
    Boston ish
    Agreed
    there is a chance that ifs skid won’t clear or you’ll need spacers,, I’d like more input from the likes of @tacobell007 and @JDUB-Fabrication.
    Can y’all help wisely spend money :D
    Brownmatthall[QUOTED] likes this.
  20. Apr 28, 2024 at 5:10 PM
    #6240
    Brownmatthall
    2016 TRD OR DCSB
    https://youtu.be/47aat1tc6zw?si=FrfayuDEHenxwIwm
    This video explains it magnitudes better than I could lol
