New England Mod & Meetup Renaissance group
Discussion in 'North East' started by AllTacosFloat, Apr 14, 2022.
  1. Jun 9, 2024 at 3:37 PM
    #6741
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    Weather cleared up and dried out nicely.
  2. Jun 9, 2024 at 5:43 PM
    #6742
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
  3. Jun 10, 2024 at 2:21 AM
    #6743
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    It was a good day. Talked it over with Jared @crashngiggles and Chase @Chasespeed
    Came to the realization that I don't need shims in the rear end. Installing them would cause vibrations. What I'm feeling is probably axle wrap upon take off.
    It happens at 5 to 10 miles per hour (in reverse also). We did get the driver side shim installed in Jared's truck and I wired his license plate lights.
    On the way back home I stopped at @CTSpruceMica house and visited with him and the Mrs.
  4. Jun 10, 2024 at 3:12 AM
    #6744
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    My guess would be the shaft spacer would probably take care of the problem
  5. Jun 10, 2024 at 3:25 AM
    #6745
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    I'll have to look into that. Definitely would be an easier install than the shims.
  6. Jun 10, 2024 at 4:37 AM
    #6746
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Fox and Locked suspension 63's Skinny 33's
    I have one that someone gave me and I am not going to use it if you want to try it
  7. Jun 10, 2024 at 6:11 AM
    #6747
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Merling likes this.
  8. Jun 10, 2024 at 6:53 AM
    #6748
    Chasespeed
    In the woods...
    2018 TRD OffRoad
    Some stuff
    Honestly, a pair of matched batteries, be it, AGM, Lead acid, or Lithium ion, in series, with a stinger and a ground. Toss a tube of rod in the tools box, and call it good.
    Might be a little difficult to start, but....
    Either way, I'd stay with matched batteries. They tend to have different charge and draw characteristics.
    tacobell007 likes this.
  9. Jun 10, 2024 at 7:08 AM
    #6749
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    As mentioned, try to keep the batteries the same type. I'm not sure about charging voltage on Lipo4 or Lithium, but if it is different than the AGM, you could over/under charge one or the other. That, and if the sitting voltage for either is different, the higher one will always discharge into the lower one constantly.
    If you plan on only using them temporarily when welding, I don't see why it wouldn't work. Just don't keep them connected all the time.
  10. Jun 10, 2024 at 7:33 AM
    #6750
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    So the reason I was preferring to use different batteries is I already have an agm and you are not supposed to use a new battery with an old battery (assuming normal isolater setup). And the depth of discharge is alot better for normal house battery tasks
    Lithium would be on a dc-dc
  11. Jun 10, 2024 at 7:36 AM
    #6751
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Yeah Im gunna mess around with my stick welder some more. Alot of what I could repair might by 0.095 or 0.120 wall so it might be tough.
    But also I have only burned maybe 10 rods in my life
  12. Jun 12, 2024 at 4:52 PM
    #6752
    tacobell007
    Drew
    Western MA
    Stickers came in :spy:
    GarlicFarts, lynyrd3, Merling and 5 others like this.
  13. Jun 12, 2024 at 5:02 PM
    #6753
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
  14. Jun 12, 2024 at 5:11 PM
    #6754
    Chasespeed
    In the woods...
    2018 TRD OffRoad
    Some stuff
    Got a call from Hotshot. My front Billies should ship out NLT Monday. :bananadance:
  15. Jun 13, 2024 at 4:47 AM
    #6755
    lynyrd3
    Bill
    East Central Upstate NY
  16. Jun 13, 2024 at 5:13 AM
    #6756
    Chasespeed
    In the woods...
    2018 TRD OffRoad
    Some stuff
    Still too soon.
  17. Jun 13, 2024 at 5:41 AM
    #6757
    Merling
    Merling Well-Known Member
    James
    NH
    2021 Black Tacoma TRD OR
    RCI IFS Skid Eibach Stage 2 Explore Overland Sliders
    Dislike button*
    lynyrd3 and Chasespeed[QUOTED] like this.
  18. Jun 14, 2024 at 5:05 PM
    #6758
    InCogNeatOh Parts
    InCogNeatOh Parts Well-Known Member
    I was thinking it might be time for some Dear John letters.
    Putting some miles on the lift loaded. Liking the over all ride, doesn’t float as much loaded. Went up to just south of Burlington VT yesterday and now in the Ithica, NY area for the night. Minimal Highway, even found gravel once today.
  19. Jun 14, 2024 at 5:11 PM
    #6759
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    What are you doing out in Ithaca?
  20. Jun 14, 2024 at 5:30 PM
    #6760
    InCogNeatOh Parts
    Headed to the Smokey mountains, the long way. Got some music to go see and a while to get there. Plan to hit Nashville next Saturday on the way to a Music Festival in Kentucky the following weekend.
