New England Mod & Meetup Thread:
Discussion in 'North East' started by AllTacosFloat, Apr 14, 2022.
  1. May 5, 2024 at 12:08 PM
    #6341
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    Smack it with the biggest hammer you can get your hands on, as long as it's steel it'll be fine. What kind of movement are you seeing in the sliders?
    AllTacosFloat[OP] likes this.
  2. May 5, 2024 at 12:19 PM
    #6342
    AllTacosFloat
    AllTacosFloat [OP] If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    Not sure what brand o have but they are weld on and beefy. Better access to the frame fire woolwax than bolt on
    Brownmatthall[QUOTED] likes this.
  3. May 5, 2024 at 1:27 PM
    #6343
    Merling
    Merling Well-Known Member
    James
    NH
    2021 Black Tacoma TRD OR
    RCI IFS Skid Eibach Stage 2 Explore Overland Sliders
    Lmk, if I’m free I’ll come through
  4. May 5, 2024 at 6:08 PM
    #6344
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    IIRC they are Mobtown skids, steel. The fun part is that where it is bent is right on the edge where it turns up, and there already is a reinforcement pretty close as is.
    Lol I don't think a hammer would work, probably need a press of some sort... Hoping we can somehow fit it in Jack's press.
    The one time I hit the sliders (near the front) it ended up moving up and hitting something on the cab. IIRC the only mounting point near the front is a single bolt that uses another plate inside the crossmember/trans mount. I looked at it yesterday and the plate it uses to pinch is bent, so it was plenty tight at some point.
    For reference they are the old Cali Raised ones before they got rid of the stainless steel top plates.
  5. May 6, 2024 at 4:51 AM
    #6345
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Fox and Locked suspension 63's Skinny 33's
    I dont think we will be able to fit it in but we can try. Its a normal 20 ton HF press. Either way we can figure out something.
    We can take a look. I did notice they dont use a square main tube which IMO is the best slider design strength wise. Kind of depends what's really happening on how we can fix it. I am sure we can figure out something
  6. May 6, 2024 at 5:09 AM
    #6346
    AllTacosFloat
    Boston ish
    You need a bigger hammer!! A little fire would help move it along as well
  7. May 6, 2024 at 5:13 AM
    #6347
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
  8. May 6, 2024 at 5:14 AM
    #6348
    AllTacosFloat
    Boston ish
    Yes
    Brownmatthall and CttAznRanger like this.
  9. May 6, 2024 at 5:35 AM
    #6349
    Merling
    James
    NH
    I am finding myself free and available to spectate whenever this happens
  10. May 6, 2024 at 5:42 AM
    #6350
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    We need RI's best wood splitter to man the maul. @GarlicFarts
  11. May 6, 2024 at 5:57 AM
    #6351
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    Brilliant!
    crashngiggles likes this.
  12. May 6, 2024 at 5:58 AM
    #6352
    InCogNeatOh Parts
    InCogNeatOh Parts Well-Known Member
  13. May 6, 2024 at 5:59 AM
    #6353
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    First thought in my head
  14. May 6, 2024 at 10:56 AM
    #6354
    CttAznRanger
    Brandon
    Boston, MA
    That's the one thing I don't have, big fire source.
    I'm sure it will be spectacular.
    You never know, we might need that.
    If we require anywhere near that level of effort, that is going to be really rough.
  15. May 6, 2024 at 10:59 AM
    #6355
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    I have the two things listed in the pictures, we can wack it for a while then if that doesnt work just cut out the bad section and patch in a good one.
    Either way you are going to need to repaint it
    CttAznRanger[QUOTED] likes this.
  16. May 6, 2024 at 1:21 PM
    #6356
    CttAznRanger
    Brandon
    Boston, MA
    Oh it already needs a massive paint job, so we good there.
  17. May 6, 2024 at 6:26 PM
    #6357
    crazychris4124
    crazychris4124 Earn those pinstripes
    Westchester County, NY
    '17 Inferno Moneypit
    Too many but also not enough mods
    any off road trips for May??
    Merling and AllTacosFloat[OP] like this.
  18. May 6, 2024 at 6:36 PM
    #6358
    AllTacosFloat
    Boston ish
    Haven’t heard anything but I could probably be persuaded.
    I do want to start getting a 3 Bears / VW hill trip planned.. May want to take a ride up with just a few and do some sketchy bridge repair.
    Roody, Merling, Chasespeed and 6 others like this.
  19. May 7, 2024 at 4:07 AM
    #6359
    Merling
    James
    NH
    Probably just gonna drive around race point for may and go to Vermont in june
    GarlicFarts likes this.
  20. May 7, 2024 at 4:50 AM
    #6360
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    In for all of this. I could pick up the lumber too sense I think I am the closest
